74HC4051D,653
74HC4051D,653
    NEXPERIA(安世)
    SOIC16_150MIL
    8通道模拟多路复用器/解复用器 SOIC16_150MIL 120Ω
74HC4051D,653 数据手册
74HC4051; 74HCT4051 8-channel analog multiplexer/demultiplexer Rev. 9 — 26 September 2017 1 Product data sheet General description The 74HC4051; 74HCT4051 is a single-pole octal-throw analog switch (SP8T) suitable for use in analog or digital 8:1 multiplexer/demultiplexer applications. The switch features three digital select inputs (S0, S1 and S2), eight independent inputs/outputs (Yn), a common input/output (Z) and a digital enable input (E). When E is HIGH, the switches are turned off. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2 Features and benefits • Wide analog input voltage range from -5 V to +5 V • Complies with JEDEC standard no. 7A • Low ON resistance: – 80 Ω (typical) at VCC - VEE = 4.5 V – 70 Ω (typical) at VCC - VEE = 6.0 V – 60 Ω (typical) at VCC - VEE = 9.0 V • Logic level translation: to enable 5 V logic to communicate with ±5 V analog signals • Typical ‘break before make’ built-in • ESD protection: – HBM JESD22-A114F exceeds 2000 V – MM JESD22-A115-A exceeds 200 V – CDM JESD22-C101E exceeds 1000 V • Multiple package options • Specified from -40 °C to +85 °C and -40 °C to +125 °C 3 Applications • Analog multiplexing and demultiplexing • Digital multiplexing and demultiplexing • Signal gating 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer 4 Ordering information Table 1. Ordering information Type number 74HC4051D Package Temperature range Name Description Version -40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 -40 °C to +125 °C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 -40 °C to +125 °C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 -40 °C to +125 °C DHVQFN16 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 16 terminals; body 2.5 x 3.5 x 0.85 mm 74HCT4051D 74HC4051DB 74HCT4051DB 74HC4051PW 74HCT4051PW 74HC4051BQ 74HCT4051BQ 5 SOT763-1 Functional diagram VCC 16 13 Y0 S0 11 14 Y1 15 Y2 S1 10 12 Y3 LOGIC LEVEL CONVERSION 1 Y4 1-OF-8 DECODER S2 9 5 Y5 2 Y6 E 6 4 Y7 3 Z 8 GND 7 VEE 001aad543 Figure 1.  Functional diagram 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer 11 10 9 6 13 S0 S1 S2 11 14 10 15 9 12 1 5 2 E 6 4 3 0 8X 2 0 7 G8 Y0 Y1 MUX/DMUX 0 Y2 13 14 1 Y3 15 2 Y4 12 3 3 Y5 1 4 Y6 5 5 Y7 2 6 4 7 Z 001aad542 001aad541 Figure 2.  Logic symbol Figure 3.  IEC logic symbol Y VCC VEE VCC VCC VCC VEE from logic VEE Z 001aad544 Figure 4.  Schematic diagram (one switch) 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer 6 Pinning information 6.1 Pinning 1 Y4 terminal 1 index area Y6 2 15 Y2 Z 3 14 Y1 Y7 4 13 Y0 Y5 5 12 Y3 E 6 VEE 7 3 14 Y1 Y7 4 13 Y0 Y5 5 12 Y3 E 6 11 S0 VEE 7 10 S1 GND 8 9 9 2 Z 11 S0 10 S1 8 Y6 16 VCC 15 Y2 S2 1 VCC(1) GND 74HC4051 74HCT4051 Y4 16 VCC 74HC4051 74HCT4051 001aad540 Transparent top view (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad.However, if it is soldered, the solder land should remain floating or be connected to VCC. S2 001aad539 Figure 5.  Pin configuration SO16, and (T)SSOP16 Figure 6.  Pin configuration DHVQFN16 6.2 Pin description Table 2. Pin description Symbol Pin Description E 6 enable input (active LOW) VEE 7 supply voltage GND 8 ground supply voltage S0, S1, S2 11, 10, 9 select input Y0, Y1, Y2, Y3, Y4, Y5, Y6, Y7 13, 14, 15, 12, 1, 5, 2, 4 independent input or output Z 3 common output or input VCC 16 supply voltage 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer 7 Function description Table 3. Function table [1] Input Channel ON E S2 S1 S0 L L L L Y0 to Z L L L H Y1 to Z L L H L Y2 to Z L L H H Y3 to Z L H L L Y4 to Z L H L H Y5 to Z L H H L Y6 to Z L H H H Y7 to Z H X X X switches off [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. 