CC-MX-KD69-ZM
CC-MX-KD69-ZM
    DIGIINTERNATIONAL
    模块
    MOD I.MX53 1GHZ 512MB FLASH
CC-MX-KD69-ZM 数据手册
PRODUCT NOTICE #5-2-16-1 DATE: May 2, 2016 PRODUCT: ConnectCore for i.MX51 ConnectCore for i.MX53 REASON: Three-axis accelerometer component obsolescence PART NUMBERS AFFECTED (SKUs): All active ConnectCore for i.MX51 and ConnectCore for i.MX53 SKUs ; see Appendix A ESTIMATED EFFECTIVITY: September 1, 2016 NOTICE: Due to component obsolescence, the Freescale/NXP Accelerometer component MMA7455L will no longer be available as a standard population on all active ConnectCore for i.MX51/i.MX53 SKUs. The component (and the functionality it provides) will be removed from the ConnectCore for i.MX51/i.MX53 product line, per the effectivity date stated above. If you have any additional questions or concerns, please contact your local Digi channel partner or Digi account manager. _____ MIKE ROHRMOSER DIRECTOR OF PRODUCT MANAGEMENT, EMBEDDED SYSTEMS 11001 Bren Road East, Minnetonka, MN 55343 Page 1 of 4 Appendix A: Affected Part Numbers Part Number Description CC-MX-KD47-ZM ConnectCore i.MX53 1GHz, 128/128 1xENET CC-MX-KD47-ZM-B ConnectCore i.MX53 1GHz, 128/128 1xENET (25) CC-MX-KD69-ZM ConnectCore i.MX53 1GHz 512/512 1xENET CC-MX-KD69-ZM-B ConnectCore i.MX53 1GHz 512/512 1xENET (25) CC-MX-LB47-ZM ConnectCore i.MX51 800 MHz, 128/128 1xENET CC-MX-LB47-ZM-B ConnectCore i.MX51 800 MHz, 128/128 1xENET (25) CC-MX-LB58-ZM ConnectCore i.MX51 800 MHz, 256/256 1xENET CC-MX-LB58-ZM-B ConnectCore i.MX51 800 MHz, 256/256 1xENET (25) CC-MX-LB69-GMD ConnectCore i.MX51 800 MHz,512/512 2xENET (25) CC-MX-LB69-GMD-1 ConnectCore i.MX51 800 MHz,512/512 2xENET CC-MX-LB69-ZK ConnectCore i.MX51 800 MHz, 512/512 2xENET CC-MX-LB69-ZK-B ConnectCore i.MX51 800 MHz, 512/512 2xENET (25) CC-MX-LB69-ZM ConnectCore i.MX51 800 MHz, 512/512 1xENET CC-MX-LB69-ZM-B ConnectCore i.MX51 800 MHz, 512/512 1xENET (25) CC-MX-LB6B-ZM ConnectCore i.MX51 800 MHz, 2GB ND/512 1xENET CC-MX-LB6B-ZM-B ConnectCore i.MX51 800 MHz, 2GB ND/512 1xENET (25) CC-MX-LC47-Z1 ConnectCore i.MX51 800 MHz, 128/128 no ENET CC-MX-LC47-Z1-B ConnectCore i.MX51 800 MHz, 128/128 no ENET (25) CC-MX-LC47-ZM ConnectCore i.MX51 800 MHz, 128/128 1xENET CC-MX-LC47-ZM-B ConnectCore i.MX51 800 MHz, 128/128 1xENET (25) CC-MX-LD69-ZM ConnectCore i.MX53 800MHz,512/512 1xENET CC-MX-LD69-ZM-B ConnectCore i.MX53 800MHz,512/512 1xENET (25) CC-MX-LD6A-ZM ConnectCore i.MX53 800MHz, 1G ND/512 1xENET CC-MX-LD6A-ZM-B ConnectCore i.MX53 800MHz, 1G ND/512 1xENET (25) CC-MX-LD79-QTC ConnectCore i.MX53 800MHz, 512ND/1GB 2xENET (25) CC-MX-LD79-QTC-1 ConnectCore i.MX53 800MHz, 512ND/1GB 2xENET CC-MX-LD79-ZK ConnectCore i.MX53 800MHz, 512/1GB 2xENET CC-MX-LD79-ZK-B ConnectCore i.MX53 800MHz, 512/1GB 2xENET (25) CC-MX-MB47-ZM ConnectCore i.MX51 600 MHz, 128/128 1xENET CC-MX-MB47-ZM-B ConnectCore i.MX51 600 MHz, 128/128 1xENET (25) CC-MX-MB58-ZM ConnectCore i.MX51 600 MHz, 256/256 1xENET CC-MX-MB58-ZM-B ConnectCore i.MX51 600 MHz, 256/256 1xENET (25) CC-MX-MB69-ZK ConnectCore i.MX51 600 MHz, 512/512 2xENET CC-MX-MB69-ZK-B ConnectCore i.MX51 600 MHz, 512/512 2xENET (25) CC-MX-MB69-ZM ConnectCore i.MX51 600 MHz, 512/512 1xENET Page 2 of 4 Part Number Description CC-MX-MB69-ZM-B ConnectCore i.MX51 600 MHz, 512/512 1xENET (25) CC-MX-MB6B-SLB ConnectCore i.MX51 600 MHz, 2GND/512MB 2xENET (25) CC-MX-MB6B-SLB-1 ConnectCore i.MX51 600 MHz, 2GND/512MB 2xENET CC-WMX51-CE ConnectCore Wi-i.MX51 Windows Embedded CC-WMX51-LX ConnectCore Wi-i.MX51 Linux JSK CC-WMX53-ANDRD ConnectCore Wi.