98256
98256
    DESCO
    ADAPTERACCOMBOTESTER120V
98256 数据手册
TECHNICAL BULLETIN TB-2040 Combo Wrist Strap / Footwear Tester Installation, Operation and Maintenance Pass Range 750K - 10M and 750K - 100M Made in the United States of America a continuous, reliable ground is needed, and then continuous monitoring should be considered or even required.” Per ESD SP9.2 APPENDIX B - Foot Grounder Usage Guidance “Compliance verification should be performed prior to each use (daily, shift change, etc.). The accumulation of insulative materials on the FCS may increase the foot grounder system resistance. If foot grounders are worn outside the ESD protected area testing for functionality before reentry to the ESD protected area should be considered.” Per ESD SP9.2 APPENDIX C -Parallel Ground Paths “A parallel ground path allows a flow of electrical current through a path that is not intended for the test. Parallel ground paths may be caused by several different situations. Figure 1. Desco 19250 Combo Tester Description The Desco 19250 Combo Tester is a 3-state touch tester designed for fast, frequent testing of ESD personnel grounding devices. This product can be used as one of the tools to fulfill the ANSI ESD S20.20 paragraph 6.1.3.2 “Compliance Verification Plan. Verification should include routine checks of the Technical Requirements of the Plan.” The Combo Tester incorporates a unique dual test circuit design which improves accuracy of testing and eliminates the need for separate wrist strap and foot grounder test units. The 19250 is equipped with a 750 kilohm - 10 megohm circuit, ideal for testing of wrist straps and a 750 kilohm - 100 megohm circuit designed for accurate testing of footwear. For example: a. The path represented by the person standing with one shoe on the floor and the other shoe on the test apparatus. A parallel path may be created by the shoe on the floor. Current from the test instrument is then directed down two paths when it was intended to be directed down one. The correct path for the test is with one shoe in the air or on an insulating surface and the other shoe on the test plate. b. The path presented by a person inadvertently supporting themselves by means of one hand on another object such as a wall, table or supporting member in order to measure the resistance in one foot contact. The hand has created a parallel path to ground. Test parameters are factory set but can be adjusted to match your own specifications. The 19250 is very simple to operate. A green light signals the user that everything is OK. A red light and an audible indicator means that the circuit resistance is either too low or too high. c. The path represented by a person leaning against another object with other parts of the body in order to provide physical support during a testing sequence. This can then lead to other grounding paths and erroneous results.” The Tester operates on either a 9 volt battery or a special AC adapter. The Combo Tester is calibrated to NIST traceable standards and is available in three models. Remove the Tester from the carton and inspect for damage. Model 19250 Description Combo Tester, 9 Volt battery 19253 19252 19261 98273 98254 Combo Tester w/ FOOT PLATE Combo Tester w/ Stand Combo Tester Mounting Plate Foot Plate for Combo Tester Stand for Combo Tester 98256 98257 AC Adapter, 120V AC Adapter, 220V CAUTION: Use only the AC adapter designed for this unit: Item 98256 (120 volt) or Item 98257 (220 volt). Using any other adapters may damage the unit and void the warranty. Per ESD Handbook ESD TR20.20 paragraph 5.3.2.4.4 Test Frequency “Typical test programs recommend that wrist straps that are used daily should be tested daily. However, if the products that are being produced are of such value that knowledge of Packaging Items included with model 19250: 1 Combo Tester 1 9 volt battery Items included only with model 19253: 1 Combo Tester 1 Foot plate 1 Ground cord 1 9 volt battery Items included only with model 19252: 1 Combo Tester 1 Base plate 1 Pedestal tube with bracket and boot installed 1 4” banana plug connector 1 Vinyl insulator cap 1 Wall poster 1 5/32” hex wrench 1 9 volt battery Model numbers 19253 and 19252 