20-101-0507
20-101-0507
    DIGIINTERNATIONAL
20-101-0507 数据手册
RabbitCore® RCM3000 Series Microprocessor Core Module Ideal for engineers who want to rapidly develop and implement embedded systems with fully integrated Ethernet connectivity. Overview The RabbitCore RCM3000 series, featuring the Rabbit® 3000 microprocessor, boasts powerful features and integrated 10Base-T Ethernet to simplify integration. When paired with Dynamic C®, the RCM3000 series allows engineers to add device intelligence and I/O control for many of today’s embedded designs. Its small form factor and low-power modes make the RCM3000 series perfect for remote device applications. The RCM3000 series is pin-compatible with the RCM3100 series, facilitating cost-effective implementation of both Ethernet and non-Ethernet systems. Application Highlight Rabbit hardware and Dynamic C are designed in a complementary fashion for maximum performance and ease of use in embedded systems. The additional software components in Dynamic C allow you to add functionality for embedded application customization. Potential Applications: Serial-to-Ethernet conversion, device web server applications, Ethernet connectivity with I/O and intelligence, device monitoring and data logging. Features/Benefits • Rabbit 3000 microprocessor at 30 MHz • Up to 512K Flash/512K SRAM • 52 digital I/O and 6 serial ports (IrDA, HDLC, asynch, SPI) • 3.3V operation, low power “sleepy” modes (< 2mA) • Small form factor • Royalty-free TCP/IP stack in source code • Low-cost embedded microprocessor module • Security software add-on modules available www.digi.com RCM3000 Specifications RCM3010 Feature Microprocessor Rabbit® 3000 at 30 MHz EMI Reduction Spectrum spreader for reduced EMI (radiated emissions) Ethernet Port 10Base-T interface, RJ-45, 2 LEDs Flash Memory 512K (2 × 256K) 256K 512K 128K SRAM Connection for user-supplied backup battery (to support RTC and SRAM) Backup Battery General-Purpose I/O 52 parallel digital I/0 lines: • 44 configurable I/O • 4 fixed inputs • 4 fixed outputs Additional Digital Inputs 2 startup mode, reset in Additional Digital Outputs Status, reset out Auxiliary I/O Bus 8 data lines and 6 address lines (shared with I/O) plus I/O read/write Serial Ports 6 shared high-speed, CMOS-compatible ports: • 6 configurable as asynchronous (with IrDA), 4 as clocked serial (SPI), and 2 as SDLC/HDLC (with IrDA) • 1 asynchronous serial port dedicated for programming • Support for MIR/SIR IrDA transceiver Serial Rate Max. asynchronous baud rate = CLK/8 Slave Interface A slave port allows the RCM3000 to be used as a master or as an intelligent peripheral device with Rabbit-based or any other type of processor Real-Time Clock Yes Timers Ten 8-bit timers (6 cascadable from the first), one 10-bit timer with 2 match registers Watchdog/Supervisor Yes Pulse-Width Modulators 10-bit free-running counter and four pulse-width registers Input Capture 2-channel input capture can be used to time input signals from various port pins Quadrature Decoder 2-channel quadrature decoder accepts inputs from external incremental encoder modules Power 3.15V to 3.45VDC 150 mA @ 3.3V   Operating Temperature –40° C to +70° C                 Two 2 × 17, 2 mm pitch 1.850” × 2.725” × 0.86” (47 mm × 69 mm × 22 mm)         $79; 20-101-0507 $59; 20-101-0508 $299; 101-0523 None                     Development Kit and Part Number   Price and Part Number           Pricing                    Board Size                        5% to 95%, non-condensing   Connectors (for connection to headers J4 and J5)    Humidity                                  © 2006-2011 Digi International Inc. All rights reserved. Digi, Digi International, the Digi logo, the Making Wireless M2M Easy logo, Rabbit, RabbitCore and Dynamic C are trademarks or registered trademarks of Digi International Inc. in the United States and other countries worldwide. All other trademarks are the property of their respective owners. All information provided is subject to change without notice.   +852-2833-1008 www.digi.cn   +81-3-5428-0261 www.digi-intl.co.jp  +33-1-55-61-98-98 www.digi.fr 91001602 B2/411 BUY ONLINE • www.digiembedded.com   Digi International (HK) Limited   Digi International KK   Digi International France     877-912-3444 952-912-3444 info@digi.com    with expert technical support and a strong one-year warranty. www.digi.com/support Digi International   DIGI SERVICE AND SUPPORT - You can purchase with confidence knowing that Digi is here to support you    Visit www.digiembedded.com for part numbers.
20-101-0507 价格&库存
很抱歉,暂时无法提供与“20-101-0507”相匹配的价格&库存,您可以联系我们找货
