74HC299PW,112
74HC299PW,112
    NEXPERIA(安世)
    TSSOP-20
    IC UNIV SHIFT REGISTER 20TSSOP
74HC299PW,112 数据手册
74HC299; 74HCT299 8-bit universal shift register; 3-state Rev. 03 — 28 July 2008 Product data sheet 1. General description The 74HC299; 74HCT299 are high-speed Si-gate CMOS devices which are pin-compatible with Low-power Schottky TTL (LSTTL) devices. They are specified in compliance with JEDEC standard no. 7A. The 74HC299; 74HCT299 contain eight edge-triggered D-type flip-flops and the interstage logic necessary to perform synchronous shift-right, shift-left, parallel load and hold operations. An operation is determined by the mode select inputs S0 and S1, as shown in Table 3. Pins I/O0 to I/O7 are flip-flop 3-state buffer outputs which allow them to operate as data inputs in parallel load mode. The serial outputs Q0 and Q7 are used for expansion in serial shifting of longer words. A LOW signal on the asynchronous master reset input MR overrides the Sn and clock CP inputs and resets the flip-flops. All other state changes are initiated by the rising edge of the clock pulse. Inputs can change when the clock is in either state, provided that the recommended set-up and hold times are observed. A HIGH signal on the 3-state output enable inputs OE1 or OE2 disables the 3-state buffers and the I/On outputs are set to the high-impedance OFF-state. In this condition, the shift, hold, load and reset operations still occur when preparing for a parallel load operation. The 3-state buffers are also disabled by HIGH signals on both S0 and S1. 2. Features n Multiplexed inputs/outputs provide improved bit density n Four operating modes: u Shift left u Shift right u Hold (store) u Load data n Operates with output enable or at high-impedance OFF-state (Z) n 3-state outputs drive bus lines directly n Cascadable for n-bit word lengths n ESD protection: u HBM JESD22-A114E exceeds 2000 V u MM JESD22-A115-A exceeds 200 V n Specified from −40 °C to +85 °C and from −40 °C to +125 °C 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74HC299D −40 °C to +125 °C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 74HC299DB −40 °C to +125 °C SSOP20 plastic shrink small outline package; 20 leads; body width 5.3 mm SOT339-1 SOT146-1 74HC299 74HC299N −40 °C to +125 °C DIP20 plastic dual in-line package; 20 leads (300 mil) 74HC299PW −40 °C to +125 °C TSSOP20 plastic thin shrink small outline package; 20 leads; SOT360-1 body width 4.4 mm 74HCT299D −40 °C to +125 °C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 74HCT299DB −40 °C to +125 °C SSOP20 plastic shrink small outline package; 20 leads; body width 5.3 mm SOT339-1 SOT146-1 74HCT299 74HCT299N −40 °C to +125 °C DIP20 plastic dual in-line package; 20 leads (300 mil) 74HCT299PW −40 °C to +125 °C TSSOP20 plastic thin shrink small outline package; 20 leads; SOT360-1 body width 4.4 mm 4. Functional diagram 1 11 12 9 8 2 3 19 S0 DSR S1 DSL 18 CP 8-BIT SHIFT REGISTER MR Q7 Q0 17 OE1 INPUT/3-STATE OUTPUT CIRCUITRY OE2 I/O0 I/O1 I/O2 I/O3 I/O4 I/O5 I/O6 I/O7 7 Fig 1. 13 6 5 15 4 16 001aai460 Functional diagram 74HC_HCT299_3 Product data sheet 14 © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 2 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state 9 2 3 1 19 12 1 S0 I/O0 7 19 S1 I/O1 13 11 DSR I/O2 6 18 DSL I/O3 14 I/O4 5 12 CP I/O5 15 9 MR I/O6 4 I/O7 16 Q0 8 2 3 OE Q7 11 7 13 R & 0 0 M 3 1 C4/1 /2 1, 4D 3, 4D 6, 5 Logic symbol 8 6 14 5 15 4 16 18 17 3, 4D 7, 5 2, 4D Z7 17 001aai459 Fig 3. IEC logic symbol 74HC_HCT299_3 Product data sheet Z6 3, 4D 5 001aai458 Fig 2. SRG8 3EN5 © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 3 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state DSR S0 D S1 Q CP FF0 RD I/O0 CP Q0 D OE1 Q CP FF1 RD OE2 I/O1 D Q CP FF2 RD I/O2 D Q CP FF3 RD I/O3 D Q CP FF4 RD I/O4 D Q CP FF5 RD I/O5 D Q CP FF6 RD I/O6 DSL D Q CP FF7 RD Q7 001aai461 MR Fig 4. I/O7 Logic diagram 74HC_HCT299_3 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 4 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state 5. Pinning information 5.1 Pinning 74HC299 74HCT299 74HC299 74HCT299 S0 1 20 VCC OE1 2 19 S1 OE2 3 18 DSL I/O6 4 17 Q7 S0 1 20 VCC OE1 2 19 S1 OE2 3 18 DSL I/O4 5 16 I/O7 I/O6 4 17 Q7 I/O2 6 15 I/O5 I/O4 5 16 I/O7 I/O2 6 15 I/O5 I/O0 7 14 I/O3 I/O0 7 14 I/O3 Q0 8 13 I/O1 Q0 8 13 I/O1 MR 9 12 CP MR 9 12 CP GND 10 GND 10 11 DSR 001aai511 Fig 5. 