50528
50528
    DESCO
    ZERO VLT MNTR W/WRST STP KT 120V
50528 数据手册
  TECHNICAL BULLETIN TB-6515  Zero Volt Monitor Installation, Operation and Maintenance Made in the United States of America strap properly, the monitor measures the loop resistance consisting of one wire of the ground cord, one-half of the wristband, the person’s skin, the second half of the wristband, and a second wire in the ground cord. If any part of the loop should open (become disconnected or have out of limit resistance), the circuit will go into alarm state” nonetheless, due to the redundancy inherent in the dual-wire wrist strap design, the operator will continue to be grounded via the second intact wire. The Zero Volt Monitor is available in the following models: Figure 1. EMIT Zero Volt Monitor Description The EMIT Zero Volt Monitor using ZERO VOLT MONITORING™ resistive loop technology meets ANSI/ ESD S20.20 conitinuous monitoring requirements, continuously verifies the proper resistance to ground of the operator and worksurface [or other item at the workstation] and will detect charge accumulation on the operator. It is to be used with dual-wire wrist straps (not included). Zero Volt Monitoring sends two test signals which are of equal and opposite polarity. The result is near zero voltage being placed on the operator with respect to equipment ground. The Zero Volt Monitor is also unaffected by capacitance variations associated with personnel and environmental conditions. Dual-Wire Continuous Monitors provide redundancy; even if one dual-wire wrist strap conductor is severed, operator has reliable path-to-ground with other wire. The steady state DC test signal will detect intermittent failures that may be missed by pulsed DC systems. An EMIT Calibration Unit is available so proper compliance verification per ESD TR53 can be performed at the workbench without taking the monitor out of service. Each Zero Volt Monitor is calibrated within accepted procedures and standards traceable to the National Institute of Standards and Technology (NIST) and includes a NIST certificate. Item Power Adapter Wrist Strap Kit 50528 N. America 19690 50537 None 19690 50538 N. America 09163 Packaging 1 1 1 2 2 2 1 2 Zero Volt Monitor Snap Kit Power Adapter (50528, 50538 only) Wrist Strap Kits Operator Cables (black and white) Mat Cords (black and white) Monitor Ground Cord (green) Mat Ground Cords (green) Features and Components A B C Per ANSI/ESD S1.1 section 6.1.3 Frequency of Functional Testing “The wrist strap system should be tested daily to ensure proper electrical value. Daily testing may be omitted if constant monitoring is used.” Per ESD Handbook ESD TR20.20 section 5.3.2.4.4 “Typical Test programs recommend that wrist straps that are used daily should be tested daily. However, if the products that are being produced are of such value that knowledge of a continuous, reliable ground is needed, and then continuous monitoring should be considered or even required.” Per ESD Handbook ESD TR20.20 section 5.3.9.2.2 Dual Conductor Resistance Continuous Monitors “This type of monitor is used with a two wire (dual conductor) wrist strap. The wrist strap assembly consists of a two-wire ground cord and a wristband that has two isolated halves. When a person is wearing the wrist H D F G I J E FRONT VIEW K LMN O P BACK VIEW Figure 2. Zero Volt Monitor features and components EMIT - 3651 Walnut Avenue, Chino, CA 91710 • (909) 664-9980 • Website: DescoEMIT.com TB-6515 Page 1 of 6 October 2017 © 2017 DESCO INDUSTRIES, INC. Employee Owned A. Operator Fail Low LED: Illuminates and alarm sounds when the operator’s resistance is below the test limit. B. Operator Pass LED: Illuminates when the operator is properly grounded. C. Operator Fail High LED: Illuminates and alarm sounds when the operator’s resistance is above the test limit. D. Operator Standby LED: Illuminates when the operator is not connected to the remote. E. Operator Charge LED: Illuminates and alarm sounds when the charge on the operator is greater than ±1.25V. F. Mat Fail LED: Illuminates and alarm sounds when the worksurface mat is not properly grounded. G. Mat Fail LED: Illuminates when the worksurface mat is properly grounded. H. Alarm Audible Adjustment: Turn the trimpot clockwise to increase the audible alarm volume and counter-clockwise to decrease it. I. Data Output: To be used with the EMIT Smart Hub. J. Power Jack: Connect a 9-15VDC power adapter here. K. Operator 2 Remote Jack: Connect the black operator remote cable here. L. Mat 2 Terminal: Monitors worksurface mat #2. Connect the black mat cord here. M. Monitor Ground Terminal: Common ground point for the monitor. Connect the black monitor ground cord here N. Mat 1 Terminal: Monitors worksurface mat #1. Connect the white mat cord here. O. Operator 1 Remote Jack: Connect the white operator remote cable here. P. Analog Output: Used for troubleshooting purposes by the manufacturer. Installation 1. Determine the mounting location of the Zero Volt Monitor. The front panel should be visible to both operators. 