are ideally suited for testing foot grounding devices. DESCO WEST - 3651 Walnut Avenue, Chino, CA 91710 • (909) 627-8178 DESCO EAST - One Colgate Way, Canton, MA 02021-1407 • (781) 821-8370 • Website: Desco.com TB-2040 October 2013 Page 1 of 6 © 2013 DESCO INDUSTRIES INC. Employee Owned Installation The Combo Tester may be used as a portable unit, or may be permanently mounted on either a table or a wall. Please refer to the following instructions when installing your tester. Stationary Installation If you will be using the tester as a portable unit, you may prefer to mount the unit to a table or wall. Three keyhole slots on the back of the unit are included to allow you to attach the tester to a stationary surface. Figure 4. Replacing the battery General Instructions In the following test configurations, the 19250 can be used to test wrist straps while they are worn. Models 19253 and 19252 will also allow the user to test footwear. Insertion of the banana plug on the wrist strap cord activates the wrist strap tester circuit and deactivates the footwear test circuit. NOTE: When testing or calibrating, press and hold the test button until the test results are displayed. Allow 1-2 seconds for the unit to reset before pressing the test button again. Figure 2. Mounting hole locations 1. Select location for mounting Tester. Install three #6 or #8 screws spaced as illustrated in figure 3, into a wall or other vertical surface. Make sure that the screw heads do not project out more than 1/4” from mounting surface. The template on page four is actual size. 2. Mount the Tester on the screws, pulling down to lock it in place. WRIST STRAP TESTING WITH MODEL 19250 This test safely checks that a continuous path between the operator, wrist strap and ground cord exists. 1. While wearing the wrist strap, plug the banana plug end of the cord into the jack on the face of the unit. 2. Press rocker switch toward “WRIST CORD”. 3. Press and hold the test button until the test results are displayed. NOTE: DO NOT TOUCH ANY OTHER  METAL WHILE PERFORMING TEST. Figure 3. Stationary installation of the Combo Tester Operation The Combo Tester can be operated either on battery or AC power. The unit comes equipped with a 9 volt alkaline battery. For AC operation, plug the optional AC adapter into the mini phone jack located on the upper left hand corner of the tester. AC adapters are sold separately as item 98256 (120 volt) or 98257 (220 volt). LOW BATTERY INDICATOR The Combo Tester includes a low battery indicator alarm circuit. If both the audible alarm and indicator LED turn on during use, discontinue testing and replace the battery. The tester will continue to operate with a weak battery, but results should not be considered accurate. The battery can be easily replaced by removing the battery compartment cover on the back of the unit and installing a new 9 volt battery. Figure 5. Testing the wrist strap 4. Lighting of the green “PASS” LED indicates that the wrist strap and ground cord assemblies are functioning properly. 5. If either “FAIL LO” or “FAIL HI” LEDs light and the audible indicator sounds, the wrist strap wearer should check the wrist strap assembly immediately. TESTING FOOT GROUNDING DEVICES In order to test footwear you will need the model 19253 or 19252 Combo Tester. The following instructions are intended for use while wearing foot grounding devices. When using a Footwear Tester that does not use a split FOOT PLATE, one needs to test one foot at a time; best practice is to raise the other foot off the floor. When testing conductive shoes, or foot grounders worn on both feet, test each foot separately to test the separate path-to-ground. If the floor is an ESD floor, placing the other foot on the floor may result in erroneous test results. Care should also be taken not to create (hand resting on wall or bench) other paths-to-ground. DESCO WEST - 3651 Walnut Avenue, Chino, CA 91710 • (909) 627-8178 DESCO EAST - One Colgate Way, Canton, MA 02021-1407 • (781) 821-8370 • Website: Desco.com TB-2040 Page 2 of 6 © 2013 DESCO INDUSTRIES INC. Employee Owned 1. Place the Foot Plate on the floor in front of the Combo Tester. 