57006
57006
    DESCO
    Molded
    BOX COND WITH FOAM 4.2X3.2X0.52
57006 数据手册
Description: As required by ANSI/ESD S20.20 Packaging standard ANSI/ESD S541 these conductive boxes are marked with the ESD protective symbol. They contain one piece of high density foam for insertion of component leads and one piece of low density foam which acts as a cushioning material. 57000 has only 1 piece of foam, all other sizes have 2 pieces of foam. *Low density foam not included in item 57000 Properties: ITEM NO. INSIDE DIMENSIONS WITHOUT FOAM Material: Black conductive polypropylene Resistance: Less than 1 x10E5 ohms (per ANSI EOS/ESD S11.11) Size Tolerance: ± 1/32" * SIZE - MM SIZE - INCHES 57000 33 x 33 x 12 1.3 x 1.3 x 0.46 57002 73 x 51 x 16 2.9 x 2 x 0.63 Temperature Limits: 0° to 120° F 57004 90 x 64 x 16 3.5 x 2.5 x 0.63 57006 107 x 82 x 13 4.2 x 3.2 x 0.52 Hinge: Molded one-piece (57000-57006), Pin two-piece (57008-57012) 57010 229 x 126 x 21 9 x 5 x 0.81 57008 229 x 126 x 30 9 x 5 x 1.19 Closure: Snap 57012 229 x 126 x 40 9 x 5 x 1.58 Top Foam: 1/4" (.25", 6mm) thick low density foam Bottom Foam: 1/4" (.25", 6mm) thick high density foam * All boxes have the ESD Protective Symbol molded into them. ANSI/ESD S541 section 6.1 Inside an EPA “Packaging used within an EPA (that satisfies the minimum requirements of ANSI/ESD S20.20) shall be: 1. Low charge generation. 2. Dissipative or conductive materials for intimate contact.” ANSI/ESD S541 section 7.2.2 Resistance of Dissipative Materials “A static dissipative material shall have a surface resistance of greater than or equal to 1.0 x 10^4 Ohms but less than 1.0 x 10^11 Ohms. Packaging materials that are in intimate contact with devices should be dissipative.” Conductive Hinged Box with Foam PROTEKTIVE PAK 13520 MONTE VISTA AVENUE, CHINO, CA 91710 PHONE (909) 627-2578, FAX (909) 363-7331 ProtektivePak.com © 2010 DESCO INDUSTRIES INC. Employee Owned Made in America Specifications and procedures subject to change without notice DRAWING NUMBER 57000 DATE: April 2010
57006
物料型号为57000系列,具体尺寸为33x33x12毫米,对应1.3x1.3x0.46英寸。
封装材料为黑色导电聚丙烯,具有小于1x10E5欧姆的电阻值,尺寸公差为±1/32英寸,温度限制在0°至120°F之间。
铰链为一体式(57000-57006),销钉式两片(57008-57012)。
封装采用快开方式,顶部泡沫为1/4英寸厚的低密度泡沫,底部泡沫为1/4英寸厚的高密度泡沫。
所有盒子上都有防静电保护标志。
产品符合美国国家标准协会/静电放电安全(ANSI/ESD S541)第6.1节的规定,用于静电放电保护的包装应为低电荷生成材料,以及与设备有密切接触的耗散性或导电材料。
导电铰链盒内含有一片高密度泡沫用于插入组件引脚,一片低密度泡沫用作缓冲材料。
57000型号仅含有一片泡沫,其他尺寸含有两片泡沫。
57000型号不含低密度泡沫。
产品规格和程序如有变更,恕不另行通知。
制造地为美国。
产品符合ANSI/ESD S541第7.2.2节的规定,耗散性材料的表面电阻值应大于等于1.0x10^4欧姆但小于1.0×10^11欧姆。
与设备有密切接触的包装材料应为耗散性材料。
产品由PROTEKTIVE PAK公司生产,地址位于美国加利福尼亚州奇诺市,电话为(909) 627-2578,传真为(909) 363-7331。
更多信息可以访问ProtektivePak.com。
图号为57000,日期为2010年4月,版权归DESCO INDUSTRIES INC.所有。
57006 价格&库存
很抱歉,暂时无法提供与“57006”相匹配的价格&库存,您可以联系我们找货
