74HC1G04; 74HCT1G04
Inverter
Rev. 5 — 25 September 2013
Product data sheet
1. General description
The 74HC1G04; 74HCT1G04 is a single inverter. Inputs include clamp diodes that enable
the use of current limiting resistors to interface inputs to voltages in excess of VCC.
2. Features and benefits
Wide supply voltage range from 2.0 V to 6.0 V
Input levels:
For 74HC1G04: CMOS level
For 74HCT1G04: TTL level
Symmetrical output impedance
High noise immunity
Low power dissipation
Balanced propagation delays
ESD protection:
HBM JESD22-A114E exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74HC1G04GW
40 C to +125 C
TSSOP5
plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
40 C to +125 C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
74HCT1G04GW
74HC1G04GV
74HCT1G04GV
74HC1G04; 74HCT1G04
Nexperia
Inverter
4. Marking
Table 2.
Marking codes
Type number
Marking[1]
74HC1G04GW
HC
74HCT1G04GW
TC
74HC1G04GV
H04
74HCT1G04GV
T04
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
2
A
Y
4
1
2
4
Y
A
mna108
Fig 1. Logic symbol
mna110
mna109
Fig 2. IEC logic symbol
Fig 3. Logic diagram
6. Pinning information
6.1 Pinning
74HC1G04
74HCT1G04
n.c.
1
A
2
GND
3
5
VCC
4
Y
001aaf089
Fig 4. Pin configuration
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
n.c.
1
not connected
A
2
data input
GND
3
ground (0 V)
Y
4
data output
VCC
5
supply voltage
74HC_HCT1G04
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 12
74HC1G04; 74HCT1G04
Nexperia
Inverter
7. Functional description
Table 4.
Function table
H = HIGH voltage level; L = LOW voltage level
Input
Output
A
Y
L
H
H
L
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). [1]
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
0.5
+7.0
V
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
mA
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
mA
IO
output current
0.5 V < VO < VCC + 0.5 V
12.5
mA
ICC
supply current
25
mA
IGND
ground current
25
mA
Tstg
storage temperature
65
+150
C
200
mW
total power dissipation
Ptot
Tamb = 40 C to +125 C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
Above 55 C, the value of Ptot derates linearly with 2.5 mW/K.
9. Recommended operating conditions
Table 6.
Symbol Parameter
Conditions
74HC1G04
74HCT1G04
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
40
+25
+125
40
+25
+125
C
t/V
input transition rise
and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
139
139
ns/V
VCC = 6.0 V
83
ns/V
74HC_HCT1G04
Product data sheet
3 of 12
74HC1G04; 74HCT1G04
Nexperia
Inverter
10. Static characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V). All typical values are measured at Tamb = 25 C.
Symbol
Parameter
40 C to +85 C
Conditions
40 C to +125 C
Unit
Min
Typ
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
V
IO = 20 A; VCC = 2.0 V
1.9
2.0
1.9
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
4.4
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
5.9
V
IO = 2.0 mA; VCC = 4.5 V
4.13
4.32
3.7
V
IO = 2.6 mA; VCC = 6.0 V
5.63
5.81
5.2
V
0.1
V
0.1
V
0.1
V
0.15
0.33
0.4
V
0.16
0.33
0.4
V
For type 74HC1G04
VIH
VIL
VOH
VOL
HIGH-level input
voltage
LOW-level input
voltage
HIGH-level output
voltage
LOW-level output
voltage
VI = VIH or VIL
VI = VIH or VIL
II
input leakage current
VI = VCC or GND; VCC = 6.0 V
1.0
1.0
A
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
10
A
CI
input capacitance
1.5
pF
For type 74HCT1G04
VIH
HIGH-level input
voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
V
VIL
LOW-level input
voltage
1.2
0.8
0.8
V
VOH
HIGH-level output
voltage
VI = VIH or VIL
4.4
4.5
4.4
V
4.13
4.32
3.7
V
VOL
II
LOW-level output
voltage
74HC_HCT1G04
Product data sheet
VI = VIH or VIL
0.1
V
0.15
0.33
0.4
V
VI = VCC or GND; VCC = 5.5 V
1.0
1.0
A
4 of 12
74HC1G04; 74HCT1G04
Nexperia
Inverter
Table 7.
Static characteristics …continued
Symbol
Parameter
40 C to +85 C
Conditions
40 C to +125 C
Min
Typ
Max
Min
Max
Unit
ICC
supply current
VCC = 5.5 V
10
A
ICC
additional supply
current
per input; VCC = 4.5 V to 5.5 V;
VI = VCC 2.1 V; IO = 0 A
500
850
A
CI
input capacitance
1.5
pF
11. Dynamic characteristics
Table 8.