8 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to VSS = 0 V (ground). Symbol Parameter Conditions [1] Min Max Unit -0.5 +11.0 V VCC supply voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V - ±20 mA ISK switch clamping current VSW < -0.5 V or VSW > VCC + 0.5 V - ±20 mA ISW switch current -0.5 V < VSW < VCC + 0.5 V - ±25 mA IEE supply current - ±20 mA ICC supply current - 50 mA IGND ground current - -50 mA Tstg storage temperature -65 +150 °C - 500 mW - 100 mW Ptot total power dissipation SO16, (T)SSOP16, and DHVQFN16 package P power dissipation per switch [2] [1] To avoid drawing VCC current out of terminal Z, when switch current flows into terminals Yn, the voltage drop across the bidirectional switch must not exceed 0.4 V. If the switch current flows into terminal Z, no VCC current will flow out of terminals Yn, and in this case there is no limit for the voltage drop across the switch, but the voltages at Yn and Z may not exceed VCC or VEE. [2] For SO16 packages: above 70 °C the value of Ptot derates linearly with 8 mW/K. For SSOP16 and TSSOP16 packages: above 60 °C the value of Ptot derates linearly with 5.5 mW/K. For DHVQFN16 packages: above 60 °C the value of Ptot derates linearly with 4.5 mW/K. 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer 9 Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC Conditions 74HC4051 74HCT4051 Unit Min Typ Max Min Typ Max VCC - GND 2.0 5.0 10.0 4.5 5.0 5.5 V VCC - VEE 2.0 5.0 10.0 2.0 5.0 10.0 V see Figure 7 supply voltage and Figure 8 VI input voltage GND - VCC GND - VCC V VSW switch voltage VEE - VCC VEE - VCC V Tamb ambient temperature -40 +25 +125 -40 +25 +125 °C Δt/ΔV input transition rise and fall VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V VCC = 10.0 V - - 31 - - - ns/V rate 001aad545 10 VCC - GND (V) 001aad546 10 VCC - GND (V) 8 8 6 6 operating area operating area 4 4 2 2 0 0 2 4 6 8 10 VCC - VEE (V) Figure 7.  Guaranteed operating area as a function of the supply voltages for 74HC4051 74HC_HCT4051 Product data sheet 0 0 2 4 6 8 10 VCC - VEE (V) Figure 8.  Guaranteed operating area as a function of the supply voltages for 74HCT4051 All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer 10 Static characteristics Table 6. RON resistance per switch for 74HC4051 and 74HCT4051 VI = VIH or VIL; for test circuit see Figure 9. Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. For 74HC4051: VCC - GND or VCC - VEE = 2.0 V, 4.5 V, 6.0 V and 9.0 V. For 74HCT4051: VCC - GND = 4.5 V and 5.5 V, VCC - VEE = 2.0 V, 4.5 V, 6.0 V and 9.0 V. Symbol Parameter Conditions Min Typ Max Unit - - - Ω VCC = 4.5 V; VEE = 0 V; ISW = 1000 μA - 100 180 Ω VCC = 6.0 V; VEE = 0 V; ISW = 1000 μA - 90 160 Ω VCC = 4.5 V; VEE = -4.5 V; ISW = 1000 μA - 70 130 Ω - 150 - Ω VCC = 4.5 V; VEE = 0 V; ISW = 1000 μA - 80 140 Ω VCC = 6.0 V; VEE = 0 V; ISW = 1000 μA - 70 120 Ω VCC = 4.5 V; VEE = -4.5 V; ISW = 1000 μA - 60 105 Ω - 150 - Ω VCC = 4.5 V; VEE = 0 V; ISW = 1000 μA - 90 160 Ω VCC = 6.0 V; VEE = 0 V; ISW = 1000 μA - 80 140 Ω VCC = 4.5 V; VEE = -4.5 V; ISW = 1000 μA - 65 120 Ω - - - Ω VCC = 4.5 V; VEE = 0 V - 9 - Ω VCC = 6.0 V; VEE = 0 V - 8 - Ω VCC = 4.5 V; VEE = -4.5 V - 6 - Ω Tamb = 25 °C RON(peak) ON resistance (peak) Vis = VCC to VEE VCC = 2.0 V; VEE = 0 V; ISW = 100 μA RON(rail) ON resistance (rail) [1] Vis = VEE VCC = 2.0 V; VEE = 0 V; ISW = 100 μA [1] Vis = VCC VCC = 2.0 V; VEE = 0 V; ISW = 100 μA ΔRON ON resistance mismatch between channels 74HC_HCT4051 Product data sheet [1] Vis = VCC to VEE VCC = 2.0 V; VEE = 0 V All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 [1] © Nexperia B.V. 2017. All rights reserved. 