2. Plug the plate’s ground cord into the jack on the left hand side of the unit. NOTE: Steps 1 and 2 are not required with the 19252. Assembly 1. Remove 3 screws from baseplate. 2. Position pedestal on the baseplate with the Tester mounting bracket pointing away from the operator. Attach pedestal to baseplate using the three screws provided. Tighten with hex wrench provided. Figure 6. Installing ground cord to “FOOT PLATE” jack 3. Press the rocker switch toward “FOOT PLATE.” 4. Place one foot on the plate. If the floor is conductive, lift the foot you are not testing off of the floor during this test. Make sure there is no cord plugged into the “WRIST CORD” jack. 5. Press and hold the test button until the test results are displayed. Figure 9. Attaching pedestal to baseplate 3. Open the compartment and attach the snap connector to the included 9 volt battery. Attach poster to the wall at eye level in front of the Tester location. 4. Install the Tester on the bracket by aligning keyholes on the back of tester with mounting studs on bracket. While pushing up on thumb screw, insert the mounting studs into the keyholes and slide the tester down. See Figure 10. Figure 7. Testing foot grounding devices with 19253 6. Lighting of the green “PASS” LED indicates that the foot ground assemblies are functioning properly. Thumb screw 7. If either red “FAIL LO” or red “FAIL HI” LEDs light and the audible indicator sounds, the wearer should check the foot grounding device immediately. Figure 10. Installing Tester on bracket and securing Tester to bracket 8. Repeat steps 3-6 with other foot. 5. Install the 4” banana plug connector to “FOOT PLATE” jack on the side of the unit. Insert ring terminal behind thumb screw. Free Standing Test Fixture Assembly and Operation (Model 19252) The 19252’s rugged steel pedestal tube is powder coated in a non-conductive white finish that helps to prevent false readings if contacted by skin or loose smocks. 6. Twist the thumb screw clockwise to secure the tester to the bracket. Cover thumb screw with vinyl insulator cap. WRIST STRAP TESTING This test verifies that a continuous path between the operator, wrist strap, and ground cord exists. 1. While wearing the wrist strap, plug the banana plug end of the cord into the jack on the face of the unit. 2. Press rocker switch toward “WRIST CORD”. 3. Press and hold the test button until the test results are displayed. NOTE: DO NOT TOUCH ANY OTHER  METAL WHILE PERFORMING TEST. Figure 8. The 19252 Free Standing Test Fixture DESCO WEST - 3651 Walnut Avenue, Chino, CA 91710 • (909) 627-8178 DESCO EAST - One Colgate Way, Canton, MA 02021-1407 • (781) 821-8370 • Website: Desco.com TB-2040 Page 3 of 6 © 2013 DESCO INDUSTRIES INC. Employee Owned Calibration The models 19250, 19253, and 19252 are calibrated to NIST traceable standards. We recommend that calibration is performed annually to ensure that the Tester is operating within limits. Due to its dual circuit design both test circuits of the Combo Tester must be calibrated individually. Desco offers a calibration unit that is specifically designed to simplify the calibration procedure. This unit is sold as item 07010. The Calibration Unit comes calibrated to NIST traceable standards. For additional information on the 07010, ask for Technical Bulletin TB-2039. 750 Kilohm - 10 Megohm TEST RANGE - WRIST STRAPS The following resistance should give the display shown: Figure 11. Testing of wrist strap grounding assemblies 4. Lighting of the green “PASS” LED indicates that the wrist strap and ground cord assemblies are functioning properly. 5. If either red “FAIL LO” or “FAIL HI” LEDs light and the audible indicator sounds, the wrist strap wearer should check the wrist strap assembly immediately. TESTING FOOT GROUNDING DEVICES When using a Footwear Tester that does not use a split FOOT PLATE, one needs to test one foot at a time; best practice is to raise the other foot off the floor. When testing conductive shoes, or foot grounders worn on both feet, test each foot separately to test the separate path-to-ground. If the floor is an ESD floor, placing the other foot on the floor may result in erroneous test results. Care should also be taken not to create (hand resting on wall or bench) other paths-to-ground. 