S4B-PH-SM4-TB(LF)(SN) 数据手册
Emboss Tape
PH CONNECTOR
2.0mm pitch/Disconnectable Crimp style connectors
6
5
Specifications –––––––––––––––––––
4
3
2
This is a thin, low-profile 2.0mm pitch
connector 8.0mm in height after mounting
and 4.5mm in width. It is designed to meet
the demand for high-density connection of
internal wires to printed circuit boards. It is
compact, highly reliable and low in cost.
• Reliable contact
• Fully shrouded header
• Printed circuit board retention mechanism
• Surface mount model (SMT)
• Current rating: 2A AC, DC (AWG #24)
• Voltage rating: 100V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 10m Ω max.
After environmental testing/ 20m Ω max.
• Insulation resistance: 1,000M Ω min.
• Withstanding voltage: 800V AC/ minute
• Applicable wire: AWG #32 to #24
• Applicable PC board thickness: 0.8 to 1.6mm
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Standards ––––––––––––––––––––––
Recognized E60389
1 Certified LR20812
2 R75087
〈Through-hole type (viewed from soldering side) 〉
Side entry type
Top entry type
4.5
2 ±0.05
2 ±0.05
9.6
+0.1
8
+0.1
φ0.7 0
6
φ0.7 0
4.8
7.6
6.25
Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers.
2. Hole dimensions differ according to the kind of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions should
be larger. The dimensions above should serve as a guideline. Contact JST for details.
〈SMT type (viewed from component side) 〉
SM4 type
Top entry type
1.6 ±0.1
2 ±0.05
5
1.5
(2)
1.6
1 min
2
±0.05
5.5 max
3.4
9.6
7.6
1
5.5
6.6
8.6
2 max
7.5 min
±0.1
1
±0.1
3
Circuit No.1
±0.1
End face of wafer
on the mating side
0.2
End face of wafer
on the mating side
±0.1
9 min
1.6 ±0.1
SM4 type
Side entry type
1 min
Circuit No.1
2. The dimensions above should serve as a guideline. Contact JST for details.
1
PH CONNECTOR
Contact
Applicable wire
Model No.
1.5
5.7
1
2.05
SPH-002T-P0.5S
SPH-002T-P0.5L
SPH-004T-P0.5S
2.08
2.85
mm2
AWG #
Insulation O.D. (mm)
0.05 ∼ 0.22
30∼24
0.9∼1.5
0.08 ∼ 0.22
28∼24
0.8∼1.5
0.032∼0.08
32∼28
0.5∼0.9
Q'ty /
reel
8,000
10,000
Material and Finish
Phosphor bronze, tin-plated (reflow treatment)
Crimping
machine
Contact
Applicator
Dies
Crimp applicator
MKS-L
SPH-002T-P0.5S
SPH-002T-P0.5L AP-K2N
SPH-004T-P0.5S
Crimp applicator with dies
MK/SPH-002-05S APLMK SPH002-05S
*MKS-SC
SC/SPH-002-05S
APLSC SPH002-05S
MKS-L
MK/SPH-002-05L
APLMK SPH002-05L
*MKS-SC
SC/SPH-002-05L
APLSC SPH002-05L
MKS-L-10
MK/SPH-004-05S APLMK SPH004-05S
*MKS-SC-10
SC/SPH-004-05S
RoHS compliance
Note:
1. Contact JST for gold-plated products.
2. SPH-002T-P0.5L is low-insertion force type contact, for easier insertion/
withdrawal, which would be less resistant to the vibration. The crimp height
is different from the standard.
3. Contact JST for details.
APLSC SPH004-05S
Note: *Strip-crimp applicator
Housing
Circuits
B
1.9
A
2
2
4.5
0.5
Circuit
No.1
3
4
5
7
6.35
H JST
8
6
8
9
10
11
0.6
12
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
ex.
