9110-NO
9110-NO
    SCS
    IONIZERBENCHTOP110-240VW/FAN
9110-NO 数据手册
USER GUIDE TB-9043 9110 Benchtop Air Ionizer Installation, Operation and Maintenance Features and Components Grill Tabs Front Grill Knobs Tab Screws Fan Speed Control Power Switch LED Power Indicator Saftey Switch Figure 1. SCS 9110 Benchtop Air Ionizer Figure 2. Benchtop Air Ionizer features and components (front view) Description The SCS 9110 Benchtop Air Ionizers a self-contained, ionized air blower designed to neutralize electrostatic charges from non-conductive objects (insulators) and isolated conductors. The SCS 9110 meets ANSI/ESD S20.20 tested per ANSI/ESD STM3.1 and ESD TR53. The ionizer is designed with a built-in automatic emitter points cleaner to periodically clean the emitter points therefore saving some manual work and time. The SCS 9110 Benchtop Air Ionizer is available in one model: Item Power Adapter Input 9110-NO 100-240 VAC Back Grill Offset Voltage Adjust Fuse Holder DC Input Jack Ground Terminal Figure 3. Benchtop Air Ionizer features and components (rear view) The SCS 9110 Benchtop Air Ionizer does not include a power cord. It must be purchased separately. Item Description 770000 Power Cord, IEC C-13, North America 770001 Power Cord, IEC C-13, UK 770002 Power Cord, IEC C-13, Europe 770003 Power Cord, IEC C-13, China Packaging 1 1 1 1 Benchtop Air Ionizer Unit Power Adapter, 100-240VAC Input, No Power Cord Ground Wire Certificate of Calibration Figure 4. Power adapter (included) and SCS 770000 North America Power Cord (not included) SCS - 926 JR Industrial Drive, Sanford, NC 27332 • (919) 718-0000 • Website: StaticControl.com TB-9043 Page 1 of 5 August 2015 © 2015 DESCO INDUSTRIES, INC. Employee Owned Installation Maintenance The Benchtop Air Ionizer mounts easily in a variety of positions using the provided tilting bracket/stand. Mount the bracket by following the illustration below. Secure the mounting bracket with screws on table top. Adjust the angle of air flow towards the target and secure it by tightening the side knobs. 1. When performing emitter points maintenance, disconnect the Power Adapter AC plug from the outlet. Do not connect or disconnect the power plug with wet hands as doing so puts you at risk of electrical shock or injury. Metal screw Metal screw 4mm x 20mm 4 x 20mm 1. Remove both side 1. Remove both side knobs one at a knobs time. one at a time. 2. Mount the bracket 2. Mount the bracket using using three screws. three screws. 3. Replace the fan body. Tighten 3. Replace the fan body. Tighten both knobs flow both knobstotoaa desired desired airair flow abgle towardsthe the target angle towards targetofof ionization. ionization. Figure 5. Installing the Benchtop Air Ionizer The safety of any system incorporating this equipment is the responsibility of the assembler of the system. The ionizer’s performance is affected by its distance from the worksurface and fan speed. As distance increases or fan speed is reduced, the discharge time at the work surface will increase. WARNING: The Benchtop Air Ionizer is not designed to be used in explosive areas or flammable atmospheres. Sparks from the fan motor or emitter points may cause ignition. Electrical Use the included AC/DC power adapter. For proper operation, the unit must be grounded for safe operation. Grounding The Benchtop Air Ionizer must be connected to ground through the GROUND Terminal behind the unit and the ground wire included in the package. Connect the ground wire to a known good electrical ground. Failure to connect the ground terminal may cause the unit to malfunction. Operation 1. Insert the AC/DC power adapter plug into an electrical outlet. Make certain that power line voltage is within the operating range of the AC/DC power adapter. The use of improper power line voltages may impair operation or damage the unit. This will void the warranty. 2. Occasional cleaning of the case is the only routine maintenance required. Although the emitter points have a built-in automatic cleaner, a check is still necessary for any abnormality within the emitter points. Verification and adjustment may be required to keep the balance within the specification range. 3. Cleaning the Case - Wipe the case with a moistened, fully squeezed soft cloth with deionized water. If a stronger cleaning solution is required, use a soft cloth with a mixture of alcohol and water (70% IPA and 30% DI water). Do not use any other solvents that can damage the coating of the case. Fully squeeze the cloth or sponge to remove any excess liquid. 4. Cleaning the Emitter Points - The emitter points and auto-cleaning brushes are accessible through the front grill. To clean them, turn off the unit; clean the points and brushes with a cotton swab. Use caution when accessing the emitter points to avoid injury. Access to the points is available by removing two tab screws on each side, pressing the side tabs, and pulling off the grill (see images below). Use caution when removing the grill to avoid breaking the cable that connects the grill. Be careful not to bend the emitter points during cleaning. The emitter points are fixed and therefore not replaceable. 