HEF4050BT,653
HEF4050BT,653
    NEXPERIA(安世)
    SOIC16_150MIL
    类型:缓冲器,非反相 电源电压:3V~15V 输出类型:推挽 低电平输出电流(IOL):20mA 高电平输出电流(IOH):3mA 工作温度:-40℃~+85℃ 6通道非反相缓冲器
HEF4050BT,653 数据手册
HEF4050B Hex non-inverting buffers Rev. 10 — 23 June 2016 Product data sheet 1. General description The HEF4050B provides six non-inverting buffers with high current output capability suitable for driving TTL or high capacitive loads. Since input voltages in excess of the buffers’ supply voltage are permitted, the buffers may also be used to convert logic levels of up to 15 V to standard TTL levels. Their guaranteed fan-out into common bipolar logic elements is shown in Table 3. It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. 2. Features and benefits       Accepts input voltages in excess of the supply voltage Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Specified from 40 C to +85 C Complies with JEDEC standard JESD 13-B 3. Applications  LOCMOS (Local Oxidation CMOS) to DTL/TTL converter  HIGH sink current for driving two TTL loads  HIGH-to-LOW level logic conversion HEF4050B Nexperia Hex non-inverting buffers 4. Ordering information Table 1. Ordering information All types operate from 40 C to +85 C. Type number Package HEF4050BT Name Description Version SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 5. Functional diagram      $ < $ < $ < $ < $ < $ <      LQSXW   $ DDH Fig 1. Logic symbol HEF4050B Product data sheet < 966 DDH DDH Fig 2. Logic diagram for one gate All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 June 2016 Fig 3. Input protection circuit © Nexperia B.V. 2017. All rights reserved 2 of 12 HEF4050B Nexperia Hex non-inverting buffers 6. Pinning information 6.1 Pinning +()% 9''   QF <   < $   $ <   QF $   < <   $ $   < 966   $ DDH Fig 4. Pin configuration 6.2 Pin description Table 2. Pin description Symbol Pin Description VDD 1 supply voltage 1Y to 6Y 2, 4, 6, 10, 12, 15 output 1A to 6A 3, 5, 7, 9, 11, 14, input VSS 8 ground supply voltage n.c. 13, 16 not connected 7. Functional description Table 3. Guaranteed fan-out Driven element Guaranteed fan-out Standard TTL 2 74 LS 9 74 L 16 HEF4050B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 June 2016 © Nexperia B.V. 2017. All rights reserved 3 of 12 HEF4050B Nexperia Hex non-inverting buffers 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDD supply voltage IIK input clamping current VI input voltage IOK output clamping current II/O input/output current Conditions VI < 0.5 V VO < 0.5 V or VO > VDD + 0.5 V Min Max Unit 0.5 +18 V 10 - 0.5 +18 V - 10 mA - 10 mA mA IDD supply current - 50 mA Tstg storage temperature 65 +150 C Tamb ambient temperature 40 +85 C Ptot total power dissipation - 500 mW - 100 mW Tamb 40 C to +85 C [1] SO16 package P [1] power dissipation per output For SO16 package: Ptot derates linearly with 8 mW/K above 70 C. 9. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VDD VI Conditions Min Max Unit supply voltage 3 15 V input voltage 0 15 V Tamb ambient temperature in free air 40 +85 C t/V input transition rise and fall rate VDD = 5 V - 3.75 s/V VDD = 10 V - 0.5 s/V VDD = 15 V - 0.08 s/V 10. Static characteristics Table 6. Static characteristics VSS = 0 V; VI = VSS or VDD unless otherwise specified. Symbol VIH VIL Parameter HIGH-level input voltage LOW-level input voltage HEF4050B Product data sheet Conditions IO < 1 A IO < 1 A Tamb = 25 C Tamb = 85 C Min Max Min Max Min Max 5V 3.5 - 3.5 - 3.5 - V 10 V 7.0 - 7.0 - 7.0 - V 15 V 11.0 - 11.0 - 11.0 - V 5V - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 V VDD Tamb = 40 C All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 June 2016 © Unit Nexperia B.V. 2017. All rights reserved 4 of 12 HEF4050B Nexperia Hex non-inverting buffers Table 6. Static characteristics …continued VSS = 0 V; VI = VSS or VDD unless otherwise specified. Symbol VOH Parameter Conditions HIGH-level output voltage IO < 1 A LOW-level output voltage VOL IOH Tamb = 85 C Unit Max Min Max Min Max 4.95 - 4.95 - 4.95 - 10 V 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 V V 15 V - 0.05 - 0.05 - 0.05 V 5V - 1.7 - 1.4 - 1.1 mA VO = 4.6 V 5V - 0.52 - 0.44 - 0.36 mA VO = 9.5 V 10 V - 1.3 - 1.1 - 0.9 II input leakage current IDD supply current mA VO = 13.5 V 15 V - 3.6 - 3.0 - 2.4 mA VO = 0.4 V 4.75 V 3.5 - 2.9 - 2.3 - mA VO = 0.5 V 10 V 12.0 - 10.0 - 8.0 - mA VO = 1.5 V 15 V 24.0 - 20.0 - 16.0 - mA 15 V - 0.3 - 0.3 - 1.0 A 5V - 4.0 - 4.0 - 30 A 10 V - 8.0 - 8.0 - 60 A 15 V - 16.0 - 16.0 - 120 A - - - 7.5 - - pF IO = 0 A input capacitance CI Tamb = 25 C Min 5V IO < 1 A Tamb = 40 C HIGH-level output current VO = 2.5 V LOW-level output current IOL VDD 11. Dynamic characteristics Table 7. Dynamic characteristics VSS = 0 V; Tamb = 25 C; for test circuit see Figure 6; unless otherwise specified. Symbol tPHL Parameter Conditions HIGH to LOW propagation delay nA to nY; see Figure 5 LOW to HIGH