2. Determine the mounting locations of the operator remotes. Be sure to install the remotes at a distance that enables its leads to reach the back of the monitor. NOTE: The operator remotes for the Zero Volt Monitor are configured differently from other EMIT remotes. Be sure to only use the remotes that were packaged with your monitor. 3. Install tinned wire ends of the mat cords to their appropriate screw terminal block located at the back of the monitor. 4. Attach the worksurface mats to ground using the green mat ground cords. Install the ring terminal end of the cord to an appropriate ground point. Attach the snaps terminals to the snaps on the worksurface mat. 5. Install the tinned wire end of the black monitor ground cord to the ground terminal located at the back of the monitor. Install its ring terminal to an appropriate ground point. Be sure to use a different ground point than the one used for the mats. The face plate screw of a grounded AC wall outlet may provide a convenient connection point. 6. Route the mat cords from the back of the monitor to the snaps on worksurface mats. The white cord is for worksurface mat #1. The black cord is for worksurface mat #2. 7. Insert the operator remote cables into their appropriate jacks located at the back of the monitor. The white cable is for operator #1. The black cable is for operator #2. 8. Connect the power adapter to the power jack located at the back of the monitor. Plug the power adapter into a proper AC power outlet. The monitor is now powered. EMIT - 3651 Walnut Avenue, Chino, CA 91710 • (909) 664-9980 • Website: DescoEMIT.com TB-6515 Page 2 of 6 © 2017 DESCO INDUSTRIES, INC. Employee Owned OPERATOR 2 REMOTE JACK OPERATOR 1 REMOTE JACK MAT 2 CORD MONITOR GROUND CORD MAT 1 CORD 10mm PUSH & CLINCH SNAPS 10mm PUSH & CLINCH SNAPS 10mm snaps need to pierce and clinch bottom side of mat and be 12" - 72" apart. 10mm snaps need to pierce and clinch bottom side of mat and be 12" - 72" apart. OPERATOR 2 WORKSURFACE OPERATOR 1 WORKSURFACE Figure 3. Installing the Zero Volt Monitor EMIT - 3651 Walnut Avenue, Chino, CA 91710 • (909) 664-9980 • Website: DescoEMIT.com TB-6515 Page 3 of 6 © 2017 DESCO INDUSTRIES, INC. Employee Owned Operation Maintenance 1. Monitoring of the operators will remain in the STANDBY condition until a wrist cord is plugged into the operator remote. 2. Plug a wrist strap cord, not attached to the wristband, into the monitored jack labeled WRIST STRAP MONITOR located on the remote. This automatically activates the selected operator channel. The corresponding operator LED should illuminate red and the alarm should sound on the monitor. 3. Remove the charges from your body by making contact with a properly grounded ESD worksurface. Snap the cord to the wristband, and fit it snugly onto your wrist. This should silence the audible alarm and cause the corresponding operator LED to switch from red to green. If this does not happen, examine the wrist cord for continuity or damage and your wrist band to ensure that it is securely fit. If you have dry skin, apply an approved dissipative hand lotion such as Menda Reztore™ ESD Hand Lotion. 4. The AUX MAT jack located on the operator remote is a grounded and unmonitored connection for guests. It must be used with a banana plug wrist cord and single-wire wristband. JUMPER SETTINGS Feature Enable Disable Audible Adjust JP5 - OFF JP5 - ON Charge Display JP6 - OFF JP6 - ON Data Output JP7 - ON JP7 - OFF JP5 JP2 JP1 JP7 JP6 Figure 5. Jumper locations Calibration Figure 4. Connecting wrist straps to the operator remote CHARGE DETECTION The CHARGE LED illuminates and the alarm sounds when the charge on the operator is greater than ±1.25V. To disable charge detection on the display, shunt jumper JP6 inside the unit. If a charge is detected while using this configuration, the display will remain in its previous state until the charge is no longer detected. The Zero Volt Monitor is calibrated to standards traceable to NIST. Frequency of recalibratrion should be based on the critical nature of those ESD sensitive items handled and the risk of failure for the ESD protective equipment and materials. In general, we recommend that calibration be performed annually. Use the EMIT 50524 Limit Comparator for Dual-Wire Monitors to perform periodic testing (once every 6-12 months) of the Zero Volt Monitor. The Limit Comparator can be used on the shop floor within a few minutes virtually eliminating downtime, verifying that the monitor is operating within tolerances. See TB-6542 for more information. EMIT - 3651 Walnut Avenue, Chino, CA 91710 • (909) 664-9980 • Website: DescoEMIT.com TB-6515 Page 4 of 6 © 2017 DESCO INDUSTRIES, INC. Employee Owned MAT RESISTANCE SETTINGS 3.5M 1. If the desired resistance is 3.5M, jumpers JP1 (MAT 1) and JP2 (MAT 2) need to be on one pin (see Figure 5). 