GND = 0 V; tr = tf 6.0 ns; All typical values are measured at Tamb = 25 C. For test circuit, see Figure 6
Symbol Parameter
40 C to +85 C
Conditions
40 C to +125 C Unit
Min
Typ
Max
Min
Max
VCC = 2.0 V; CL = 50 pF
25
105
135
ns
VCC = 4.5 V; CL = 50 pF
9
21
27
ns
VCC = 5.0 V; CL = 15 pF
7
ns
8
18
23
ns
16
pF
10
24
27
ns
8
ns
18
pF
For type 74HC1G04
propagation delay
tpd
A to Y; see Figure 5
[1]
VCC = 6.0 V; CL = 50 pF
power dissipation
capacitance
CPD
VI = GND to VCC
[2]
[1]
For type 74HCT1G04
propagation delay
tpd
power dissipation
capacitance
CPD
[1]
[2]
VI = GND to VCC 1.5 V
[2]
tpd is the same as tPLH and tPHL.
CPD is used to determine the dynamic power dissipation PD (W).
PD = CPD VCC2 fi + (CL VCC2 fo) where:
fi = input frequency in MHz
fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
(CL VCC2 fo) = sum of outputs
74HC_HCT1G04
Product data sheet
5 of 12
74HC1G04; 74HCT1G04
Nexperia
Inverter
12. Waveforms
VM
A input
tPHL
tPLH
VM
Y output
mna111
Measurement points are given in Table 9.
Fig 5. The input (A) to output (Y) propagation delays
Table 9.
Measurement points
Type
VI
VM
74HC1G04
GND to VCC
0.5 VCC
74HCT1G04
GND to 03 V
1.3 V
VCC
PULSE
GENERATOR
VI
VO
DUT
RT
CL
mna101
Test data is given in Table 8. Definitions for test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator
CL = Load capacitance including jig and probe capacitance
Fig 6. Load circuitry for switching times
74HC_HCT1G04
Product data sheet
6 of 12
74HC1G04; 74HCT1G04
Nexperia
Inverter
13. Package outline
TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm
E
D
SOT353-1
A
X
c
y
HE
v M A
Z
5
4
A2
A
(A3)
A1
θ
1
Lp
3
L
e
w M
bp
detail X
e1
3 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
e1
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.1
0.8
0.15
0.30
0.15
0.25
0.08
2.25
1.85
1.35
1.15
0.65
1.3
2.25
2.0
0.425
0.46
0.21
0.3
0.1
0.1
0.60
0.15
7°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT353-1
REFERENCES
IEC
JEDEC
JEITA
MO-203
SC-88A
EUROPEAN
PROJECTION
ISSUE DATE
00-09-01
03-02-19
Fig 7. Package outline SOT353-1 (TSSOP5)
74HC_HCT1G04
Product data sheet
7 of 12
74HC1G04; 74HCT1G04
Nexperia
Inverter
Plastic surface-mounted package; 5 leads
SOT753
D
E
B
y
A
X
HE
5
v M A
4
Q
A
A1
c
1
2
3
Lp
detail X
bp
e
w M B
2 mm
scale
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.100
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT753
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-04-16
06-03-16
SC-74A
Fig 8. Package outline SOT753 (SC-74A)
74HC_HCT1G04
Product data sheet
8 of 12
74HC1G04; 74HCT1G04
Nexperia
Inverter
14. Abbreviations
Table 10.
Abbreviations
Acronym
Description
DUT
Device Under Test
TTL
Transistor-Transistor Logic
15. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT1G04 v.5
20130925
Product data sheet
74HC_HCT1G04 v.4
74HC_HCT1G04 v.3
Modifications:
74HC_HCT1G04 v.4
Modifications:
Section 1 “General description” updated.
20070716
Product data sheet
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Package SOT353 changed to SOT353-1 in Table 1 and Figure 7.
Quick Reference Data and Soldering sections removed.
Section 2 “Features and benefits” updated.
74HC_HCT1G04 v.3
20020517
Product specification
74HC_HCT1G04 v.2
74HC_HCT1G04 v.2
20010302
74HC_HCT1G04 v.1
74HC_HCT1G04 v.1
19980831
Preliminary specification
74HC_HCT1G04
Product data sheet
9 of 12
74HC1G04; 74HCT1G04
Nexperia
Inverter
16. Legal information
16.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
16.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
16.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74HC_HCT1G04
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
10 of 12
74HC1G04; 74HCT1G04
Nexperia
Inverter
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
16.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
17. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74HC_HCT1G04
Product data sheet
11 of 12
Nexperia
74HC1G04; 74HCT1G04
Inverter
18. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
14
15
16
16.1
16.2
16.3
16.4
17
18
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional description . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Recommended operating conditions. . . . . . . . 3
Static characteristics. . . . . . . . . . . . . . . . . . . . . 4
Dynamic characteristics . . . . . . . . . . . . . . . . . . 5
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9
Legal information. . . . . . . . . . . . . . . . . . . . . . . 10
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . 11
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Date of release: 25 September 2013