1. Press rocker switch toward “FOOT PLATE”. Resistance Value (±5% or better) 675 Kilohm 825 Kilohm 8.5 Megohm 11.5 Megohm Test Output Red (Fail Lo) Green (Pass) Green (Pass) Red (Fail Hi) 750 Kilohm - 100 Megohm TEST RANGE - FOOTWEAR The following resistance should give the display shown: Resistance Value (±5% or better) Test Output 675 Kilohm Red (Fail Lo) 825 Kilohm Green (Pass) 80 Megohm Green (Pass) 120 Megohm Red (Fail Hi) To calibrate, simply test each resistance value shown above which are included in the 07010 Calibration Unit. Test across the test button and “WRIST CORD” jack for calibration of the 750 Kilohm - 10 Megohm range. Test across the test button and “FOOT PLATE” jack for calibration of the 750K - 100M range. Be sure rocker switch is set correctly. 2. Place one foot on the plate. If the floor is conductive, lift the foot you are not testing off of the floor during this test. Make sure there is no cord plugged into the “WRIST CORD” jack. 3. Press and hold the test button until the test results are displayed. Figure 13. Calibration of the Combo Tester’s 750 kilohm to 100 megohm range Figure 12. Testing foot grounding devices 4. Lighting of the green “PASS” LED indicates that the foot ground assemblies are functioning properly. 5. If either red “FAIL LO” or red “FAIL HI” LEDs light and the audible indicator sounds, the wearer should check the foot grounding device immediately. Figure 14. Calibration of the Combo Tester’s 750 kilohm to 10 megohm range 6. Repeat steps 1-3 with other foot. DESCO WEST - 3651 Walnut Avenue, Chino, CA 91710 • (909) 627-8178 DESCO EAST - One Colgate Way, Canton, MA 02021-1407 • (781) 821-8370 • Website: Desco.com TB-2040 Page 4 of 6 © 2013 DESCO INDUSTRIES INC. Employee Owned Observe the LEDs for the proper response as indicated. Be sure to hold the cord at an insulated point, so that resistance value is not affected by the body. Should testing reveal that the Tester is not functioning properly, verify that the battery or power supply is operating correctly. TABLE 1 - STANDARD RANGES RANGE FAIL LO PASS LO PASS HI FAIL HI WRIST STRAP 675K 825K 8.5M 11.5M Tester calibration can also be verified with the use of discrete resistors and two banana-to-alligator cords. FOOT WEAR 675K 825K 80M 120M Adjustment RESISTANCE “A” “B” “C” “D” Detailed adjustment instructions follow: Equipment Required: - Small blade screwdriver or Trimpot adjusting tool, manufacturer’s calibration box or a resistor decade box or discrete resistors, with appropriate test leads. PREPARATION OF THE UNIT: Make sure that a fresh 9 Volt alkaline battery is installed, and orient tester so that it corresponds to Figure 15. CALIBRATION OF FOOT WEAR RANGES: 1. Connect resistance “A” from table 1 or 2, this time between the test button and the “FOOT PLATE” banana jack on the left side of the tester. For footwear calibration, press and hold the touch plate. The red “FAIL LO” LED should be on. 2. If required, adjust FWL trimpot to the point where the “FAIL LO” LED illuminates. 3. Connect resistance “B” and press switch as in step 1. The green “PASS” LED illuminates. The FWL trimpot may require a slight re-adjustment. 4. Connect resistance “C” (footwear range) and press switch as in step 1. The green “PASS” LED should illuminate. If required, adjust the FWH trimpot to the point where the green LED illuminates. 5. Finally, connect resistance “D” (footwear range) and press switch as in step 1. The red “FAIL HI” LED should illuminate. The FWH trimpot may require a slight re-adjustment. 6. Re-check to insure that all footwear ranges are correct. Figure 15 . Back of the Combo Tester CALIBRATION OF WRIST STRAP RANGES: 1. Connect resistance “A” from Table 1 OR 2 between the touch plate and the “WRIST CORD” banana jack. A banana plug must be inserted in the banana jack to properly test the wrist strap ranges. Press and hold the test button. The red “FAIL LO” LED should illuminate. 2. If required, adjust WSL trimpot to the point where the “FAIL LO” LED illuminates. 3. Connect resistance “B” and press the switch as in Step III. The green “PASS” LED should illuminate. The WSL trimpot may require a slight re-adjustment. 