11 DSR 001aai457 Pin configuration (SO20 and (T)SSOP20) Fig 6. Pin configuration (DIP20) 5.2 Pin description Table 2. Pin description Symbol Pin Description S0 1 mode select input OE1 2 3-state output enable input (active LOW) OE2 3 3-state output enable input (active LOW) I/O6 4 parallel data input or 3-state parallel output (bus driver) I/O4 5 parallel data input or 3-state parallel output (bus driver) I/O2 6 parallel data input or 3-state parallel output (bus driver) I/O0 7 parallel data input or 3-state parallel output (bus driver) Q0 8 serial output (standard output) MR 9 asynchronous master reset input (active LOW) GND 10 ground (0 V) DSR 11 serial data shift-right input CP 12 clock input (LOW to HIGH, edge-triggered) I/O1 13 parallel data input or 3-state parallel output (bus driver) I/O3 14 parallel data input or 3-state parallel output (bus driver) I/O5 15 parallel data input or 3-state parallel output (bus driver) I/O7 16 parallel data input or 3-state parallel output (bus driver) Q7 17 serial output (standard output) 74HC_HCT299_3 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 5 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state Table 2. Pin description …continued Symbol Pin Description DSL 18 serial data shift-left input S1 19 mode select input VCC 20 positive supply voltage 6. Functional description Table 3. Function table[1] Input Response MR S1 S0 CP L X X X asynchronous reset; Q0 to Q7 = LOW H H H ↑ parallel load; I/On → Qn H L H ↑ shift right; DSR → Q0, Q0 → Q1, etc. H H L ↑ shift left; DSL → Q7, Q7 → Q6, etc. H L L X hold [1] H = HIGH voltage level; L = LOW voltage level; ↑ = LOW to HIGH CP transition; X = don’t care. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit −0.5 +7 V - ±20 mA - ±20 mA standard outputs - ±25 mA bus driver outputs - ±35 mA standard outputs - 50 mA bus driver outputs - 70 mA standard outputs −50 - mA bus driver outputs −70 - mA Tstg storage temperature −65 +150 °C Ptot total power dissipation IIK input clamping current VI < −0.5 V or VI > VCC + 0.5 V [1] IOK output clamping current VO < −0.5 V or VO > VCC + 0.5 V [1] IO output current −0.5 V < VO < VCC + 0.5 V supply current ICC IGND [1] ground current Tamb = −40 °C to +125 °C DIP20 package [2] - 750 mW SO20 package [3] - 500 mW (T)SSOP20 package [4] - 500 mW The input and output voltage ratings may be exceeded if the input and output current ratings are observed. 74HC_HCT299_3 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 6 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state [2] Ptot derates linearly at 12 mW/K above 70 °C. [3] Ptot derates linearly at 8 mW/K above 70 °C. [4] Ptot derates linearly at 5.5 mW/K above 60 °C. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74HC299 74HCT299 Unit Min Typ Max Min Typ Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature −40 - +125 −40 - +125 °C ∆t/∆V input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 1.39 ns/V VCC = 6.0 V - - 83 - - - ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V 74HC299 VIH VIL HIGH-level input voltage LOW-level input voltage 74HC_HCT299_3 Product data sheet V © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 7 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol VOH Parameter HIGH-level output voltage 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ Max Min Max Min Max IO = −20 µA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = −20 µA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = −20 µA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = −4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = −5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = −6.