37130
37130
    DESCO
    DIP
    BOX BIN REEL/DIP TUBE 18X2X9
37130 数据手册
Features • • • • • • Designed to saftely store both reels and Rail/DIP tubes in the same bin box Available in open style with better loading from above Available in closed style with better loading from front May be used for storing, kitting, or transporting during work-in-process operations Shipped knocked-down; easy to assemble Made in America Item D L Size O.D. - L x W x D (IN) 37130 Open: 18 x 2 x 9 37132 Open: 18 x 4 x 9 37134 Open: 18 x 6 x 9 37131 Open: 24 x 2 x 9 37133 Open: 24 x 4 x 9 37135 Open: 24 x 6 x 9 37611 Closed: 24-3/8 x 4-11/16 x 15-1/4 Unless otherwise noted, tolerance is ±10% W Meets the required limits of ANSI/ESD S20.20, Packaging standard ANSI/ESD S541, and worksurface standard ANSI/ESD S4.1 SPECIFICATIONS Properties Surface Resistance Sloughing Test Recyclability Typical Values 1 x 106 to < 1 x 109 ohms Negligible surface damage at 10 cycles and
37130 价格&库存
很抱歉,暂时无法提供与“37130”相匹配的价格&库存,您可以联系我们找货
