20-101-1131
20-101-1131
    DIGIINTERNATIONAL
    模块
20-101-1131 数据手册
RCM4200 RabbitCore™ MODELS | RCM4200 | RCM4210 | Microprocessor Core Module Key Features • Rabbit® 4000 microprocessor running at up to 58.98 MHz • 10/100Base-T Ethernet, RJ-45 jack • 4 Mbytes or 8 Mbytes Serial Flash for mass data storage • 512K Flash/512K SRAM • 8-channel, 12-bit A/D converter option • Up to 35 GPIO with multi-layer alternate pin functions • Up to 5 serial ports • Synchronized PWM channels with 16-bit counter • Optimized for use with Dynamic C® - a powerful integrated development environment RCM4200 – 10/100 Ethernet Connectivity The RCM4200 family of microprocessor core modules are powerful Design Advantages: • Designed for embedded networking with intelligence and I/O control • Serves web pages, controls remote devices, links equipment to the internet • Security-key feature with “tamper detect” and encryption capabilities adds peace of mind for OEMs and systems integrators • Complete microprocessor, on-board memory, royalty-free TCP/IP stack, and hundreds of sample programs reduces time-to-market embedded control devices that offer intelligence, 10/100Base-T Ethernet connectivity, optional analog, and ample memory for sophisticated data logging and serial to Ethernet applications. The RCM4200 RabbitCore modules are functions that include variable phase PWM. equipped with 10/100 Ethernet connectiv- The Rabbit 4000 boasts an additional 500+ ity, combined with 4 Mbytes or 8 Mbytes new operational code instructions that serial flash memory storage for intensive increases the processing efficiency, from communication and data logging its predecessor the Rabbit 3000. applications. The optional on-board The RCM4200 RabbitCore modules are 12-bit analog channels diversify your easily interchangeable with other RCM4xxx device connectivity options. based products due to electrical and At the heart of the RCM4200 is the Applications • Serial-to-Ethernet applications • Data-logging via Ethernet • Remote monitoring and communications functional compatibility. With a small Rabbit 4000 microprocessor which features footprint of 1.84”x2.42” (47mm x 61mm), a clock speed of up to 58.98 MHz. Other the RCM4200 is compact and can easily features include hardware DMA, auxiliary be mounted directly onto a user-designed I/O, quadrature decoder, input capture, motherboard, allowing CMOS-compatible GPIO lines shared with up to five serial digital devices to interface via the user’s ports, and four levels of alternate pin motherboard. • Web-enabling devices • Device/data management and control www.rabbit.com Developing with the RCM4200 RCM4200 RabbitCore Specifications The RCM4200 Development Kits come com- Features plete with a RabbitCore module, a prototyping Microprocessor board, accessory parts and all development EMI Reduction Spectrum spreader for reduced EMI (radiated emissions) tools specifically designed to get you up and Ethernet Port 10/100Base-T, RJ-45, 3 LEDs running in minutes! Development Kits come Data SRAM with our industry-proven Dynamic C Program Execution Fast SRAM integrated development software that includes Flash Memory an editor, compiler, and in-circuit debugger. Serial Flash Memory Programming is easy with hundreds of Rabbit’s royalty-free approach to TCP/IP Analog Inputs A/D Conversion Time (including 120 μs raw count and Dynamic C) Dynamic C Add-on modules provide added Auxiliary I/O Bus 2 startup mode, reset in, CONVERT 2 startup mode, reset in Status, reset out, analog VREF Status, reset out — 180 μs 8 data lines, 6 address lines (shared with parallel I/O lines) plus I/O read/write Configurable as asynchronous (with IrDA), 4 as clocked serial (SPI), and 1 as SDLC/HDLC Serial Ports via download or CD-ROM. Secure Socket Layer Serial Rate Industry standard web security Slave Interface for embedded applications 35 parallel digital I/O lines configurable with four layers of alternate functions 12 bits (11 bits single-ended) Dynamic C Add-on Modules embedded applications. Software is available 25 parallel digital I/O lines configurable with four layers of alternate functions 8 channels single-ended, or 4 channels differential. Programmable gain 1, 2, 4, 5, 8, 10, 16, and 20 V/V A/D Converter Resolution functionality and customization to your 4 Mbytes Connection for user-supplied backup battery (to support RTC and data SRAM) and all the tools for a robust, embedded implementation. — 512K (8-bit) Additional Inputs Additional Outputs Rabbit 4000 @ 29.49 MHz 8 Mbytes General Purpose I/O developers the lowest development cost, Rabbit 4000 @ 58.98 MHz 512K (8-bit) Backup Battery support and security encryption provides RCM4210 512K (8-bit) samples and libraries that can be used as building blocks to your code. RCM4200 Up to 4 serial ports (shared with programming port, A/D converter, and serial flash) Maximum asynchronous baud rate = CLK/8 Slave port allows the RabbitCore module to be used as an intelligent peripheral device slaved to a master processor Real Time Clock RabbitWeb Timers Easily create web interfaces Watchdog/Supervisor Up to 5 serial ports (shared with programming port, and serial flash) Yes Ten 8-bit timers (6 cascadable from the first), one 10-bit timer with 2 match registers, and one 16-bit timer with 4 outputs and 8 set/reset registers Yes to monitor and control embedded applications FAT File System Pulse-Width Modulators 4 channels synchronized PWM with 10-bit counter 4 channels variable-phase or synchronized PWM with 16-bit counter 3 channels synchronized PWM with 10-bit counter 3 channels variable-phase or synchronized PWM with 16-bit counter Input Capture 4 input capture channels can be used to time input signals from various port pins system for flash memories Quadrature Decoder 1 channel accepts inputs from external incremental encoder modules Advanced Encryption Standard Power (pins unloaded) Popular, network-accessible file 2 channels accept inputs from external incremental encoder modules 3.0–3.6 V DC 128-bit encryption for transfer of sensitive data 240 mA @ 3.3 V (typ.), 275 mA at 3.6 V and 85°C (max.) Operating Temperature -40°C to +85°C Humidity Point-to-Point Protocol 5% to 95%, non-condensing Connectors One 2 × 25, 1.27 mm pitch IDC signal header One 2 × 5, 1.27 mm pitch IDC programming header Board Size 1.84” × 2.42” × 0.84” (47 mm × 61 mm × 21 mm) TCP/IP functionality for serial and PPPoE connections 200 mA @ 3.3 V (typ.), 225 mA at 3.6 V and 85°C (max.) Pricing Library Encryption Executable Program to encrypt Dynamic C library source files Pricing (qty. 1/100) Part Number (RoHs) Development Kit Part Number Rabbit Semiconductor, Inc. $109/$89 20-101-1131 $99/$81 20-101-1132 $269 U.S. 101-1155 Int’l 101-1156 2900 Spafford Street Davis, CA 95616 USA Tel 530.757.8400 Fax 530.757.8402 Copyright© 2006, Rabbit Semiconductor, Inc. All rights Reserved. Rabbit and RabbitCore are trademarks or registered trademarks of Rabbit Semiconductor, Inc.. All other trademarks are the property of their respective owners.
20-101-1131 价格&库存
很抱歉,暂时无法提供与“20-101-1131”相匹配的价格&库存,您可以联系我们找货