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = −7.8 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 µA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 µA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 µA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V IO = 6.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 7.8 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V µA VI = VIH or VIL all outputs standard outputs bus driver outputs VOL LOW-level output voltage VI = VIH or VIL all outputs standard outputs bus driver outputs II input leakage current VI = VCC or GND; VCC = 6.0 V - - ±0.1 - ±1.0 - ±1.0 IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - ±0.5 - ±5.0 - ±10.0 µA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 µA CI input capacitance - 3.5 - - - - - pF CI/O input/output capacitance - 10 - - - - - pF CPD power dissipation capacitance - 120 - - - - - pF 2.0 1.6 - 2.0 - 2.0 - V [1] per package 74HCT299 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 74HC_HCT299_3 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 8 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ Max Min Max Min Max - 1.2 0.8 - 0.8 - 0.8 V 4.4 4.5 - 4.4 - 4.4 - V 3.98 4.32 - 3.84 - 3.7 - V 3.98 4.32 - 3.84 - 3.7 - V - 0 0.1 - 0.1 - 0.1 V - 0.15 0.26 - 0.33 - 0.4 V IO = 6.0 mA - 0.16 0.26 - 0.33 - 0.4 V µA VIL LOW-level input voltage VCC = 4.5 V to 5.5 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V all outputs IO = −20 µA standard outputs IO = −4.0 mA bus driver outputs IO = −6.0 mA LOW-level output voltage VOL VI = VIH or VIL; VCC = 4.5 V all outputs IO = 20 µA standard outputs IO = 4.0 mA bus driver outputs II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±0.1 - ±1.0 - ±1.0 IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND per input pin; other inputs at VCC or GND; IO = 0 A; VCC = 5.5 V - - ±0.5 - ±5.0 - ±10.0 µA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 8.0 - 80 - ∆ICC additional supply current per input pin; VI = VCC − 2.1 V; other inputs at VCC or GND; IO = 0 A; VCC = 4.5 V to 5.5 V I/On, DSR, DSL, MR and S1 - 25 90 - 112.5 - CP, S0 - 60 216 - 270 - 294 OEn 160 µA 122.5 µA µA - 30 108 - 135 - 147 µA CI input capacitance - 3.5 - - - - - pF CI/O input/output capacitance - 10 - - - - - pF CPD power dissipation capacitance - 125 - - - - - pF [1] per package [1] CPD is used to determine the dynamic power dissipation (PD in µW). PD = CPD × VCC2 × fi + ∑(CL × VCC2 × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; 74HC_HCT299_3 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 9 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state ∑(CL × VCC2 × fo) = sum of outputs. CL = output load capacitance in pF; VCC = supply voltage in V; VI = GND to VCC for 74HC299; VI = GND to (VCC − 1.5 V) for 74HCT299. 10. Dynamic characteristics Table 7. Dynamic characteristics GND (ground = 0 V); for test circuit, see Figure 11. Symbol Parameter 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 66 200 - 250 - 300 ns VCC = 4.5 V - 24 40 - 50 - 60 ns VCC = 5.0 V; CL = 15 pF - 20 - - - - - ns VCC = 6.0 V - 19 34 - 43 - 51 ns - 66 200 - 250 - 300 ns VCC = 4.5 V - 24 40 - 50 - 60 ns VCC = 5.0 V; CL = 15 pF - 20 - - - - - ns - 19 34 - 43 - 51 ns VCC = 2.0 V - 66 200 - 250 - 300 ns VCC = 4.5 V - 24 40 - 50 - 60 ns VCC = 5.0 V; CL = 15 pF - 20 - - - - - ns - 19 34 - 43 - 51 ns VCC = 2.0 V - 14 60 - 75 - 90 ns VCC = 4.5 V - 5 12 - 15 - 18 ns VCC = 6.0 V - 4 10 - 13 - 15 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns 74HC299 tpd propagation delay CP to Q0, Q7; see Figure 7 [1] CP to I/On; see Figure 7 VCC = 2.0 V VCC = 6.0 V MR to Q0, Q7 or I/On; see Figure 8 [2] VCC = 6.0 V tt transition time bus driver (I/On); see Figure 7 [3] standard (Q0, Q7); see Figure 7 74HC_HCT299_3 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 10 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state Table 7. Dynamic characteristics …continued GND (ground = 0 V); for test circuit, see Figure 11. Symbol tW Parameter pulse width 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 80 17 - 100 - 120 - ns VCC = 4.5 V 16 6 - 20 - 24 - ns VCC = 6.0 V 14 5 - 17 - 20 - ns VCC = 2.0 V 80 19 - 100 - 120 - ns VCC = 4.5 V 16 7 - 20 - 24 - ns 14 6 - 17 - 20 - ns VCC = 2.0 V - 50 155 - 195 - 235 ns VCC = 4.5 V - 18 31 - 39 - 47 ns VCC = 6.0 V - 14 26 - 33 - 40 ns VCC = 2.0 V - 41 130 - 165 - 195 ns VCC = 4.5 V - 15 26 - 33 - 39 ns - 12 22 - 28 - 33 ns VCC = 2.0 V - 66 185 - 230 - 280 ns VCC = 4.5 V - 24 37 - 46 - 56 ns VCC = 6.0 V - 19 31 - 39 - 48 ns VCC = 2.0 V - 55 155 - 195 - 235 ns VCC = 4.5 V - 20 31 - 39 - 47 ns VCC = 6.0 V - 16 26 - 33 - 40 ns VCC = 2.0 V 5 −14 - 5 - 5 - ns VCC = 4.5 V 5 −5 - 5 - 5 - ns VCC = 6.0 V 5 −4 - 5 - 5 - ns CP HIGH or LOW; see Figure 7 MR LOW; see Figure 8 VCC = 6.0 V tPZH tPZL OFF-state to HIGH propagation delay OFF-state to LOW propagation delay OEn to I/On; see Figure 10 [4] OEn to I/On; see Figure 10 VCC = 6.0 V tPHZ tPLZ trec HIGH to OFF-state propagation delay LOW to OFF-state propagation delay recovery time OEn to I/On; see Figure 10 [5] OEn to I/On; see Figure 10 MR to CP; see Figure 8 74HC_HCT299_3 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 11 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state Table 7. Dynamic characteristics …continued GND (ground = 0 V); for test circuit, see Figure 11. Symbol tsu Parameter set-up time 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 100 33 - 125 - 150 - ns VCC = 4.5 V 20 12 - 25 - 30 - ns VCC = 6.0 V 17 10 - 21 - 26 - ns VCC = 2.0 V 100 33 - 125 - 150 - ns VCC = 4.5 V 20 12 - 25 - 30 - ns VCC = 6.0 V 17 10 - 21 - 26 - ns VCC = 2.0 V 125 39 - 155 - 190 - ns VCC = 4.5 V 25 14 - 31 - 38 - ns VCC = 6.0 V 21 11 - 26 - 32 - ns VCC = 2.0 V 0 −14 - 0 - 0 - ns VCC = 4.5 V 0 −5 - 0 - 0 - ns VCC = 6.0 V 0 −4 - 0 - 0 - ns VCC = 2.0 V 0 −28 - 0 - 0 - ns VCC = 4.5 V 0 −10 - 0 - 0 - ns VCC = 6.0 V 0 −8 - 0 - 0 - ns VCC = 2.0 V 5.0 15 - 4.0 - 3.4 - MHz VCC = 4.5 V 25 45 - 20 - 17 - MHz DSR, DSL to CP; see Figure 7 S0, S1 to CP; see Figure 9 I/On to CP; see Figure 7 th hold time I/On, DSR, DSL to CP; see Figure 7 S0, S1 to CP; see Figure 9 fmax maximum frequency CP input; see Figure 7 VCC = 5.0 V; CL = 15 pF - 50 - - - - - MHz 29 54 - 24 - 20 - MHz VCC = 4.5 V - 22 37 - 46 - 56 ns VCC = 5.0 V; CL = 15 pF - 19 - - - - - ns - 22 37 - 46 - 56 ns - 19 - - - - - ns VCC = 4.5 V - 27 46 - 58 - 69 ns VCC = 5.0 V; CL = 15 pF - 23 - - - - - ns VCC = 6.0 V 74HCT299 tpd propagation delay CP to Q0, Q7; see Figure 7 [1] CP to I/On; see Figure 7 VCC = 4.5 V VCC = 5.0 V; CL = 15 pF MR to Q0, Q7 or I/On; see Figure 8 [2] 74HC_HCT299_3 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 12 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state Table 7. Dynamic characteristics …continued GND (ground = 0 V); for test circuit, see Figure 11. Symbol tt Parameter transition time 25 °C Conditions bus driver (I/On); see Figure 7 −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ Max Min Max Min Max - 5 12 - 15 - 18 ns - 7 15 - 19 - 22 ns 20 10 - 25 - 30 - ns 20 11 - 25 - 30 - ns - 19 30 - 38 - 45 ns - 24 37 - 46 - 56 ns - 20 32 - 40 - 48 ns 10 2 - 9 - 11 - ns 25 14 - 31 - 38 - ns 32 18 - 40 - 48 - ns 0 −11 - 0 - 0 - ns 0 −17 - 0 - 0 - ns 25 42 - 20 - 17 - MHz - 46 - - - - - MHz [3] VCC = 4.5 V standard (Q0, Q7); see Figure 7 VCC = 4.5 V pulse width tW clock HIGH or LOW; see Figure 7 VCC = 4.5 V master reset LOW; see Figure 8 VCC = 4.5 V enable time ten OEn to I/On; see Figure 10 [4] VCC = 4.5 V tPHZ tPLZ trec HIGH to OFF-state propagation delay OEn to I/On; see Figure 10 LOW to OFF-state propagation delay OEn to I/On; see Figure 10 recovery time MR to CP; see Figure 8 VCC = 4.5 V VCC = 4.5 V VCC = 4.5 V set-up time tsu [5] I/On, DSR, DSL to CP; see Figure 7 VCC = 4.5 V S0, S1 to CP; see Figure 9 VCC = 4.5 V hold time th I/On, DSR, DSL to CP; see Figure 7 VCC = 4.5 V S0, S1 to CP; see Figure 9 VCC = 4.5 V maximum