10511
10511
    DESCO
    LENS ARRAY 20MM TRPL FROST NARR
10511 数据手册
DESCO INDUSTRIES, INC. TECHNICAL BULLETIN TB-7042 Statguard® Static Dissipative Floor Finish Application Instructions Made in the United States of America the enhanced floor tile limits charge generation, for example, due to a person walking across the floor. Generally accepted industrial stripping and floor finish application procedures are to be followed as outlined on pages 2 and 3 in this technical bulletin. Note: to avoid contamination finish mop and bucket should be dedicated to Statguard® Floor Finish use only. NOTE: Statguard® Static Dissipative Floor Care products do not have a set life span. The chemicals are not known to degrade over time when stored at the proper temperature conditions as stated in the Safety Data Sheet. We also recommend that these products be stored in their original containers and be sealed when not in use. Figure 1. Statguard® Static Dissipative Floor Finish Description Statguard® Static Dissipative Floor Finish is a cross linked polymer used to convert hard non-ESD floors to ESD protective flooring and for use in protecting and enhancing ESD permanent flooring (vinyl, VCT, rubber and other flooring types*). It creates a dissipative (1 x 106 to < 1 x 1010 ohms per ANSI/ESD STM7.1 and ESD TR53) and Low Tribocharging ( 8,400 mg/kg LD50 = 1,920 - 9,050 mg/kg SECTION 12 — ECOLOGICAL INFORMATION 12.1 Toxicity N/A 12.2 Persistence and degradability N/A 12.3 Bioaccumulative potential Not likely 12.4 Mobility in soil The product is aqueous and will be separated in aqueous conditions. 12.5 Results of PBT and vPvB assessment N/A 12.6 Other adverse effects N/A 12.7 Additional Information N/A SECTION 13 — DISPOSAL CONSIDERATIONS 13.1 Waste treatment methods Product Coagulate the emulsion by the stepwise of Ferric Chloride and Lime. Remove the clear supernatant liquid and flush to a chemical sewer. Incinerate the solids and the contaminated material according to local and federal regulations. 13.2 Additional information N/A SECTION 14 — TRANSPORT INFORMATION This product is not classified for transport under ADR/IMDG regulations. This product is not classified as a flammable liquid according to DOT and IATA transportation standards and is not regulated as such. 14.1 UN Number N/A 14.2 UN proper shipping name N/A DESCO INDUSTRIES, INC. - 3651 Walnut Avenue, Chino, CA 91710 • (909) 627-8178 • Website: DescoIndustries.com TB-7042 Page 10 of 11 © 2017 DESCO INDUSTRIES, INC. Employee Owned 14.3 Transport hazard class(es) N/A 14.4 Packing group N/A 14.5 Environmental hazards N/A 14.6 Special precautions for user N/A 14.7 Transport in bulk according to Annex II of MARPOL and the IBC Code N/A SECTION 15 — REGULATORY INFORMATION 15.1 Safety, health and environmental regulations/legislation specific for the substance or mixture Physical/Chemical Indication Non-flammable *These items are listed and subjected to the reporting requirements of the SARA Title III Section 313 Inventory of the Emergency Planning and Community Right-To-Know Act of 1986 and of 40 CFR37. CAS Number: 111-90-0 with Maximum weight 25% International Inventories at All components of this product are listed on or exempt from CAS# Level Following Inventories USA (TCA), Canada (DSL\NDSL) California Proposition 65 This product is not subject to the reporting requirements under California’s Proposition 65 EINECS Status All components are included in the EINECS Inventories. TSCA All ingredients of this product are listed or are excluded from the listing on the U.S. Toxic substance. REACH This product does not required REACH registration. RIGHT TO KNOW (RTK) Ingredients CAS # MARTK NJRTK PARTK 7732-18-5 - - X Diethylene glycol monoethyl ether 111-90-0 - X X Tributoxyethyl phosphate 78-51-3 - X X Water WHIMIS Canada hazard class: Non-controlled. This product has been classified according to the hazard criteria of the CPR and the MSDS contains all the information required by the CPR. REACH Regulation (EC) No 1907/2006 concerning the Registration, Evaluation, Authorization and Restriction of Chemicals. As of 2012-09-27 Desco Industries Inc. has completed an assessment of all of our products and is not under any obligation to register. 15.2 Chemical Safety Assessment N/A SECTION 16 — OTHER INFORMATION HMIS RATING Health 1, Reactivity 0, Flammability 0, Personal Protection B NFPA RATING Special Hazard: N/A, Health: 2, Flammability: 0, Instability: 0 SDS Updated 2017-04-20 Disclaimer OTHER INFORMATION: This information relates only to the specific material designated and may not be valid for such material used in combination with any other materials or in any other process. Such information is to the best of the company’s knowledge and believed accurate and reliable as of the date indicated. However, no representation, warranty or guarantee of any kind, express or implied, is made as to its accuracy, reliability or completeness and we assume no responsibility for any loss, damage or expense, direct or consequential, arising out of use. It is the user’s responsibility to satisfy himself as to the suitableness and completeness of such information for his own particular use. DESCO INDUSTRIES, INC. - 3651 Walnut Avenue, Chino, CA 91710 • (909) 627-8178 • Website: DescoIndustries.com TB-7042 Page 11 of 11 © 2017 DESCO INDUSTRIES, INC. Employee Owned
10511
物料型号:Statguard® Static Dissipative Floor Finish
器件简介:Statguard® 静电耗散型地面涂层,是一种交联聚合物,用于将硬质非防静电地面转换为防静电地面,并用于保护和增强永久性防静电地面(如乙烯基、VCT、橡胶等地面类型)。
该产品创建了一个耗散性涂层,符合ANSI/ESD STM7.1和ESD TR53标准,以及ANSI/ESD S20.20最低要求,用作主要接地方法和鞋类/地面系统的电荷生成。
引脚分配:无
参数特性: - 表面电阻:1×10^5 至 <1×10^1 欧姆/平方,符合ANSI/ESD S7.1和ESD TR53标准 - 低电荷生成:<100 伏特,符合ANSI/ESD STM97.2标准 - 固体含量:18% - 光泽:高光泽 - 覆盖率:每加仑约2000平方英尺/层 - 干燥时间:建议在室温超过70°F下每层干燥时间超过1小时或直至干燥
功能详解: - 消除100V以上的摩擦电,防止对静电敏感部件造成损害 - 通过ESD鞋类配合使用,从人员身上排放静电荷 - 减少干式维护和抛光时的维护频率和劳动需求
应用信息: - 适用于需要防静电保护的场所,如实验室、洁净室、电子制造车间等 - 适用于各种地面材料,包括混凝土、乙烯基、VCT、橡胶等
封装信息:产品包装有2.5加仑、5加仑和55加仑等规格。
10511 价格&库存
很抱歉,暂时无法提供与“10511”相匹配的价格&库存,您可以联系我们找货