7 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer Symbol Parameter Conditions Min Typ Max Unit - - - Ω VCC = 4.5 V; VEE = 0 V; ISW = 1000 μA - - 225 Ω VCC = 6.0 V; VEE = 0 V; ISW = 1000 μA - - 200 Ω VCC = 4.5 V; VEE = -4.5 V; ISW = 1000 μA - - 165 Ω - - - Ω VCC = 4.5 V; VEE = 0 V; ISW = 1000 μA - - 175 Ω VCC = 6.0 V; VEE = 0 V; ISW = 1000 μA - - 150 Ω VCC = 4.5 V; VEE = -4.5 V; ISW = 1000 μA - - 130 Ω - - - Ω VCC = 4.5 V; VEE = 0 V; ISW = 1000 μA - - 200 Ω VCC = 6.0 V; VEE = 0 V; ISW = 1000 μA - - 175 Ω VCC = 4.5 V; VEE = -4.5 V; ISW = 1000 μA - - 150 Ω - - - Ω VCC = 4.5 V; VEE = 0 V; ISW = 1000 μA - - 270 Ω VCC = 6.0 V; VEE = 0 V; ISW = 1000 μA - - 240 Ω VCC = 4.5 V; VEE = -4.5 V; ISW = 1000 μA - - 195 Ω - - - Ω VCC = 4.5 V; VEE = 0 V; ISW = 1000 μA - - 210 Ω VCC = 6.0 V; VEE = 0 V; ISW = 1000 μA - - 180 Ω VCC = 4.5 V; VEE = -4.5 V; ISW = 1000 μA - - 160 Ω - - - Ω VCC = 4.5 V; VEE = 0 V; ISW = 1000 μA - - 240 Ω VCC = 6.0 V; VEE = 0 V; ISW = 1000 μA - - 210 Ω VCC = 4.5 V; VEE = -4.5 V; ISW = 1000 μA - - 180 Ω Tamb = -40 °C to +85 °C RON(peak) ON resistance (peak) Vis = VCC to VEE VCC = 2.0 V; VEE = 0 V; ISW = 100 μA RON(rail) ON resistance (rail) [1] Vis = VEE VCC = 2.0 V; VEE = 0 V; ISW = 100 μA [1] Vis = VCC VCC = 2.0 V; VEE = 0 V; ISW = 100 μA [1] Tamb = -40 °C to +125 °C RON(peak) ON resistance (peak) Vis = VCC to VEE VCC = 2.0 V; VEE = 0 V; ISW = 100 μA RON(rail) ON resistance (rail) [1] Vis = VEE VCC = 2.0 V; VEE = 0 V; ISW = 100 μA [1] Vis = VCC VCC = 2.0 V; VEE = 0 V; ISW = 100 μA [1] [1] When supply voltages (VCC - VEE) near 2.0 V the analog switch ON resistance becomes extremely non-linear. When using a supply of 2 V, it is recommended to use these devices only for transmitting digital signals. 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer mnb047 110 (1) RON (Ω) 90 70 Vsw (2) V from select input VCC 50 Z 30 (3) Sn Yn Vis GND VEE Isw 10 001aan389 Vis = 0 V to (VCC - VEE). 0 1.8 3.6 5.4 7.2 Vis (V) 9.0 Vis = 0 V to (VCC - VEE). (1) VCC = 4.5 V (2) VCC = 6 V (3) VCC = 9 V Figure 9.  Test circuit for measuring RON Figure 10.  Typical RON as a function of input voltage Vis Table 7. Static characteristics for 74HC4051 Voltages are referenced to GND (ground = 0 V). Vis is the input voltage at pins Yn or Z, whichever is assigned as an input. Vos is the output voltage at pins Z or Yn, whichever is assigned as an output. Symbol Parameter Conditions Min Typ Max Unit HIGH-level input VCC = 2.0 V 1.5 1.2 - V voltage VCC = 4.5 V 3.15 2.4 - V VCC = 6.0 V 4.2 3.2 - V VCC = 9.0 V 6.3 4.7 - V LOW-level input VCC = 2.0 V - 0.8 0.5 V voltage VCC = 4.5 V - 2.1 1.35 V VCC = 6.0 V - 2.8 1.8 V VCC = 9.0 V - 4.3 2.7 V VCC = 6.0 V - - ±0.1 μA VCC = 10.0 V - - ±0.2 μA per channel - - ±0.1 μA all channels - - ±0.4 μA Tamb = 25 °C VIH VIL II IS(OFF) input leakage current OFF-state leakage current 74HC_HCT4051 Product data sheet VEE = 0 V; VI = VCC or GND VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; |VSW| = VCC - VEE; see Figure 11 All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer Symbol Parameter Min Typ Max Unit IS(ON) ON-state leakage VI = VIH or VIL; |VSW| = VCC - VEE; current VCC = 10.0 V; VEE = 0 V; see Figure 12 - - ±0.4 μA ICC supply current VCC = 6.0 V - - 8.0 μA VCC = 10.0 V - - 16.0 μA - 3.5 - pF independent pins Yn - 5 - pF common pins Z - 25 - pF VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 9.0 V 6.3 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V VCC = 9.0 V - - 2.7 V VCC = 6.0 V - - ±1.0 μA VCC = 10.0 V - - ±2.0 μA per channel - - ±1.0 μA all channels - - ±4.0 μA IS(ON) ON-state leakage VI = VIH or VIL; |VSW| = VCC - VEE; current VCC = 10.0 V; VEE = 0 V; see Figure 12 - - ±4.0 μA ICC supply current VCC = 6.0 V - - 80.0 μA VCC = 10.0 V - - 160.0 μA CI input capacitance Csw switch capacitance Conditions VEE = 0 V; VI = VCC or GND; Vis = VEE or VCC; Vos = VCC or VEE Tamb = -40 °C to +85 °C VIH VIL II IS(OFF) HIGH-level input voltage LOW-level input voltage input leakage current OFF-state leakage current 74HC_HCT4051 Product data sheet VEE = 0 V; VI = VCC or GND VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; |VSW| = VCC - VEE; see Figure 11 VEE = 0 V; VI = VCC or GND; Vis = VEE or VCC; Vos = VCC or VEE All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer Symbol Parameter Conditions Min Typ Max Unit VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 9.0 V 6.3 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V VCC = 