5. The safety switch functions to turn off the power to the ionizer when the front grill is removed while the ionizer is in operation. Before any maintenance is performed on the emitter points and before removing the front grill, ensure the unit is powered off and the power cord is removed from the ionizer or the wall outlet. 6. Re-attach the front grill after cleaning the emitter points and fan blades. Replace the two tab screws on each side of the grill. 7. Service - If you believe that a unit is not functioning properly, disconnect the unit from power. If the unit is covered by Warranty, contact your SCS sales representative or distributor. CAUTION: There are no user replaceable parts. Unauthorized replacement of parts will void the warranty. 2. The power switch on the front of the unit turns the power and LED Power Indicator illuminates when it’s on. The dial knob adjusts the fan speed. Rotating it clockwise increases the fan speed. SCS - 926 JR Industrial Drive, Sanford, NC 27332 • (919) 718-0000 • Website: StaticControl.com TB-9043 Page 2 of 5 © 2015 DESCO INDUSTRIES, INC. Employee Owned 6. Locate the Offset Voltage Adjust trimpot and slowly turn the small screw head using a mini screwdriver. Observe the CPM reading as you turn. Stop turning as soon as the CPM reads as close to zero volts as possible. Remove two screws from each side to release the tab. 7. Proceed to do the Decay Time and Offset Voltage verification. Decay Time and Offset Voltage Verification 1. Set the CPM to Decay/Offset mode. Refer to the User’s Guide accompanying the CPM for proper operation and setup. Push and pull the tabs slowly. 2. Set the CPM to decay and offset voltage mode with a starting charge at either + or – 1 KV and a stopping charge at either + or -100 Volts. Wipe the emitter points, brushes, and fan with cotton swab or brush. 3. Start the decay/offset test sequence on the CPM. This will take a few seconds. 4. Record the decay time, and offset voltage as displayed on the CPM. Troubleshooting Replace the front grill and tighten two tab screws from each side to lock the tab. Problem Action The fan does not turn. Turn off the unit. Disconnect the AC plug from the outlet. Be sure to contact a SCS sales representative or authorized dealer to request inspection and repair. Repairing the product yourself is dangerous and will void the warranty. Do not attempt to repair the product yourself. Unbalanced ion levels. Ion balance cannot be adjusted to 0V. Check that the environmental conditions at the installation site fall within the service environment conditions of the unit. Calibration Offset Voltage Calibration 1. The equipment needed to measure the offset voltage is a calibrated charged plate monitor or equivalent set to voltmeter mode. Refer to the User’s Guide accompanying the CPM for proper operation and setup. 2. Position the Benchtop Air Ionizer and CPM as shown below. Ionizer Ionizer 30cm 30cm CPM CPM Turn off the unit if the above step does not improve the situation. Disconnect the AC plug from the outlet. Be sure to contact a SCS sales representative or authorized dealer to request inspection and repair. Repairing the product yourself is dangerous and will void the warranty. Do not attempt to repair the product yourself. 15cm 15cm Static-dissipative mat connected to GND Static-dissipative mat connected to GND Figure 6. Position of Ionizer and CPM 3. Turn on the power for the ionizer and the CPM. Let it warm up for 5 minutes. 4. Set the ionizer fan speed to maximum. 5. Set the CPM to voltmeter mode and select a smaller scale, example: 25 Volts. Perform cleaning of the emitter points as described in the “Maintenance” section. Others Examples: Abnormally slow rotation of the fan, the unit being abnormally hot, a burning odor, abnormal noises, etc. Turn off the unit. Disconnect the AC plug from the outlet. Be sure to contact a SCS sales representative or authorized dealer to request inspection and repair. Repairing the product yourself is dangerous and will void the warranty. Do not attempt to repair the product yourself. SCS - 926 JR Industrial Drive, Sanford, NC 27332 • (919) 718-0000 • Website: StaticControl.com TB-9043 Page 3 of 5 © 2015 DESCO INDUSTRIES, INC. Employee Owned Specifications Description Typical Values Input Voltage and Frequency (External Adapter) AC/DC Power Adapter – Power Input: 100-240VAC, 50/60 Hz Power Output: 24VDC, 2.5A Cable Length: 11 ft. (3.4 m) (including AC/DC Adapter) Indoor use only Operating Voltage 24VDC, 1.8A maximum – – Emitter Point Two-way Automatic Cleaning Cleaning Interval: 1 time per hour (4 cycles each time) – Indicators LED: Red power ON – Fuse 2.0A, 250V, 5.2 x 20 mm Glass Tube – Ion Emission Steady-state DC – Balance Voltage ANSI/ESD STM3.1 Maximum fan speed, measurement taken 30 cm from fan. Decay Time < 2.0 sec. ANSI/ESD STM3.1 Maximum fan speed, measurement taken 30 cm from fan. Air Speed 500 ft./min, 152 m/min Maximum fan speed Audible Noise High Fan Speed: 54 dB (sustained), 57 dB (auto cleaning) Low Fan Speed: 48 dB (sustained), 55 dB (auto cleaning) Audible noise during both ion output and auto cleaning operation. Measurement taken 100 cm from fan.
9110-NO 价格&库存
很抱歉,暂时无法提供与“9110-NO”相匹配的价格&库存,您可以联系我们找货
