74HCT245D,653
74HCT245D,653
    NEXPERIA(安世)
    SO-20-300mil
    CAN收发器 4.5V~5.5V
74HCT245D,653 数据手册
74HC245; 74HCT245 Octal bus transceiver; 3-state Rev. 4 — 26 February 2016 Product data sheet 1. General description The 74HC245; 74HCT245 is an 8-bit transceiver with 3-state outputs. The device features an output enable (OE) and send/receive (DIR) for direction control. A HIGH on OE causes the outputs to assume a high-impedance OFF-state. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Complies with JEDEC standard JESD7A  Input levels:  For 74HC245: CMOS level  For 74HCT245: TTL level  Octal bidirectional bus interface  Non-inverting 3-state outputs  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number 74HC245D Package Temperature range Name Description Version 40 C to +125 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 40 C to +125 C SSOP20 plastic shrink small outline package; 20 leads; body width 5.3 mm SOT339-1 40 C to +125 C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 40 C to +125 C DHVQFN20 plastic dual-in-line compatible thermal enhanced very SOT764-1 thin quad flat package; no leads; 20 terminals; body 2.5  4.5  0.85 mm 74HCT245D 74HC245DB 74HCT245DB 74HC245PW 74HCT245PW 74HC245BQ 74HCT245BQ 74HC245; 74HCT245 Nexperia Octal bus transceiver; 3-state 4. Functional diagram  ',5 2(  %   (1 (1                $  $ %   Logic symbol 74HC_HCT245 Product data sheet  PQD PQD Fig 1.   $ %  *  %   $ %    $ %   $ %   $ %   $ Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 4 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 2 of 18 74HC245; 74HCT245 Nexperia Octal bus transceiver; 3-state 5. Pinning information  WHUPLQDO LQGH[DUHD $   2( $   % $   % $   % $   % $    9&& $   2( $   % $  $  $  $   % $   % $   % *1'   % $  $   %  %  % *1'   %  % *1'   %  %  ',5   9&& ',5 5.1 Pinning DDF 7UDQVSDUHQWWRSYLHZ DDF (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Fig 3. Pin configuration SO20 and (T)SSOP20 Fig 4. Pin configuration DHVQFN20 5.2 Pin description Table 2. Pin description Symbol Pin Description DIR 1 direction control A0, A1, A2, A3, A4, A5, A6, A7 2, 3, 4, 5, 6, 7, 8, 9 data input/output GND 10 ground (0 V) B7, B6, B5, B4, B3, B2, B1, B0 11, 12, 13, 14, 15, 16, 17, 18 data input/output OE 19 output enable input (active LOW) VCC 20 supply voltage 74HC_HCT245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 3 of 18 74HC245; 74HCT245 Nexperia Octal bus transceiver; 3-state 6. Functional description 6.1 Function table Table 3. Function table[1] Input Input/output OE DIR An Bn L L A=B input L H input B=A H X Z Z [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit VCC supply voltage 0.5 +7 V IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V - 20 mA IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V - 20 mA IO output current 0.5 V < VO < VCC + 0.5 V - 35 mA ICC supply current - 70 mA IGND ground current 70 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot [1] [1] SO20, SSOP20, TSSOP20 and DHVQFN20 packages For SO20 packages: above 70 C, Ptot derates linearly with 8 mW/K. For SSOP20 and TSSOP20 packages: above 60 C, Ptot derates linearly with 5.5 mW/K. For DHVQFN20 packages: above 60 C, Ptot derates linearly with 4.5 mW/K. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage t/V input transition rise and fall rate Tamb ambient temperature 74HC_HCT245 Product data sheet Conditions 74HC245 74HCT245 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V 0 - VCC 0 - VCC V V 0 - VCC 0 - VCC VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 40 +25 +125 40 +25 +125 All information provided in this document is subject to legal disclaimers. Rev. 4 — 26 February 2016 © C Nexperia B.V. 2017. All rights reserved 4 of 18 74HC245; 74HCT245 Nexperia Octal bus transceiver; 3-state 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V 74HC245 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V HIGH-level VI = VIH or VIL output voltage IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 6.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = 7.8 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V LOW-level VI = VIH or VIL output voltage IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 6.