9.0 V - - 2.7 V VCC = 6.0 V - - ±1.0 μA VCC = 10.0 V - - ±2.0 μA per channel - - ±1.0 μA all channels - - ±4.0 μA IS(ON) ON-state leakage VI = VIH or VIL; |VSW| = VCC - VEE; current VCC = 10.0 V; VEE = 0 V; see Figure 12 - - ±4.0 μA ICC supply current VCC = 6.0 V - - 160.0 μA VCC = 10.0 V - - 320.0 μA Tamb = -40 °C to +125 °C VIH VIL II IS(OFF) HIGH-level input voltage LOW-level input voltage input leakage current OFF-state leakage current 74HC_HCT4051 Product data sheet VEE = 0 V; VI = VCC or GND VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; |VSW| = VCC - VEE; see Figure 11 VEE = 0 V; VI = VCC or GND; Vis = VEE or VCC; Vos = VCC or VEE All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer Table 8. Static characteristics for 74HCT4051 Voltages are referenced to GND (ground = 0 V). Vis is the input voltage at pins Yn or Z, whichever is assigned as an input. Vos is the output voltage at pins Z or Yn, whichever is assigned as an output. Symbol Parameter Conditions Min Typ Max Unit Tamb = 25 °C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 V II input leakage current VI = VCC or GND; VCC = 5.5 V; VEE = 0 V - - ±0.1 μA IS(OFF) OFF-state leakage current VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; per channel - - ±0.1 μA all channels - - ±0.4 μA - - ±0.4 μA VCC = 5.5 V; VEE = 0 V - - 8.0 μA VCC = 5.0 V; VEE = -5.0 V - - 16.0 μA IS(ON) ICC |VSW| = VCC - VEE; see Figure 11 ON-state leakage current VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; supply current VI = VCC or GND; Vis = VEE or VCC; |VSW| = VCC - VEE; see Figure 12 Vos = VCC or VEE ΔICC additional supply per input; VI = VCC - 2.1 V; other inputs at VCC current or GND; VCC = 4.5 V to 5.5 V; VEE = 0 V - 50 180 μA CI input capacitance - 3.5 - pF Csw switch capacitance independent pins Yn - 5 - pF common pins Z - 25 - pF 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer Symbol Parameter Conditions Min Typ Max Unit Tamb = -40 °C to +85 °C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 V II input leakage current VI = VCC or GND; VCC = 5.5 V; VEE = 0 V - - ±1.0 μA IS(OFF) OFF-state leakage current VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; per channel - - ±1.0 μA all channels - - ±4.0 μA - - ±4.0 μA VCC = 5.5 V; VEE = 0 V - - 80.0 μA VCC = 5.0 V; VEE = -5.0 V - - 160.0 μA - - 225 μA IS(ON) ICC |VSW| = VCC - VEE; see Figure 11 ON-state leakage current VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; supply current VI = VCC or GND; Vis = VEE or VCC; |VSW| = VCC - VEE; see Figure 12 Vos = VCC or VEE ΔICC additional supply per input; VI = VCC - 2.1 V; other inputs at VCC current or GND; VCC = 4.5 V to 5.5 V; VEE = 0 V Tamb = -40 °C to +125 °C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 V II input leakage current VI = VCC or GND; VCC = 5.5 V; VEE = 0 V - - ±1.0 μA IS(OFF) OFF-state leakage current VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; per channel - - ±1.0 μA all channels - - ±4.0 μA - - ±4.0 μA VCC = 5.5 V; VEE = 0 V - - 160.0 μA VCC = 5.0 V; VEE = -5.0 V - - 320.0 μA - - 245 μA IS(ON) ICC |VSW| = VCC - VEE; see Figure 11 ON-state leakage current VCC = 10.0 V; VEE = 0 V; VI = VIH or VIL; supply current VI = VCC or GND; Vis = VEE or VCC; |VSW| = VCC - VEE; see Figure 12 Vos = VCC or VEE ΔICC additional supply per input; VI = VCC - 2.1 V; other inputs at VCC current or GND; VCC = 4.5 V to 5.5 V; VEE = 0 V 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer VCC from select input Sn Isw A nYn Isw nZ GND Vis A VEE Vos 001aah827 Vis = VCC and Vos = VEE. Vis = VEE and Vos = VCC. Figure 11.  Test circuit for measuring OFF-state current VCC HIGH from select input Sn Isw A nYn Vis nZ GND Vos VEE 001aah828 Vis = VCC and Vos = open-circuit. Vis = VEE and Vos = open-circuit. Figure 12.  Test circuit for measuring ON-state current 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 14 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer 11 Dynamic characteristics Table 9. Dynamic characteristics for 74HC4051 GND = 0 V; tr = tf = 6 ns; CL = 50 pF; for test circuit see Figure 15. Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. Symbol Parameter Conditions Min Typ Max Unit VCC = 2.0 V; VEE = 0 V - 14 60 ns VCC = 4.5 V; VEE = 0 V - 5 12 ns VCC = 6.0 V; VEE = 0 V - 4 10 ns - 4 8 ns VCC = 2.0 V; VEE = 0 V - 72 345 ns VCC = 4.5 V; VEE = 0 V - 29 69 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF - 22 - ns VCC = 6.0 V; VEE = 0 V - 21 59 ns - 18 51 ns VCC = 2.0 V; VEE = 0 V - 66 345 ns VCC = 4.5 V; VEE = 0 V - 28 69 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF - 20 - ns VCC = 6.0 V; VEE = 0 V - 19 59 ns - 16 51 ns VCC = 2.0 V; VEE = 0 V - 58 290 ns VCC = 4.5 V; VEE = 0 V - 31 58 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF - 18 - ns VCC = 6.0 V; VEE = 0 V - 17 49 ns VCC = 4.5 V; VEE = -4.5 V - 18 42 ns VCC = 2.0 V; VEE = 0 V - 61 290 ns VCC = 4.5 V; VEE = 0 V - 25 58 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF - 19 - ns VCC = 6.0 V; VEE = 0 V - 18 49 ns VCC = 4.5 V; VEE = -4.5 V - 18 42 ns Tamb = 25 °C tpd propagation delay Vis to Vos; RL = ∞ Ω; see Figure 13 [1] VCC = 4.5 V; VEE = -4.5 V ton turn-on time E to Vos; RL = ∞ Ω; see Figure 14 [2] VCC = 4.5 V; VEE = -4.5 V Sn to Vos; RL = ∞ Ω; see Figure 14 [2] VCC = 4.5 V; VEE = -4.5 V toff turn-off time E to Vos; RL = 1 kΩ; see Figure 14 Sn to Vos; RL = 1 kΩ; see Figure 14 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 [3] [3] © Nexperia B.V. 2017. All rights reserved. 15 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer Symbol CPD Parameter Conditions Min Typ Max - 25 - pF VCC = 2.0 V; VEE = 0 V - - 75 ns VCC = 4.5 V; VEE = 0 V - - 15 ns VCC = 6.0 V; VEE = 0 V - - 13 ns - - 10 ns VCC = 2.0 V; VEE = 0 V - - 430 ns VCC = 4.5 V; VEE = 0 V - - 86 ns VCC = 6.0 V; VEE = 0 V - - 73 ns - - 64 ns VCC = 2.0 V; VEE = 0 V - - 430 ns VCC = 4.5 V; VEE = 0 V - - 86 ns VCC = 6.0 V; VEE = 0 V - - 73 ns - - 64 ns VCC = 2.0 V; VEE = 0 V - - 365 ns VCC = 4.5 V; VEE = 0 V - - 73 ns VCC = 6.0 V; VEE = 0 V - - 62 ns - - 53 ns VCC = 2.0 V; VEE = 0 V - - 365 ns VCC = 4.5 V; VEE = 0 V - - 73 ns VCC = 6.0 V; VEE = 0 V - - 62 ns VCC = 4.5 V; VEE = -4.5 V - - 53 ns power dissipation per switch; VI = GND to VCC [4] Unit capacitance Tamb = -40 °C to +85 °C tpd propagation delay Vis to Vos; RL = ∞ Ω; see Figure 13 [1] VCC = 4.5 V; VEE = -4.5 V ton turn-on time E to Vos; RL = ∞ Ω; see Figure 14 [2] VCC = 4.5 V; VEE = -4.5 V Sn to Vos; RL = ∞ Ω; see Figure 14 [2] VCC = 4.5 V; VEE = -4.5 V toff turn-off time E to Vos; RL = 1 kΩ; see Figure 14 [3] VCC = 4.5 V; VEE = -4.5 V Sn to Vos; RL = 1 kΩ; see Figure 14 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 [3] © Nexperia B.V. 2017. All rights reserved. 16 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer Symbol Parameter Conditions Min Typ Max Unit VCC = 2.0 V; VEE = 0 V - - 90 ns VCC = 4.5 V; VEE = 0 V - - 18 ns VCC = 6.0 V; VEE = 0 V - - 15 ns VCC = 4.5 V; VEE = -4.5 V - - 12 ns VCC = 2.0 V; VEE = 0 V - - 520 ns VCC = 4.5 V; VEE = 0 V - - 104 ns VCC = 6.0 V; VEE = 0 V - - 88 ns - - 77 ns VCC = 2.0 V; VEE = 0 V - - 520 ns VCC = 4.5 V; VEE = 0 V - - 104 ns VCC = 6.0 V; VEE = 0 V - - 88 ns - - 77 ns VCC = 2.0 V; VEE = 0 V - - 435 ns VCC = 4.5 V; VEE = 0 V - - 87 ns VCC = 6.0 V; VEE = 0 V - - 74 ns - - 72 ns VCC = 2.0 V; VEE = 0 V - - 435 ns VCC = 4.5 V; VEE = 0 V - - 87 ns VCC = 6.0 V; VEE = 0 V - - 74 ns VCC = 4.5 V; VEE = -4.5 V - - 72 ns Tamb = -40 °C to +125 °C propagation delay Vis to Vos; RL = ∞ Ω; see Figure 13 tpd ton turn-on time E to Vos; RL = ∞ Ω; see Figure 14 [1] [2] VCC = 4.5 V; VEE = -4.5 V Sn to Vos; RL = ∞ Ω; see Figure 14 [2] VCC = 4.5 V; VEE = -4.5 V toff turn-off time E to Vos; RL = 1 kΩ; see Figure 14 [3] VCC = 4.5 V; VEE = -4.5 V Sn to Vos; RL = 1 kΩ; see Figure 14 [1] [2] [3] [4] [3] tpd is the same as tPHL and tPLH. ton is the same as tPZH and tPZL. toff is the same as tPHZ and tPLZ. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + Σ{(CL + Csw) x VCC x fo} where: fi = input frequency in MHz; fo = output frequency in MHz; N = number of inputs switching; 2 Σ{(CL + Csw) x VCC x fo} = sum of outputs; CL = output load capacitance in pF; Csw = switch capacitance in pF; VCC = supply voltage in V. 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 17 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer Table 10. Dynamic characteristics for 74HCT4051 GND = 0 V; tr = tf = 6 ns; CL = 50 pF; for test circuit see Figure 15. Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. Symbol Parameter Conditions Min Typ Max Unit - 5 12 ns - 4 8 ns VCC = 4.5 V; VEE = 0 V - 26 55 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF - 22 - ns VCC = 4.5 V; VEE = -4.5 V - 16 39 ns VCC = 4.5 V; VEE = 0 V - 28 55 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF - 24 - ns - 16 39 ns VCC = 4.5 V; VEE = 0 V - 19 45 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF - 16 - ns - 16 32 ns VCC = 4.5 V; VEE = 0 V - 23 45 ns VCC = 5.0 V; VEE = 0 V; CL = 15 pF - 20 - ns - 16 32 ns - 25 - pF - - 15 ns - - 10 ns - - 69 ns - - 49 ns VCC = 4.5 V; VEE = 0 V - - 69 ns VCC = 4.5 V; VEE = -4.5 V - - 49 ns Tamb = 25 °C tpd propagation delay Vis to Vos; RL = ∞ Ω; see Figure 13 [1] VCC = 4.5 V; VEE = 0 V VCC = 4.5 V; VEE = -4.5 V ton turn-on time E to Vos; RL = 1 kΩ; see Figure 14 Sn to Vos; RL = 1 kΩ; see Figure 14 [2] [2] VCC = 4.5 V; VEE = -4.5 V toff turn-off time E to Vos; RL = 1 kΩ; see Figure 14 [3] VCC = 4.5 V; VEE = -4.5 V Sn to Vos; RL = 1 kΩ; see Figure 14 [3] VCC = 4.5 V; VEE = -4.5 V CPD power dissipation per switch; VI = GND to VCC - 1.5 V [4] capacitance Tamb = -40 °C to +85 °C tpd propagation delay Vis to Vos; RL = ∞ Ω; see Figure 13 [1] VCC = 4.5 V; VEE = 0 V VCC = 4.5 V; VEE = -4.5 V ton turn-on time E to Vos; RL = 1 kΩ; see Figure 14 [2] VCC = 4.5 V; VEE = 0 V VCC = 4.5 V; VEE = -4.5 V Sn to Vos; RL = 1 kΩ; see Figure 14 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 [2] © Nexperia B.V. 2017. All rights reserved. 18 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer Symbol toff Parameter turn-off time Conditions Min Typ Max VCC = 4.5 V; VEE = 0 V - - 56 ns VCC = 4.5 V; VEE = -4.5 V - - 40 ns VCC = 4.5 V; VEE = 0 V - - 56 ns VCC = 4.5 V; VEE = -4.5 V - - 40 ns - - 18 ns - - 12 ns - - 83 ns - - 59 ns - - 83 ns - - 59 ns - - 68 ns - - 48 ns VCC = 4.5 V; VEE = 0 V - - 68 ns VCC = 4.5 V; VEE = -4.5 V - - 48 ns E to Vos; RL = 1 kΩ; see Figure 14 Sn to Vos; RL = 1 kΩ; see Figure 14 Unit [3] [3] Tamb = -40 °C to +125 °C propagation delay Vis to Vos; RL = ∞ Ω; see Figure 13 tpd [1] VCC = 4.5 V; VEE = 0 V VCC = 4.5 V; VEE = -4.5 V ton turn-on time E to Vos; RL = 1 kΩ; see Figure 14 [2] VCC = 4.5 V; VEE = 0 V VCC = 4.5 V; VEE = -4.5 V Sn to Vos; RL = 1 kΩ; see Figure 14 [2] VCC = 4.5 V; VEE = 0 V VCC = 4.5 V; VEE = -4.5 V toff turn-off time E to Vos; RL = 1 kΩ; see Figure 14 [3] VCC = 4.5 V; VEE = 0 V VCC = 4.5 V; VEE = -4.5 V Sn to Vos; RL = 1 kΩ; see Figure 14 [1] [2] [3] [4] [3] tpd is the same as tPHL and tPLH. ton is the same as tPZH and tPZL. toff is the same as tPHZ and tPLZ. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + Σ{(CL + Csw) x VCC x fo} where: fi = input frequency in MHz; fo = output frequency in MHz; N = number of inputs switching; 2 Σ{(CL + Csw) x VCC x fo} = sum of outputs; CL = output load capacitance in pF; Csw = switch capacitance in pF; VCC = supply voltage in V. 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 19 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer 50 % Vis input tPLH tPHL 50 % Vos output 001aad555 Figure 13.  Input (Vis) to output (Vos) propagation delays VI E, Sn inputs VM 0V tPLZ tPZL 50 % Vos output 10 % tPHZ tPZH 90 % 50 % Vos output switch ON switch OFF switch ON 001aad556 For 74HC4051: VM = 0.5 x VCC. For 74HCT4051: VM = 1.3 V. Figure 14.  