2. The respective potentiometers need to be adjusted fully clockwise. The pots are located inside the unit on the bottom board (see Figure 7). HIGH RESISTANCE (10k - 3.5M) Figure 6. EMIT 50524 Limit Comparator for Dual-Wire Monitors NOTE: The series “test” resistance is not the same as the operator to ground resistance. As shown in Figure 6, the series resistance is made up of the 1 megohm resistor in the cord, the wristband to operator’s skin resistance (skin contact resistance) and the operator’s resistance (human body resistance). 1. If the desired resistance is 10k - 3.5M, jumpers JP1 (MAT 1) and JP2 (MAT 2) need to be on one pin (see Figure 5). 2. Use a resistor decade box to set the desired resistance between the ground terminal and ground. 3. Connect the mat wire to the decade box and connect the decade box to ground. 4. Turn the appropriate potentiometer counter-clockwise until the GROUND LED illuminates red and alarm sounds (see Figure 7). For a given series resistance, the typical operator to ground resistance can be calculated from the following formula: 5. Slowly turn the potentiometer clockwise until the GROUND LED illuminates green. Roperator to ground = (Rseries + 2 megohms) 4 6. Add 10% more resistance (at least 1 ohm) to the decade box and verify that the GROUND LED illuminates red and alarm sounds. For a given operator to ground resistance, the series resistance can be calculated from the following formula: Rseries = (Roperator to ground x 4) - 2 megohms Skin Contact Resistance 7. Return back to the starting resistance and confirm that the green LED illuminates again. Repeat steps 4-7 if the monitor does not fail with the increased resistance or return to a pass condition. LOW RESISTANCE (< 1k) 1 megohm in Cord 1. If the desired resistance is < 1k, jumpers JP1 (MAT 1) and JP2 (MAT 2) need to be on both pins (see Figure 5). Human Body Resistance To Operator Remote 2. Use a resistor decade box to set the desired resistance between the ground terminal and ground. 3. Connect the mat wire to the decade box and connect the decade box to ground. 4. Turn the appropriate potentiometer counter-clockwise until the GROUND LED illuminates red and alarm sounds (see Figure 7). Skin Contact Resistance 1 megohm in Cord Figure 7. Operator series resistance 5. Slowly turn the potentiometer clockwise until the GROUND LED illuminates green. 6. Add 10% more resistance (at least 1 ohm) to the decade box and verify that the GROUND LED illuminates red and alarm sounds. 7. Return back to the starting resistance and confirm that the green LED illuminates again. Repeat steps 4-7 if the monitor does not fail with the increased resistance or return to a pass condition. EMIT - 3651 Walnut Avenue, Chino, CA 91710 • (909) 664-9980 • Website: DescoEMIT.com TB-6515 Page 5 of 6 © 2017 DESCO INDUSTRIES, INC. Employee Owned Limited Warranty, Warranty Exclusions, Limit of Liability and RMA Request Instructions See the EMIT Warranty http://EMIT.descoindustries.com/Warranty.aspx MAT 2 MAT 1 Figure 8. MAT potentiometers Specifications Operating Voltage 100-240 VAC, 50/60 Hz Operating Temperature 32°F - 104°F (0 - 40°C) Monitor Dimensions 5.6" x 4.7" x 2.6" (14.2cm x 11.9cm x 6.6cm) Monitor Weight 1.6 lbs (0.7 kg) TEST VOLTAGES Operator 1.25 V Worksurface 200 mV TEST LIMITS Operator Low Fail: < 1.72 megohms Pass: 2 - 9 megohms High Fail: > 11.5 megohms Worksurface Pass: < 3.5 megohms Fail: > 3.8 megohms Charge Detector Detects > ±1.25 VDC on operator NOTE: Worksurface must have a conductive layer such as Dual Layer Rubber or Dissipative 3-Layer Vinyl or Micastat® Dissipative Laminate with conductive buried layers. EMIT Continuous Monitors are not recommended for use with homogeneous matting. EMIT - 3651 Walnut Avenue, Chino, CA 91710 • (909) 664-9980 • Website: DescoEMIT.com TB-6515 Page 6 of 6 © 2017 DESCO INDUSTRIES, INC. Employee Owned
50528 价格&库存
很抱歉,暂时无法提供与“50528”相匹配的价格&库存,您可以联系我们找货