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 7.8 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 - 1.0 - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VCC = 6.0 V; VO = VCC or GND - - 0.5 - 5.0 - 10 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 A CI input capacitance - 3.5 - - - - - pF CI/O input/output capacitance - 10 - - - - - pF 74HC_HCT245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 5 of 18 74HC245; 74HCT245 Nexperia Octal bus transceiver; 3-state Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max 74HCT245 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 20 A 4.4 4.5 - 4.4 - 4.4 - V 3.98 4.32 - 3.84 - 3.7 - V IO = 6 mA VOL LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 20 A - 0 0.1 - 0.1 - 0.1 V IO = 6.0 mA - 0.15 0.26 - 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 0.1 - 1.0 - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VCC = 5.5 V; VO = VCC or GND - - 0.5 - 5.0 - 10 A ICC supply current VI = VCC or GND; VCC = 5.5 V; IO = 0 A - - 8.0 - 80 - 160 A ICC additional VI = VCC  2.1 V; supply current other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A An or Bn inputs - 40 144 - 180 - 196 A OE input - 150 540 - 675 - 735 A DIR input - 90 324 - 405 - 441 A CI input capacitance - 3.5 - - - - - pF CI/O input/output capacitance - 10 - - - - - pF 74HC_HCT245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 6 of 18 74HC245; 74HCT245 Nexperia Octal bus transceiver; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; for load circuit see Figure 7. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ Max Max (85 C) Max (125 C) VCC = 2.0 V - 25 90 115 135 ns VCC = 4.5 V - 9 18 23 27 ns VCC = 5.0 V; CL = 15 pF - 7 - - - ns - 7 15 20 23 ns VCC = 2.0 V - 30 150 190 225 ns VCC = 4.5 V - 11 30 38 45 ns - 9 26 33 38 ns VCC = 2.0 V - 41 150 190 225 ns VCC = 4.5 V - 15 30 38 45 ns - 12 26 33 38 ns VCC = 2.0 V - 14 60 75 90 ns VCC = 4.5 V - 5 12 15 18 ns - 4 10 13 15 ns - 30 - - - pF 74HC245 tpd propagation delay An to Bn or Bn to An; [1] see Figure 5 VCC = 6.0 V ten enable time OE to An or Bn; see Figure 6 [2] VCC = 6.0 V tdis disable time OE to An or Bn; see Figure 6 [3] VCC = 6.0 V tt transition time [4] see Figure 5 VCC = 6.0 V CPD power dissipation capacitance 74HC_HCT245 Product data sheet per buffer; VI = GND to VCC [5] All information provided in this document is subject to legal disclaimers. Rev. 4 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 7 of 18 74HC245; 74HCT245 Nexperia Octal bus transceiver; 3-state Table 7. Dynamic characteristics …continued GND = 0 V; for load circuit see Figure 7. Symbol Parameter 25 C Conditions Min 40 C to +125 C Unit Typ Max Max (85 C) Max (125 C) 74HCT245 [1] propagation delay An to Bn or Bn to An; tpd see Figure 5 enable time ten disable time tdis VCC = 4.5 V - 12 22 28 33 ns VCC = 5.0 V; CL = 15 pF - 10 - - - ns OE to An or Bn; see Figure 6 [2] - 16 30 38 45 ns OE to An or Bn; see Figure 6 [3] - 16 30 38 45 ns - 5 12 15 18 ns - 30 - - - pF tt transition time VCC = 4.5 V; see Figure 5 [4] CPD power dissipation capacitance per buffer; VI = GND to VCC  1.5 V [5] [1] tpd is the same as tPHL and tPLH. [2] ten is the same as tPZH and tPZL. [3] tdis is the same as tPHZ and tPLZ. [4] tt is the same as tTHL and tTLH. [5] CPD is used to determine the dynamic power dissipation (PD in W): PD = CPD  VCC2  fi  N +  (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching;  (CL  VCC2  fo) = sum of outputs. 11. Waveforms 9, $Q%QLQSXW 90 90 *1' W 3+/ W 3/+ 92+ %Q$QRXWSXW  90 90  92/ W 7+/ W 7/+ DDF Measurement points are given in Table 8. VOL and VOH are typical voltage output drop that occur with the output load. Fig 5. Input (An, Bn) to output (Bn, An) propagation delays and output transition times 74HC_HCT245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 8 of 18 74HC245; 74HCT245 Nexperia Octal bus transceiver; 3-state WU 9, WI  2(LQSXW 90 *1'  W3/= RXWSXW W3=/ 9&& /2:WR2)) 2))WR/2: 90  92/ W3+= RXWSXW 92+ W3=+  +,*+WR2)) 2))WR+,*+ *1' 90 RXWSXWV HQDEOHG RXWSXWV HQDEOHG RXWSXWV GLVDEOHG DDF Measurement points are given in Table 8. VOL and VOH are typical voltage output drop that occur with the output load. Fig 6. 