Turn-on and turn-off times 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 20 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VCC Vis PULSE GENERATOR VI VCC Vos S1 RL DUT RT open CL GND VEE 001aae382 Definitions for test circuit; see Table 11: RT = termination resistance should be equal to the output impedance Zo of the pulse generator. CL = load capacitance including jig and probe capacitance. RL = load resistance. S1 = Test selection switch. Figure 15.  Test circuit for measuring switching times Table 11. Test data Test Input VI tPHL, tPLH [2] tPZH, tPHZ [2] tPZL, tPLZ [2] Load Vis tr, tf S1 position CL RL [1] at fmax other pulse < 2 ns 6 ns 50 pF 1 kΩ open VCC < 2 ns 6 ns 50 pF 1 kΩ VEE VEE < 2 ns 6 ns 50 pF 1 kΩ VCC [1] tr = tf = 6 ns; when measuring fmax, there is no constraint to tr and tf with 50 % duty factor. [2] VI values: For 74HC4051: VI = VCC For 74HCT4051: VI = 3 V 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 21 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer 11.1 Additional dynamic characteristics Table 12. Additional dynamic characteristics Recommended conditions and typical values; GND = 0 V; Tamb = 25 °C; CL = 50 pF. Vis is the input voltage at pins nYn or nZ, whichever is assigned as an input. Vos is the output voltage at pins nYn or nZ, whichever is assigned as an output. Symbol Parameter Conditions Min Typ Max dsin sine-wave distortion fi = 1 kHz; RL = 10 kΩ; see Figure 16 Unit Vis = 4.0 V (p-p); VCC = 2.25 V; VEE = -2.25 V - 0.04 - % Vis = 8.0 V (p-p); VCC = 4.5 V; VEE = -4.5 V - 0.02 - % Vis = 4.0 V (p-p); VCC = 2.25 V; VEE = -2.25 V - 0.12 - % Vis = 8.0 V (p-p); VCC = 4.5 V; VEE = -4.5 V - 0.06 - % fi = 10 kHz; RL = 10 kΩ; see Figure 16 αiso Vct RL = 600 Ω; fi = 1 MHz; see Figure 17 isolation (OFF-state) VCC = 2.25 V; VEE = -2.25 V [1] - -50 - dB VCC = 4.5 V; VEE = -4.5 V [1] - -50 - dB VCC = 4.5 V; VEE = 0 V - 110 - mV VCC = 4.5 V; VEE = -4.5 V - 220 - mV peak-to-peak value; between control and any crosstalk voltage switch; RL = 600 Ω; fi = 1 MHz; E or Sn square wave between VCC and GND; tr = tf = 6 ns; see Figure 18 f(-3dB) RL = 50 Ω; see Figure 19 -3 dB frequency response VCC = 2.25 V; VEE = -2.25 V [2] - 170 - MHz VCC = 4.5 V; VEE = -4.5 V [2] - 180 - MHz [1] Adjust input voltage Vis to 0 dBm level (0 dBm = 1 mW into 600 Ω). [2] Adjust input voltage Vis to 0 dBm level at Vos for 1 MHz (0 dBm = 1 mW into 50 Ω). VCC Sn Vis 10 µF Yn/Z Z/Yn VEE GND Vos RL CL dB 001aan385 Figure 16.  Test circuit for measuring sine-wave distortion 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 22 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer VCC Sn 0.1 µF Vis Yn/Z Z/Yn VEE GND Vos RL CL dB 001aan386 VCC = 4.5 V; GND = 0 V; VEE = -4.5 V; RL = 600 Ω; RS = 1 kΩ. a. Test circuit 001aae332 0 α iso (dB) - 20 - 40 - 60 - 80 - 100 102 10 103 104 105 fi (kHz) 106 b. Isolation (OFF-state) as a function of frequency Figure 17.  Test circuit for measuring isolation (OFF-state) 2RL 2RL VCC Sn, E Vct Yn G 2RL Z VEE GND 2RL oscilloscope 001aan387 Figure 18.  Test circuit for measuring crosstalk between control input and any switch 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 23 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer VCC Sn Vis 10 µF Yn/Z Z/Yn VEE GND Vos RL CL dB 001aan385 VCC = 4.5 V; GND = 0 V; VEE = -4.5 V; RL = 50 Ω; RS = 1 kΩ. a. Test circuit 001aad551 5 Vos (dB) 3 1 -1 -3 -5 10 102 103 104 105 f (kHz) 106 b. Typical frequency response Figure 19.  Test circuit for frequency response 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 24 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer 12 Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Figure 20.  Package outline SOT109-1 (SO16) 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 25 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm D SOT338-1 E A X c y HE v M A Z 9 16 Q A2 A (A 3) A1 pin 1 index θ Lp L 8 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.00 0.55 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT338-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Figure 21.  