20-101-0673
20-101-0673
    DIGIINTERNATIONAL
    模块
20-101-0673 数据手册
MICROPROCESSOR CORE MODULE RABBITCORE® RCM3600 SERIES Extremely compact and low-cost Rabbit® 3000 microprocessor based core module designed for a wide variety of applications The RabbitCore RCM3600 series is a perfect introduction into embedded control and monitoring. Its small size and ease of integration when paired with Dynamic C® allow engineers to develop a control and monitoring solution for many of today’s applications. The RCM3600 mounts directly onto a userdesigned motherboard with a single 2x20 dual row IDC header, interfacing with all types of CMOS-compatible digital devices. Built-in low EMI features, including a clock spectrum spreader, practically eliminate EMI problems, which helps with passing CE and RF emissions tests. BENEFITS Rabbit hardware and Dynamic C are designed in a complementary fashion for maximum performance and ease of use in embedded systems. The additional software components in Dynamic C allow you to add functionality for customized embedded applications. APPLICATION EXAMPLE – Rabbit 3000 microprocessor at 22 MHz – Up to 512K Flash/512K SRAM – 33 parallel digital I/O with configurable options WAREHOUSE OR INDUSTRIAL BUILDING – 4 serial ports (IrDA, HDLC, async, SPI) – 5 VDC input, 3.3VDC interface Ethernet – Compact footprint: 2.11” x 1.23” x 0.62” (54 mm x 31 mm x 16 mm) RABBITCORE® RCM3600 Inside Message Notification System – Ready-made platform for fast time-to-market – save up to 3 months of design integration time – Low-cost embedded microprocessor module Fire Detector RELATED PRODUCTS ALARM Ceiling Speaker RS-232 Fire Pull Handle RabbitCore® RCM3100 Series RabbitCore® RCM3400 Series RabbitCore® RCM3700 Series RabbitCore® RCM3900 Series Dynamic C® Remote Intercom Interface Emergency Strobe Light SPECIFICATIONS RCM3600 | RCM3610 FEATURE MICROPROCESSOR Rabbit® 3000 at 22 MHz FLASH MEMORY 512K 256K SRAM 512K 128K BACKUP BATTERY Connection for user-supplied backup battery (to support RTC and SRAM) GENERAL-PURPOSE I/O 33 parallel digital I/0 lines: • 31 configurable I/O • 2 fixed outputs ADDITIONAL I/O Reset AUXILIARY I/O BUS Can be configured for 8 data lines and 5 address lines (shared with parallel I/O lines), plus I/O read/write SERIAL PORTS Four 3.3V CMOS-compatible ports configurable as: • 4 asynchronous serial ports (with IrDA) or • 3 clocked serial ports (SPI) plus 1 HDLC (with IrDA) or • 1 clocked serial port (SPI) plus 2 HDLC serial ports (with IrDA) SERIAL RATE Maximum asynchronous baud rate = CLK/8 SLAVE INTERFACE A slave port allows the RCM3600 to be used as an intelligent peripheral device slaved to a master processor, which may either be another Rabbit 3000 or any other type of processor REAL-TIME CLOCK Yes TIMERS Ten 8-bit timers (6 cascadable), one 10-bit timer with 2 match registers WATCHDOG/SUPERVISOR Yes PULSE-WIDTH MODULATORS 4 PWM output channels with 10-bit free-running counter and priority interrupts INPUT CAPTURE/QUADATURE DECODER 2-channel input capture can be used to time input signals from various port pins • 1 quadrature decoder unit accepts inputs from external incremental encoder modules or • 1 quadrature decoder unit shared with 2 PWM channels POWER 5V ±0.25 VDC 60 mA @ 22.1 MHz, 5V; 38 mA @ 11.06 MHz, 5V OPERATING TEMPERATURE -40° C to +85° C HUMIDITY 5% to 95%, non-condensing CONNECTORS One 2 x 20, 0.1” pitch BOARD SIZE 1.23” × 2.11” × 0.62” (31 mm × 54 mm × 16 mm) PART NUMBERS DESCRIPTION 20-101-0672 RCM3600 20-101-0673 RCM3610 DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2016 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91001599 C2/816 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL FRANCE +33-1-55-61-98-98 / www.digi.fr DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Digi International: 20-101-0673
20-101-0673 价格&库存
很抱歉,暂时无法提供与“20-101-0673”相匹配的价格&库存,您可以联系我们找货