13
14
15
16
PHR-2-oo(blank)…natural (white)
BK…black R…red TR…tomato red BL…blue Y…yellow
L…lemon yellow M…green D…orange N…brown
P…purple PK…pink H…gray LE…light blue
FY…vivid yellow DPK...dark pink
Model No.
PHR-2
PHR-3
PHR-4
PHR-5
PHR-6
PHR-7
PHR-8
PHR-9
PHR-10
PHR-11
PHR-12
PHR-13
PHR-14
PHR-15
PHR-16
A
Dimensions (mm)
B
Q'ty /
box
2.0
5.8
1,000
4.0
7.8
1,000
6.0
9.8
1,000
8.0
11.8
1,000
10.0
13.8
1,000
12.0
15.8
1,000
14.0
17.8
1,000
16.0
19.8
1,000
18.0
21.8
1,000
20.0
23.8
1,000
22.0
25.8
1,000
24.0
27.8
1,000
26.0
29.8
1,000
28.0
31.8
1,000
30.0
33.8
1,000
Material
PA 66, UL94V-0, natural (white)
RoHS compliance
Through-hole type shrouded header
Top entry type
Circuits
2
3
(2 circuits)
(3 circuits or more)
4
4.5
4.5
1.7
B
5
1.7
B
6
7
8
6
6
9
10
1.95 A
Circuit
No.1
3.4
3.4
11
12
13
14
0.5
2
1.95
0.5
15
A
Circuit No.1
16
Model No.
Top entry type
Side entry type
B2B-PH-K-S
S2B-PH-K-S
B3B-PH-K-S
S3B-PH-K-S
B4B-PH-K-S
S4B-PH-K-S
B5B-PH-K-S
S5B-PH-K-S
B6B-PH-K-S
S6B-PH-K-S
B7B-PH-K-S
S7B-PH-K-S
B8B-PH-K-S
S8B-PH-K-S
B9B-PH-K-S
S9B-PH-K-S
B10B-PH-K-S
S10B-PH-K-S
B11B-PH-K-S
S11B-PH-K-S
B12B-PH-K-S
S12B-PH-K-S
B13B-PH-K-S
S13B-PH-K-S
B14B-PH-K-S
S14B-PH-K-S
B15B-PH-K-S
S15B-PH-K-S
B16B-PH-K-S
S16B-PH-K-S
Dimensions (mm)
Q'ty / box
A
B
Top entry type Side entry type
2.0
5.9
1,000
1,000
4.0
7.9
1,000
1,000
6.0
9.9
1,000
500
8.0
11.9
1,000
500
10.0
13.9
1,000
500
12.0
15.9
500
500
14.0
17.9
500
250
16.0
19.9
500
250
18.0
21.9
500
250
20.0
23.9
500
250
22.0
25.9
400
250
24.0
27.9
250
250
26.0
29.9
250
250
28.0
31.9
250
200
30.0
33.9
250
200
Material and Finish
Side entry type
Post: Brass, copper-undercoated, tin-plated (reflow treatment)
Wafer: PA 66, UL94V-0, natural (white)
4.8
6
6.25
1.7
B
RoHS compliance This product displays (LF)(SN) on a label.
2
1.95
2
0.5
A
Circuit
No.1
1.6
ex.
3.4
B2B-PH-K-ooS…natural (white)
E…blue Y…yellow L…lemon yellow M…green
O…orange N…brown P…purple PK…pink H…gray
LE…light blue FY…vivid yellow (blank)…ivory
PH CONNECTOR
Through-hole type shrouded header〈Low insertion force type〉
Top entry type
Circuits
(2 circuits)
2
3
4.5
B
4
4.5
1.7
B
5
1.7
6
6
6
7
8
9
1.95 A
Circuit
No.1
3.4
3.4
10
11
12
0.5
2
0.5
1.95
13
Circuit No.1
A
14
15
Side entry type
16
Model No.