frequency fmax CP input; see Figure 7 VCC = 4.5 V VCC = 5.0 V; CL = 15 pF [1] tpd is the same as tPHL and tPLH. [2] tpd is the same as tPHL. [3] tt is the same as tTHL and tTLH. [4] ten is the same as tPZH and tPZL. [5] tdis is the same as tPHZ and tPLZ. 74HC_HCT299_3 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 13 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state [6] CPD is used to determine the dynamic power dissipation (PD in µW). PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; Σ(CL × VCC2 × fo) = sum of outputs; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching. 11. Waveforms VI I/On, DSR, DSL inputs VM GND th th tsu tsu 1/fmax VI CP input VM GND tW tPHL tPLH VOH I/On, Q0, Q7 outputs VM VOL tTHL tTLH 001aai462 The shaded areas indicate when the input is permitted to change for predictable output performance. Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 7. Clock pulse to outputs I/On, Q0, Q7 propagation delays, the clock pulse width, the I/On, DSR and DSL to clock pulse set-up and hold times, the output transition times and the maximum clock frequency 74HC_HCT299_3 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 14 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state VI VM MR input GND tW trec VI VM CP input GND tPHL VOH I/On, Q0, Q7 outputs VOL VM 001aai463 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 8. The master reset pulse width (LOW), the master reset to outputs I/On, Q0, Q7 propagation delays and the master reset to clock pulse removal time VI I/On, DSR, DSL, Sn inputs VM GND tsu th tsu th VI CP input VM GND 001aai464 Measurement points are given in Table 8. Fig 9. Set-up and hold times from the mode control inputs S0, S1 to the clock pulse 74HC_HCT299_3 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 15 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state tr VI tf 90 % OEn input VM GND 10 % tPLZ VOH I/On output LOW to OFF OFF to LOW VOL tPZL VM 10 % tPZH tPHZ VOH I/On output HIGH to OFF OFF to HIGH VOL 90 % VM outputs enabled outputs disabled outputs enabled 001aai465 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 10. 3-state enable and disable times for OEn inputs Table 8. Measurement points Type Input Output VI VM VM 74HC299 VCC 0.5VCC 0.5VCC 74HCT299 3V 1.3 V 1.3 V VCC PULSE GENERATOR VI VCC VO RL = 1 kΩ RT S1 open DUT CL 50 pF 001aai466 Test data is given in Table 9. Definitions for test circuit: DUT = Device Under Test. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch Fig 11. Test circuit for measuring switching times 74HC_HCT299_3 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 16 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state Table 9. Test data Type Input Load S1 position VI tr, tf CL RL tPHL, tPLH 74HC299 VCC 6 ns 15 pF, 50 pF 1 kΩ open 74HCT299 3V 6 ns 15 pF, 50 pF 1 kΩ open 74HC_HCT299_3 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 17 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state 12. Package outline SO20: plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 D E A X c HE y v M A Z 20 11 Q A2 A (A 3) A1 pin 1 index θ Lp L 10 1 e detail X w M bp 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 13.0 12.6 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.01 0.019 0.013 0.014 0.009 0.51 0.49 0.30 0.29 0.05 0.419 0.043 0.055 0.394 0.016 inches 0.1 0.012 0.096 0.004 0.089 0.043 0.039 0.01 0.01 Z (1) 0.9 0.4 0.035 0.004 0.016 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT163-1 075E04 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 12. Package outline SOT163-1 (SO20) 74HC_HCT299_3 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 18 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state SSOP20: plastic shrink small outline package; 20 leads; body width 5.3 mm D SOT339-1 E A X c HE y v M A Z 20 11 Q A2 A (A 3) A1 pin 1 index θ Lp L 1 10 w M bp e detail X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 7.4 7.