3-state output enable and disable times Table 8. Measurement points Type Input Output VM VM 74HC245 0.5VCC 0.5VCC 74HCT245 1.3 V 1.3 V 74HC_HCT245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 9 of 18 74HC245; 74HCT245 Nexperia Octal bus transceiver; 3-state 9, W:  QHJDWLYH SXOVH 90 9 WI WU WU WI 9,  SRVLWLYH SXOVH 9 90  90 90  W: 9&& 9&& * 9, 92 5/ 6 RSHQ '87 &/ 57 DDG Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig 7. Test circuit for measuring switching times Table 9. Test data Type Input VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74HC245 VCC 6 ns 15 pF, 50 pF 1 k open GND VCC 74HCT245 3V 6 ns 15 pF, 50 pF 1 k open GND VCC 74HC_HCT245 Product data sheet Load S1 position All information provided in this document is subject to legal disclaimers. Rev. 4 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 10 of 18 74HC245; 74HCT245 Nexperia Octal bus transceiver; 3-state 12. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' $ ( ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S /   H ES GHWDLO; Z 0   PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ PP                                           LQFKHV         =       ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 Fig 8. -(,7$ (8523($1 352-(&7,21 ,668('$7(   Package outline SOT163-1 (SO20) 74HC_HCT245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 11 of 18 74HC245; 74HCT245 Nexperia Octal bus transceiver; 3-state 6623SODVWLFVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F +( \ Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S /   Z 0 ES H GHWDLO;   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 Fig 9. 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Package outline SOT339-1 (SSOP20) 74HC_HCT245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 12 of 18 74HC245; 74HCT245 Nexperia Octal bus transceiver; 3-state 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F +( \ Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 10. Package outline SOT360-1 (TSSOP20) 74HC_HCT245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 13 of 18 74HC245; 74HCT245 Nexperia Octal bus transceiver; 3-state '+94)1SODVWLFGXDOLQOLQHFRPSDWLEOHWKHUPDOHQKDQFHGYHU\WKLQTXDGIODWSDFNDJHQROHDGV WHUPLQDOVERG\[[PP % ' 627 $ $ $ ( F GHWDLO; WHUPLQDO LQGH[DUHD WHUPLQDO LQGH[DUHD H & H E   Y Z & $ % & \ & \ /   (K H     ; 'K   PP VFDOH 'LPHQVLRQV PPDUHWKHRULJLQDOGLPHQVLRQV 8QLW $  $ E PD[    QRP    PLQ    PP F '  'K (  (K H H / Y                    Z \   \  1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 5HIHUHQFHV 2XWOLQH YHUVLRQ ,(& -('(& -(,7$ 627  02  VRWBSR (XURSHDQ SURMHFWLRQ ,VVXHGDWH   Fig 11. Package outline SOT764-1 (DHVQFN20) 74HC_HCT245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 14 of 18 74HC245; 74HCT245 Nexperia Octal bus transceiver; 3-state 13. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT245 v.4 20160226 Product data sheet - Modifications: 74HC_HCT245 v.3 Modifications: 74HC_HCT245_CNV v.2 74HC_HCT245 Product data sheet • 74HC_HCT245 v.3 Type numbers 74HC245N and 74HCT245N (SOT146-1) removed. 20050131 Product data sheet - 74HC_HCT245_CNV v.2 • The format of this data sheet is redesigned to comply with the new presentation and information standard of Philips Semiconductors • Section 3 “Ordering information”, Section 5 “Pinning information” and Section 12 “Package outline” are modified to include the DHVQFN20 package. 19930930 Product specification - All information provided in this document is subject to legal disclaimers. Rev. 4 — 26 February 2016 - © Nexperia B.V. 2017. All rights reserved 15 of 18 74HC245; 74HCT245 Nexperia Octal bus transceiver; 3-state 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT245 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 4 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 16 of 18 74HC245; 74HCT245 Nexperia Octal bus transceiver; 3-state Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC_HCT245 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 26 February 2016 © Nexperia B.V. 2017. All rights reserved 17 of 18 Nexperia 74HC245; 74HCT245 Octal bus transceiver; 3-state 17. Contents 1 2 3 4 5 5.1 5.2 6 6.1 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Function table . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 15 Legal information. . . . . . . . . . . . . . . . . . . . . . . 16 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 16 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Contact information. . . . . . . . . . . . . . . . . . . . . 17 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 26 February 2016
74HCT245D,653 价格&库存
很抱歉,暂时无法提供与“74HCT245D,653”相匹配的价格&库存,您可以联系我们找货
74HCT245D,653
  • 1+1.91400
  • 100+1.47400
  • 1000+1.27600
  • 2000+1.21000
库存:5
74HCT245D,653
  • 1+2.52840
  • 10+1.97960
  • 30+1.75420
库存:59
