HEF4051BT,653
HEF4051BT,653
    NEXPERIA(安世)
    SOIC-16
    模拟开关芯片 3V~15V 350Ω
HEF4051BT,653 数据手册
HEF4051B 8-channel analog multiplexer/demultiplexer Rev. 12 — 25 March 2016 Product data sheet 1. General description The HEF4051B is an 8-channel analog multiplexer/demultiplexer with three address inputs (S1 to S3), an active LOW enable input (E), eight independent inputs/outputs (Y0 to Y7) and a common input/output (Z). The device contains eight bidirectional analog switches, each with one side connected to an independent input/output (Y0 to Y7) and the other side connected to a common input/output (Z). With E LOW, one of the eight switches is selected (low-impedance ON-state) by S1 to S3. With E HIGH, all switches are in the high-impedance OFF-state, independent of S1 to S3. If break before make is needed, then it is necessary to use the enable input. VDD and VSS are the supply voltage connections for the digital control inputs (S1 to S3, and E). The VDD to VSS range is 3 V to 15 V. The analog inputs/outputs (Y0 to Y7, and Z) can swing between VDD as a positive limit and VEE as a negative limit. VDD  VEE may not exceed 15 V. Unused inputs must be connected to VDD, VSS, or another input. For operation as a digital multiplexer/demultiplexer, VEE is connected to VSS (typically ground). VEE and VSS are the supply voltage connections for the switches. 2. Features and benefits      Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Specified from 40 C to +85 C and 40 C to +125 C Complies with JEDEC standard JESD 13-B 3. Applications  Analog multiplexing and demultiplexing  Digital multiplexing and demultiplexing  Signal gating HEF4051B Nexperia 8-channel analog multiplexer/demultiplexer 4. Ordering information Table 1. Ordering information All types operate from 40 C to +125 C. Type number Package Name Description Version HEF4051BT SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 HEF4051BTS SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 HEF4051BTT TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 5. Functional diagram 9''
HEF4051BT,653 价格&库存
很抱歉,暂时无法提供与“HEF4051BT,653”相匹配的价格&库存,您可以联系我们找货
HEF4051BT,653
  • 5+1.64111
  • 50+1.29380
  • 500+0.95922
  • 1000+0.94483
  • 2500+0.87661
库存:4992
HEF4051BT,653
  • 5+1.80857
  • 50+1.42582
  • 150+1.26177
  • 500+1.05711
  • 2500+0.96606
  • 5000+0.91131
库存:1790
HEF4051BT,653
    HEF4051BT,653
    • 1+1.32000
    • 100+1.00980
    • 1250+0.85470
    • 2500+0.79200
    库存:33