propagation delay nA to nY; see Figure 5 VDD Extrapolation formula Min Typ Max 26 ns + (0.18 ns/pF)CL - 35 70 ns 16 ns + (0.08 ns/pF)CL - 20 35 ns 12 ns + (0.05 ns/pF)CL - 15 30 ns 28 ns + (0.55 ns/pF)CL - 55 110 ns 14 ns + (0.23 ns/pF)CL - 25 55 ns 12 ns + (0.16 ns/pF)CL - 20 40 ns 7 ns + (0.35 ns/pF)CL - 25 50 ns 3 ns + (0.14 ns/pF)CL - 10 20 ns 2 ns + (0.09 ns/pF)CL - 7 14 ns 10 ns + (1.00 ns/pF)CL - 60 120 ns 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns 5V [1] 10 V 15 V tPLH 5V [1] 10 V 15 V HIGH to LOW see Figure 5 output transition time tTHL 5V [1] 10 V 15 V LOW to HIGH see Figure 5 output transition time tTLH [1] 5V [1] Unit The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF). HEF4050B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 June 2016 © Nexperia B.V. 2017. All rights reserved 5 of 12 HEF4050B Nexperia Hex non-inverting buffers Table 8. Dynamic power dissipation PD PD can be calculated from the formulas shown. VSS = 0 V; tr = tf  20 ns; Tamb = 25 C. Symbol PD Parameter dynamic power dissipation VDD Typical formula for PD (W) where: 5V PD = 3800  fi + (fo  CL)  VDD 10 V PD = 11600  fi + (fo  CL)  VDD2 fo = output frequency in MHz, 15 V PD = 65900  fi + (fo  CL)  CL = output load capacitance in pF, 2 fi = input frequency in MHz, VDD2 VDD = supply voltage in V, (fo  CL) = sum of the outputs. 12. Waveforms WU 9, WI  LQSXW 90 9  W3/+ 92+ W3+/  90 RXWSXW 92/  W7/+ W7+/ DDL Measurement points are given in Table 9. VOL and VOH are typical output voltage levels that occur with the output load. Fig 5. Table 9. Input to output propagation delays Measurement points Input Output VM VI VM 0.5VDD 0 V to VDD 0.5VDD HEF4050B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 June 2016 © Nexperia B.V. 2017. All rights reserved 6 of 12 HEF4050B Nexperia Hex non-inverting buffers 9'' * 9, 92 '87 57 &/ DDJ Test data is given in Table 10. Definitions for test circuit: CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. Fig 6. Test circuit for measuring switching times Table 10. Test data Supply voltage Input VDD VI VM tr, tf CL 5 V to 15 V VDD 0.5VI  20 ns 50 pF HEF4050B Product data sheet Load All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 June 2016 © Nexperia B.V. 2017. All rights reserved 7 of 12 HEF4050B Nexperia Hex non-inverting buffers 13. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H Z 0 ES   GHWDLO; PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV         ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG Fig 7. 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Package outline SOT109-1 (SO16) HEF4050B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 June 2016 © Nexperia B.V. 2017. All rights reserved 8 of 12 HEF4050B Nexperia Hex non-inverting buffers 14. Abbreviations Table 11. Abbreviations Acronym Description DTL Diode Transistor Logic DUT Device Under Test LOCMOS Local Oxidation CMOS TTL Transistor-Transistor Logic 15. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes HEF4050B v.10 20160623 Product data sheet - HEF4050B v.9 Modifications: HEF4050B v.9 Modifications: HEF4050B v.8 Modifications: • • Table 4: condition for input clamping current changed (typo corrected). Table 5: maximum value for input voltage changed (typo corrected). 20160324 • - HEF4050B v.8 Type number HEF4050BP (SOT38-4) removed. 20111118 • • Product data sheet Product data sheet - HEF4050B v.7 Table 6: IOH minimum values changed to maximum Table 11: DUT added HEF4050B v.7 20091201 Product data sheet - HEF4050B v.6 HEF4050B v.6 20090723 Product data sheet - HEF4050B v.5 HEF4050B v.5 20081111 Product data sheet - HEF4050B v.4 HEF4050B v.4 20080702 Product data sheet - HEF4050B_CNV v.3 HEF4050B_CNV v.3 19950101 Product specification - HEF4050B_CNV v.2 HEF4050B_CNV v.2 19950101 Product specification - - HEF4050B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 June 2016 © Nexperia B.V. 2017. All rights reserved 9 of 12 HEF4050B Nexperia Hex non-inverting buffers 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. HEF4050B Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 June 2016 © Nexperia B.V. 2017. All rights reserved 10 of 12 HEF4050B Nexperia Hex non-inverting buffers Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com HEF4050B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 June 2016 © Nexperia B.V. 2017. All rights reserved 11 of 12 Nexperia HEF4050B Hex non-inverting buffers 18. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 14 15 16 16.1 16.2 16.3 16.4 17 18 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 4 Dynamic characteristics . . . . . . . . . . . . . . . . . . 5 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9 Legal information. . . . . . . . . . . . . . . . . . . . . . . 10 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 23 June 2016
HEF4050BT,653 价格&库存
很抱歉,暂时无法提供与“HEF4050BT,653”相匹配的价格&库存,您可以联系我们找货
