RCM4300 RabbitCore®
MODELS | RCM4300 | RCM4310 |
Core Module With miniSD™ Capability
Key Features
• Rabbit 4000 microprocessor
running @ 58.98 MHz
• Supports up to 1GB miniSD
memory card
• Organize data with FAT file structure
• 1MB of SRAM for shared code
and data
• 512K bytes of battery-backed SRAM
• 10/100Base-T Ethernet port
(RJ-45 connector)
• 12-bit A/D converter (RCM4300 only)
• Up to 36 general-purpose I/O lines
configurable
• Up to 6 serial ports
• Small size: 1.84” × 2.85” × 0.84”
(47 mm × 72 mm × 21 mm)
RCM4300 — More Memory for Data Intensive Applications
Design Advantages:
mass storage than any other RabbitCore module. You can implement
• Hot-swappable mass storage
• Supports over 1MB SRAM for
algorithmic-intensive applications
• Analog inputs for reading
instrument and sensor outputs
• Low-cost and easily deployable
platform for non-critical embedded
security
• Feature set and performance to
implement a web-enabled graphic
user interface
The RCM4300, based on the Rabbit 4000 microprocessor, delivers more
up to 1GB (gigabyte) of industry-standard miniSD memory that can
be hot-swapped for another card if desired. The miniSD memory card
supports the FAT file structure to offer a convenient method of
organizing data and sharing it with other systems.
In addition, Rabbit’s Dynamic C® (version
Furthermore, Rabbit offers modules with
10.21) software supports MCS™ (Megabyte
the same form-factor as the RCM4300
Code Support) to use up to 1 megabyte of
that have either Wi-Fi (RCM4400W) or
on-board SRAM for shared memory and
with ZigBee® (RCM4510W), should those
Applications
code space. Also included on the board
connective technologies be required.
• Data logging
is 512K bytes of battery-backed SRAM
• Automatic meter reading
• Tank monitoring
For designs that require more I/O,
(battery not included) to maintain code
consider the Rabbit RIO chip to add both
and data during power down mode.
general I/O and special-feature I/O, such
The RCM4300 is pin-compatible with
as PWM and input capture. For more
• Utilities and power systems
other RCM4xxx core modules, enabling
information, please visit:
• Factory automation
easy migration from other designs.
http://www.rabbit.com/products/RIO.
• Instrumentation
www.rabbit.com
The RCM4300 series also includes the
RCM4300 RabbitCore® Specifications
RCM4310, which is a lower cost version of the
RCM4300 that offers less SRAM and removes
Feature
the analog input support.
Microprocessor
Rabbit® 4000 @ 58.98 MHz
For more details, please go to the RCM4300
RCM4300
RCM4310
EMI Reduction
Spectrum spreader for reduced EMI (radiated emissions)
User’s Manual at: http://www.rabbit.com/docs/
Ethernet Port
10/100Base-T, RJ-45, 3 LEDs
manuals/RCM4300/RC4300UM.pdf
Data SRAM
Developing with the RCM4300
The development kit has all the essentials
needed to design a microprocessor-based
embedded system with mass storage. The
kit includes an RCM4300 with a miniSD
card, a prototyping board, accessories,
and development tools to get you up
and running quickly. Along with our
industry-proven Dynamic C® Integrated
Development Environment (IDE) that includes
a full-featured C compiler, editor, and in-circuit
debugger, the RCM4300 supports a FAT
file system for mass storage (used with the
on-board SD card), RabbitWeb for creating
dynamic HTML interfaces, and Rabbit’s
Shared Code/Data and
Program Execution Fast SRAM
Serial Flash Memory
(used for program storage)
Flash Memory
(mass data storage)
LED Indicators
Backup Battery
General-Purpose I/O
Additional Inputs
Additional Outputs
Analog Inputs:
CMOS Compatible
Serial Ports
Transport Layer Security (TLS/SSL)
implementation for secure web transactions.
Dynamic C® Add-on Modules
Rabbit delivers add-on modules for
Dynamic C to help you complete your design
in less time and with higher system reliability.
These proven software modules, included
with the RCM4300 development kit, allow you
to add just the right features to support your
design requirements.
Secure Socket Layer
Industry standard web security
for embedded applications
SSL
Serial Rate
to monitor and control
RabbitWeb embedded applications
1MB (8-bit)
512K (8-bit)
2MB
1MB
miniSD™ Card 128MB – 1GB (NAND Flash)
LINK/ACT (link/activity) FDX/COL (full-duplex/collisions) SPEED
(on for 100Base-T Ethernet connection) SD (minSD™ card info TBD)
Connection for user-supplied backup battery (to support RTC and data SRAM)
28 parallel digital I/O lines, configurable
with four layers of alternate functions
36 parallel digital I/O lines, configurable
2 startup mode, reset in, CONVERT
Status, reset out, analog VREF
Status, reset out
• 8 channels single-ended or 4 channels
differential
• 12-bit resolution (11-bit single ended)
• 180 us conversion time
Up to 5 serial ports ports (shared
with programming port, A/D converter,
miniSD Card, and serial flash)
Up to 6 serial ports ports (shared
Maximum asynchronous baud rate = CLK/8
Slave Interface
Slave port allows the RCM4300 to be used as an intelligent
peripheral device slaved to a master processor
Real-Time Clock
Yes
Timers
Ten 8-bit and one 16-bit
Watchdog/Supervisor
Pulse-Width Modulators
Input Capture
Quadrature Decoder
Yes
4 PWM registers with 10-bit free-running counter and priority interrupts
2-channel input capture can be used to time input signals from various port pins
2-channel quadrature decoder accepts inputs from external incremental encoder modules
Power (pins unloaded)
350mA @ 3.3V (typ).
Operating Temperature
Without SD card: -20° C to +85° C.
With SD card: Varies according to card specs
Humidity
5% to 95%, non-condensing
Connectors
One 2 × 25, 1.27 mm pitch IDC signal header. One miniSD™ card socket
One 2 × 5, 1.27 mm pitch IDC programming header
Board Size
1.84” × 2.85” × 0.84” (47 mm × 72 mm × 21 mm)
RabbitWeb
Easily create web interfaces
512K (8-bit)
Pricing
Price (qty. 1/100)
Part Number
Development Kit
Part Number
$114/$101
20-101-1138
$99/$81
20-101-1139
$299
101-1177
FAT File System
Popular, network-accessible file
FAT
system for flash memories
Rabbit®
2900 Spafford Street Davis, CA 95618 USA Tel 530.757.8400 Fax 530.757.8402
Copyright© 2008, Rabbit. All rights reserved. Rabbit is a Digi International brand. Rabbit and RabbitCore are trademarks or registered trademarks
of Rabbit. All other trademarks are the property of their respective owners.
很抱歉,暂时无法提供与“20-101-1138”相匹配的价格&库存,您可以联系我们找货