4. Connect resistance “C” (wrist strap range) and press the switch as in step 1. The green “PASS” LED should be on. If required, adjust the WSH trimpot to the point where the green “PASS” LED illuminates. 5. Finally, connect resistance “D” (wrist strap range) and press the swtich as in step 1. The “FAIL HI” red LED should be on. The WSH trimpot may require re-adjustment. 6. Re-check to insure that all ranges are correct, then proceed to calibrate footwear ranges. RETURN UNIT TO SERVICE. Unauthorized modifications will void the product warranty. Servicing should be performed only at the factory. See warranty section for repair information. Specifications Wrist Strap Circuit FAIL HI Factory set at 11.5 Megohms FAIL LO Factory set at 675 Kilohms Footwear Circuit FAIL HI Factory set at 120 Megohms FAIL LO Factory set at 675 Kilohms General Characteristics Power 9 Volt battery or optional AC power supply Operation Resistance bridge Readout Three LED’s & audible alarm Accuracy ±20% Weight 12 pounds Height 39 inches Consider adding the 19250 to your list of “test equipment [that] shall be selected to make measurements of appropriate properties of the technical requirements that are incorporated into the ESD program plan” as required by paragraph 6.1.3.1 of ANSI/ESD S20.20. DESCO WEST - 3651 Walnut Avenue, Chino, CA 91710 • (909) 627-8178 DESCO EAST - One Colgate Way, Canton, MA 02021-1407 • (781) 821-8370 • Website: Desco.com TB-2040 Page 5 of 6 © 2013 DESCO INDUSTRIES INC. Employee Owned Limited Warranty Desco expressly warrants that for a period of one (1) year from the date of purchase, Desco Combo Testers will be free of defects in material (parts) and workmanship (labor). Within the warranty period, the product will be tested, repaired, or replaced at Desco’s option, free of charge. Call our Customer Service Department at 909-627-8178 (Chino, CA) or 781- 821-8370 (Canton, MA) for a Return Material Authorization (RMA) and proper shipping instructions and address. Include a copy of your original packing slip, invoice, or other proof of purchase date. Any unit under warranty should be shipped prepaid to the Desco factory. Warranty repairs will take approximately two weeks. If your unit is out of warranty, call Customer Service at 909-627-8178 (Chino, CA) or 781-821-8370 (Canton, MA) for a Return Material Authorization (RMA) and proper shipping instructions and address. Desco will quote repair charges necessary to bring your unit up to factory standards. Warranty Exclusions THE FOREGOING EXPRESS WARRANTY IS MADE IN LIEU OF ALL OTHER PRODUCT WARRANTIES, EXPRESSED AND IMPLIED, INCLUDING MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE WHICH ARE SPECIFICALLY DISCLAIMED. The express warranty will not apply to defects or damage due to accidents, neglect, misuse, alterations, operator error, or failure to properly maintain, clean or repair products. Limit of Liability In no event will Desco or any seller be responsible or liable for any injury, loss or damage, direct or consequential, arising out of the use of or the inability to use the product. Before using, users shall determine the suitability of the product for their intended use, and users assume all risk and liability whatsoever in connection therewith. DESCO WEST - 3651 Walnut Avenue, Chino, CA 91710 • (909) 627-8178 DESCO EAST - One Colgate Way, Canton, MA 02021-1407 • (781) 821-8370 • Website: Desco.com TB-2040 Page 6 of 6 © 2013 DESCO INDUSTRIES INC. Employee Owned
98256
- 物料型号:Desco 19250 Combo Tester,以及变体19253和19252,还有配件19261、98273、98254、98256和98257。 - 器件简介:Desco 19250 Combo Tester是一款三状态触摸测试器,用于快速频繁测试ESD个人接地装置。它结合了独特的双测试电路设计,提高了测试的准确性,并消除了分别测试手腕带和脚部接地器的需要。 - 引脚分配:文档中没有提供具体的引脚分配图,但提到了测试器具有用于手腕带的“WRIST CORD”插孔和用于脚部接地器测试的“FOOT PLATE”插孔。 - 参数特性:测试器配备了750千欧姆至10兆欧姆的电路,适用于测试手腕带,以及750千欧姆至100兆欧姆的电路,专为准确测试鞋类设计。测试参数是出厂设定的,但可以调整以符合用户自己的规格。 - 功能详解:操作非常简单,绿灯表示一切正常,红灯和声音指示器表示电路电阻过低或过高。测试器可以运行在9伏电池或专用交流适配器上。 - 应用信息:该产品可以作为ANSI ESD S20.20标准6.1.3.2节“合规性验证计划”的一部分工具使用。建议日常使用的手腕带每天进行测试。 - 封装信息:19250型号包括测试器和1节9伏电池。19253型号包括测试器、脚板、接地线和1节9伏电池。19252型号包括测试器、基板、带支架和靴子的立柱管、1个4英寸香蕉插头连接器、1个乙烯基绝缘帽、1张墙报和1个5/32英寸六角扳手。
98256 价格&库存
很抱歉,暂时无法提供与“98256”相匹配的价格&库存,您可以联系我们找货
    • 1+216.703931+28.08896
    库存:33