Package outline SOT338-1 (SSOP16) 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 26 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Figure 22.  Package outline SOT403-1 (TSSOP16) 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 27 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT763-1 16 terminals; body 2.5 x 3.5 x 0.85 mm B D A A E A1 c detail X terminal 1 index area terminal 1 index area C e1 e b 2 y y1 C v M C A B w M C 7 L 1 8 Eh e 16 9 15 10 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 3.6 3.4 2.15 1.85 2.6 2.4 1.15 0.85 0.5 2.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT763-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Figure 23.  Package outline SOT763-1 (DHVQFN16) 74HC_HCT4051 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 28 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer 13 Abbreviations Table 13. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 14 Revision history Table 14. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT4051 v.9 20170926 Product data sheet - 74HC_HCT4051 v.8 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74HC_HCT4051 v.8 20160205 Modifications: • Type numbers 74HC4051N and 74HCT4051N (SOT38-4) removed. 74HC_HCT4051 v.7 20120719 Modifications: • CDM added to features. 74HC_HCT4051 v.6 20111213 Modifications: • Legal pages updated. 74HC_HCT4051 v.5 20110513 74HC_HCT4051 v.4 74HC_HCT4051 v.3 74HC_HCT4051 Product data sheet Product data sheet Product data sheet - 74HC_HCT4051 v.7 - 74HC_HCT4051 v.6 - 74HC_HCT4051 v.5 Product data sheet - 74HC_HCT4051 v.4 20110117 Product data sheet - 74HC_HCT4051 v.3 20051219 Product specification - 74HC_HCT4051_CNV_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 29 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer 15 Legal information 15.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74HC_HCT4051 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 30 / 32 74HC4051; 74HCT4051 Nexperia 8-channel analog multiplexer/demultiplexer Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74HC_HCT4051 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 9 — 26 September 2017 © Nexperia B.V. 2017. All rights reserved. 31 / 32 Nexperia 74HC4051; 74HCT4051 8-channel analog multiplexer/demultiplexer Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 11.1 12 13 14 15 General description ............................................ 1 Features and benefits .........................................1 Applications .........................................................1 Ordering information .......................................... 2 Functional diagram ............................................. 2 Pinning information ............................................ 4 Pinning ............................................................... 4 Pin description ................................................... 4 Function description ...........................................5 Limiting values .................................................... 5 Recommended operating conditions ................ 6 Static characteristics .......................................... 7 Dynamic characteristics ...................................15 Additional dynamic characteristics ...................22 Package outline .................................................25 Abbreviations .................................................... 29 Revision history ................................................ 29 Legal information .............................................. 30 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 26 September 2017 Document identifier: 74HC_HCT4051
74HC4051D,653 价格&库存
很抱歉,暂时无法提供与“74HC4051D,653”相匹配的价格&库存,您可以联系我们找货
74HC4051D,653
  • 1+1.49870
  • 10+1.10860
  • 100+0.95020
  • 1000+0.79190
库存:4366
74HC4051D,653
  • 5+1.48695
  • 50+1.14356
  • 500+0.82634
  • 1000+0.81394
库存:290