-i.MX53 Android App Dev Kit CC-WMX53-CE ConnectCore Wi.-i.MX53 WinCE JSK CC-WMX53-LX ConnectCore Wi-i.MX53 Linux JSK CC-WMX-KD47-VM ConnectCore Wi-i.MX53 1GHz, 128/128 1xENET CC-WMX-KD47-VM-B ConnectCore Wi-i.MX53 1GHz, 128/128 1xENET (25) CC-WMX-KD69-VK ConnectCore Wi-i.MX53 1GHz, 512/512 2xENET CC-WMX-KD69-VK-B ConnectCore Wi-i.MX53 1GHz, 512/512 2xENET (25) CC-WMX-KD69-VM ConnectCore Wi-i.MX53 1GHz, 512/512 1xENET CC-WMX-KD69-VM-B ConnectCore Wi-i.MX53 1GHz, 512/512 1xENET (25) CC-WMX-KD79-VK ConnectCore Wi-i.MX53 1GHz, 512/1GB 2xENET CC-WMX-KD79-VK-B ConnectCore Wi-i.MX53 1GHz, 512/1GB 2xENET (25) CC-WMX-LB47-VM ConnectCore Wi-i.MX51 800 MHz, 128/128 1xENET CC-WMX-LB47-VM-B ConnectCore Wi-i.MX51 800 MHz, 128/128 1xENET (25) CC-WMX-LB58-VM ConnectCore Wi-i.MX51 800 MHz, 256/256 1xENET CC-WMX-LB58-VM-B ConnectCore Wi-i.MX51 800 MHz, 256/256 1xENET (25) CC-WMX-LB69-CV ConnectCore Wi-i.MX51 GR101347 (25) CC-WMX-LB69-CV-1 ConnectCore Wi-i.MX51 GR101347 CC-WMX-LB69-EYK ConnectCore Wi-i.MX51 800 MHz, 512/512 2xENET (25) CC-WMX-LB69-EYK1 ConnectCore Wi-i.MX51 800 MHz, 512/512 2xENET CC-WMX-LB69-VK ConnectCore Wi-i.MX51 800 MHz, 512/512 2xENET CC-WMX-LB69-VK-B ConnectCore Wi-i.MX51 800 MHz, 512/512 2xENET (25) CC-WMX-LB69-VM ConnectCore Wi-i.MX51 800 MHz,512/512,1xENET CC-WMX-LB69-VM-B ConnectCore Wi-i.MX51 800 MHz,512/512,1xENET (25) CC-WMX-LB6B-VM ConnectCore Wi-i.MX51 800 MHz, 2GB ND/512 1xENET CC-WMX-LB6B-VM-B ConnectCore Wi-i.MX51 800 MHz, 2GB ND/512 (25) CC-WMX-LC47-VM ConnectCore Wi-i.MX512 800MHz, 128/128 1xENET CC-WMX-LC47-VM-B ConnectCore Wi-i.MX512 800MHz, 128/128 1xENET (25) CC-WMX-LD69-VM ConnectCore Wi-i.MX53 800MHz, 512/512 1xENET CC-WMX-LD69-VM-B ConnectCore Wi-i.MX53 800MHz, 512/512 1xENET (25) CC-WMX-LD79-QTC ConnectCore Wi-i.MX53 800MHz, 512ND/1GB 2xENET(25) CC-WMX-LD79-QTC1 ConnectCore Wi-i.MX53 800MHz, 512ND/1GB 2xENET RMA CC-WMX-LD79-VK ConnectCore Wi-i.MX53 800MHz, 512ND/1GB 2xENET Page 3 of 4 Part Number Description CC-WMX-LD79-VK-B ConnectCore Wi-i.MX53 800MHz, 512ND/1GB 2xENET(25) CC-WMX-MB47-VM ConnectCore Wi-i.MX51 600 MHz, 128/128 1xENET CC-WMX-MB47-VM-B ConnectCore Wi-i.MX51 600 MHz, 128/128 1xENET (25) CC-WMX-MB58-VM ConnectCore Wi-i.MX51 600 MHz, 256/256 1xENET CC-WMX-MB58-VM-B ConnectCore Wi-i.MX51 600 MHz, 256/256 1xENET (25) CC-WMX-MB69-VK ConnectCore Wi-i.MX51 600 MHz, 512/512 2xENET CC-WMX-MB69-VK-B ConnectCore Wi-i.MX51 600 MHz, 512/512 2xENET (25) CC-WMX-MB69-VM ConnectCore Wi-i.MX51 600 MHz, 512/512 1xENET CC-WMX-MB69-VM-B ConnectCore Wi-i.MX51 600 MHz, 512/512 1xENET (25) Page 4 of 4
CC-MX-KD69-ZM 价格&库存
很抱歉,暂时无法提供与“CC-MX-KD69-ZM”相匹配的价格&库存,您可以联系我们找货
