MICROPROCESSOR
CORE MODULE
RABBITCORE®
RCM3100 SERIES
A cost-effective solution that allows embedded engineers to add
intelligence and I/O control to a wide variety of peripheral devices
Powered by the Rabbit® 3000 microprocessor, the compact
RCM3100 series boasts powerful features and a small footprint
(47 mm × 42 mm) to simplify integration. Its small size and
ease of use when paired with Dynamic C® allow engineers to
add device intelligence and I/O control for many of today’s
embedded applications. The RCM3100 series is ideal for
applications requiring M2M connectivity and is pin-compatible
with the RCM3000 series for cost-effective Ethernet and
non-Ethernet systems.
BENEFITS
Rabbit hardware and Dynamic C are designed in a
complementary fashion for maximum performance and
ease of use in embedded systems. The additional software
components in Dynamic C allow you to add functionality for
embedded application customization.
APPLICATION EXAMPLE
– Rabbit 3000 microprocessor at 30 MHz
– Up to 512K Flash/512K SRAM
Ethernet
– 54 digital I/O and 6 serial ports
(IrDA, HDLC, asynch, SPI)
– 3.3V operation, low power “sleepy” modes (< 2mA)
HEALTHCARE
FACILITY
TREATMENT
CONSOLE PC
– Compact size simplifies integration
– Ready-made platform for fast time-to-market, up to
3 months of design integration time savings
DOSIMETER SYSTEM
– Low-cost embedded microprocessor module
– Easily links to multiple serial devices
Bluetooth
Wireless
Transceiver
Bluetooth
Radio
RS-232
RELATED PRODUCTS
RABBITCORE®
RCM3100
MOSFET
Sensors
RabbitCore®
RCM3000
Series
RabbitCore®
RCM3400
Series
RabbitCore®
RCM3600
Series
RabbitCore®
RCM4100
Series
Dynamic C®
Inside Reader Module
RCM3100
SPECIFICATIONS
| RCM3110
FEATURE
MICROPROCESSOR
Rabbit 3000® at 30 MHz
EMI REDUCTION
Spectrum spreader for reduced EMI (radiated emissions)
FLASH MEMORY
512K (2 × 256K)
256K
SRAM
512K
128K
BACKUP BATTERY
Connection for user-supplied backup battery to support RTC and SRAM
GENERAL-PURPOSE I/O
54 parallel digital I/0 lines:
• 46 configurable I/O
• 4 fixed inputs
• 4 fixed outputs
ADDITIONAL DIGITAL INPUTS
2 startup mode, reset in
ADDITIONAL DIGITAL OUTPUTS
Status, reset out
AUXILIARY I/O BUS
8 data lines and 6 address lines (shared with I/O) plus I/O read/write
SERIAL PORTS
6 shared high-speed, CMOS-compatible ports:
• 6 configurable as asynchronous (with IrDA), 4 as clocked serial (SPI), and 2 as SDLC/HDLC (with IrDA)
• 1 asynchronous clocked serial port dedicated for programming
• Support for MIR/SIR IrDA transceiver
SERIAL RATE
Max. asynchronous baud rate = CLK/8
SLAVE INTERFACE
A slave port allows the RCM3100 to be used as a master or as an intelligent peripheral device with Rabbit-based or any other
type of processor
REAL-TIME CLOCK
Yes
TIMERS
Ten 8-bit timers (6 cascadable from the first),0.100
one dia
10-bit timer with 2 match registers
WATCHDOG/SUPERVISOR
Yes
(2.5)
C44
Y1
PULSE-WIDTH MODULATORS
10-bit free-running counter and four pulse-width registers
INPUT CAPTURE
2-channel input capture can be used to time input signals from various
port pins
C43
RP4
RP1
JP1
RP3
C58
C4
R5
C3
R4
C53
J3
U2
1.650
C54
(41.9)
JP3
C14
C39
U5
RP2
R20 R23
C59 C42 C52
C23
R24
C25
C45
R21
U7
R19
R17
R18
C24
C22
C18
R16 C47
D1
3.15V to 3.45 VDC 75 mA @ 3.3V
C57
-40° C to +85° C
HUMIDITY
5% to 95%, non-condensing
1.375
BOARD SIZE
1.850” × 1.650” × 0.55” (47 mm1.850
× 42 mm × 14 mm)
Y2
R30 U6
C26
(34.9)
(47.0)
(6.2)
0.244
0.100 dia
(2.5)
(14)
(6.2)
(2.2)
0.244
(6.2)
C57
J2
1.850
(47.0)
1.850
J1
(6.2)
0.244
(47.0)
0.244
(34.9)
(2.2)
(6.2)
1.375
0.087
(14)
0.55
GND
0.245
C41
C45
R20 R23
C26
RP2
C59 C42 C52
R21
U7
R19
R17
R18
C24
C22
C18
R30 U6
0.244
JP4
U5
R16 C47
D1
C23
R24
C25
Y2
C56
(41.9)
C39
R14 R26
Q1
1.650
JP3
C14
R12
R11
C13
(1.6)
J3
1.650
(41.9)
0.087
C53
C54
(1.6)
C3
R4
R5
U2
0.063
C4
JP2
C46
0.063
RP4
RP1
JP1
RP3
C43
(6.2)
Y1
0.55
C44
C58
C55
GND
(6.2)
C56
0.245
C41
OPERATING TEMPERATURE
Q1
JP4
R14 R26
C17
POWER
R12
C13
C55
R11
2-channel quadrature decoder accepts inputs from external incremental
encoder modules
QUADRATURE DECODER
C17
JP2
C46
(14)
RCM3100. 512K Flash, 512K SRAM
(6.2)
0.244
(2.2)
(1.6)
0.087
(41.9)
RCM3110. 256K Flash, 128K SRAM
(6.2)
0.244
20-101-0518
1.650
0.063
20-101-0517
DESCRIPTION
0.55
PART NUMBERS
(14)
0.55
DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi
is always available to serve you with expert technical support and our industry
leading warranty. For detailed information visit www.digi.com/support.
(6.2)
0.244
(2.2)
0.087
(1.6)
0.063
J2
J1Inc. All rights reserved.
© 1996-2016
Digi
International
1.850
(47.0)
All trademarks are
the property of their respective owners.
91001603
C2/816
DIGI INTERNATIONAL WORLDWIDE HQ
877-912-3444 / 952-912-3444 / www.digi.com
DIGI INTERNATIONAL SINGAPORE
+65-6213-5380
DIGI INTERNATIONAL FRANCE
+33-1-55-61-98-98 / www.digi.fr
DIGI INTERNATIONAL CHINA
+86-21-50492199 / www.digi.com.cn
DIGI INTERNATIONAL JAPAN
+81-3-5428-0261 / www.digi-intl.co.jp
很抱歉,暂时无法提供与“20-101-0517”相匹配的价格&库存,您可以联系我们找货