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 0.9 0.5 8 o 0 o Note 1. Plastic or metal protrusions of 0.2 mm maximum per side are not included. OUTLINE VERSION SOT339-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Fig 13. Package outline SOT339-1 (SSOP20) 74HC_HCT299_3 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 19 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state DIP20: plastic dual in-line package; 20 leads (300 mil) SOT146-1 ME seating plane D A2 A A1 L c e Z b1 w M (e 1) b MH 11 20 pin 1 index E 1 10 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 min. A2 max. b b1 c mm 4.2 0.51 3.2 1.73 1.30 0.53 0.38 0.36 0.23 26.92 26.54 inches 0.17 0.02 0.13 0.068 0.051 0.021 0.015 0.014 0.009 1.060 1.045 D e e1 L ME MH w Z (1) max. 6.40 6.22 2.54 7.62 3.60 3.05 8.25 7.80 10.0 8.3 0.254 2 0.25 0.24 0.1 0.3 0.14 0.12 0.32 0.31 0.39 0.33 0.01 0.078 (1) E (1) Note 1. Plastic or metal protrusions of 0.25 mm (0.01 inch) maximum per side are not included. OUTLINE VERSION SOT146-1 REFERENCES IEC JEDEC JEITA MS-001 SC-603 EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-13 Fig 14. Package outline SOT146-1 (DIP20) 74HC_HCT299_3 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 20 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 E D A X c HE y v M A Z 11 20 Q A2 (A 3) A1 pin 1 index A θ Lp L 1 10 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 6.6 6.4 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8 o 0 o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT360-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Fig 15. Package outline SOT360-1 (TSSOP20) 74HC_HCT299_3 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 21 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state 13. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT299_3 20080728 Product data sheet - 74HC_HCT299_CNV_2 Modifications: 74HC_HCT299_CNV_2 • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • • • • Legal texts have been adapted to the new company name where appropriate. Section 3: Ordering information added Section 12: Package outline drawings added Section 9 “Static characteristics”: Family data added Section 11 “Waveforms”: Test circuit added 19970828 Product specification 74HC_HCT299_3 Product data sheet - - © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 22 of 24 74HC299; 74HCT299 NXP Semiconductors 8-bit universal shift register; 3-state 14. Legal information 14.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 14.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 15. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com 74HC_HCT299_3 Product data sheet © NXP B.V. 2008. All rights reserved. Rev. 03 — 28 July 2008 23 of 24 NXP Semiconductors 74HC299; 74HCT299 8-bit universal shift register; 3-state 16. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 14.1 14.2 14.3 14.4 15 16 General description . . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 5 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 5 Functional description . . . . . . . . . . . . . . . . . . . 6 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 6 Recommended operating conditions. . . . . . . . 7 Static characteristics. . . . . . . . . . . . . . . . . . . . . 7 Dynamic characteristics . . . . . . . . . . . . . . . . . 10 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 18 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 22 Legal information. . . . . . . . . . . . . . . . . . . . . . . 23 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 23 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 23 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 23 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 23 Contact information. . . . . . . . . . . . . . . . . . . . . 23 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2008. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 28 July 2008 Document identifier: 74HC_HCT299_3
74HC299PW,112 价格&库存
很抱歉,暂时无法提供与“74HC299PW,112”相匹配的价格&库存,您可以联系我们找货
74HC299PW,112
  • 1875+5.058281875+0.65418