B2B-PH-KL S2B-PH-KL
B3B-PH-KL S3B-PH-KL
B4B-PH-KL S4B-PH-KL
B5B-PH-KL S5B-PH-KL
B6B-PH-KL S6B-PH-KL
B7B-PH-KL S7B-PH-KL
B8B-PH-KL S8B-PH-KL
B9B-PH-KL S9B-PH-KL
B10B-PH-KL S10B-PH-KL
B11B-PH-KL S11B-PH-KL
B12B-PH-KL S12B-PH-KL
B13B-PH-KL S13B-PH-KL
B14B-PH-KL S14B-PH-KL
B15B-PH-KL S15B-PH-KL
B16B-PH-KL S16B-PH-KL
Q'ty / box
2.0
5.9
1,000
1,000
4.0
7.9
1,000
1,000
6.0
9.9
1,000
500
8.0
11.9
1,000
500
10.0
13.9
1,000
500
12.0
15.9
500
500
14.0
17.9
500
250
16.0
19.9
500
250
18.0
21.9
500
250
20.0
23.9
500
250
22.0
25.9
400
250
24.0
27.9
250
250
26.0
29.9
250
200
28.0
31.9
250
200
30.0
33.9
250
200
Material and Finish
4.8
Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment)
Wafer: PA 66, UL94V-0, gray
1.7
B
Dimensions (mm)
A
B
6
6.25
0.5
A
Circuit
No.1
ex.
3.4
1.6
2
1.95
B2B-PH-KL-oo(blank)…gray
R…red E…blue S…natural (white)
SMT type shrouded header
Model No.
Top entry type
Circuits
Top entry type
Side entry type
B2B-PH-SM4-TB
B3B-PH-SM4-TB
B4B-PH-SM4-TB
B5B-PH-SM4-TB
B6B-PH-SM4-TB
B7B-PH-SM4-TB
B8B-PH-SM4-TB
B9B-PH-SM4-TB
B10B-PH-SM4-TB
B11B-PH-SM4-TB
B12B-PH-SM4-TB
B13B-PH-SM4-TB
B14B-PH-SM4-TB
B15B-PH-SM4-TB
B16B-PH-SM4-TB
S2B-PH-SM4-TB
S3B-PH-SM4-TB
S4B-PH-SM4-TB
S5B-PH-SM4-TB
S6B-PH-SM4-TB
S7B-PH-SM4-TB
S8B-PH-SM4-TB
S9B-PH-SM4-TB
S10B-PH-SM4-TB
S11B-PH-SM4-TB
S12B-PH-SM4-TB
S13B-PH-SM4-TB
S14B-PH-SM4-TB
S15B-PH-SM4-TB
B
2.975
2
(2)
5
A
3
1.9
2
4
6.6
5
6
7
8
Circuit No.1
1.4
2.2
9
10
11
Side entry type
12
13
2.4
14
5.5
15
16
Dimensions (mm)
B
A
Q'ty /
reel
2.0
7.95
7.9
1,000
4.0
9.95
9.9
1,000
6.0
11.95
11.9
1,000
8.0
13.95
13.9
1,000
10.0
15.95
15.9
1,000
12.0
17.95
17.9
1,000
14.0
19.95
19.9
1,000
16.0
21.95
21.9
1,000
18.0
23.95
23.9
1,000
20.0
25.95
25.9
1,000
22.0
27.95
27.9
1,000
24.0
29.95
29.9
1,000
26.0
31.95
31.9
1,000
28.0
33.95
33.9
1,000
30.0
35.95
1,000
Material and Finish
Circuit No.1
2.95
1.6
2
A
6
Wafer: PA, UL94V-0, natural (ivory)
Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment)
(2.6)
B
Note: Contact JST for the top entry type headers with suction cap.
ex.
B2B-PH-SM4-oo-TB
(blank)…natural (ivory)
R…red E…blue M…green L…lemon yellow K…black
DPK...dark pink
3
