4.1
Electrical Installation
Wire Connectors
Connectors
HelaCon Plus
HelaCon connectors are used for fast, easy and reliable connection
and distribution of cable and conductors in electrical installation
applications.
Features and Benefits
• Sophisticated push-in wire connector
• For professional cable connections in electrical installations
• Double spring for easy assembly
• Supports installers in difficult situations like overhead work
• Correct installation can be visually checked through transparent
housing
• Different colour codes for easy identification of size
• Separate voltage test entry on front
• Safe application, installation and maintenance
Connectors of the HelaCon Plus family offering multiple sizes and colours.
One Step to the Web!
MATERIAL
Polycarbonate (PC)
Max Current
24 A
Max Voltage
450 V
Wire Range (VDE)
0.5 to 2.5 mm² solid / stranded
(max. 7 cores)
Stripping Length
11 mm
Flammability
UL94 V2
Operating Temperature
-30 °C to +105 °C
Specifications
CE, cULus, DEMKO, ENEC, FIMKO, GL,
KEMA-KEUR, NEMKO, SEMKO, VDE
For product specific approvals and specifications
please refer to the Appendix.
356
Further information at www.HellermannTyton.com/installation
Date of issue: October 2015
A huge variety of connectors from 2 to 8 poles is available according to the
application. The transparent housings allow a quick and easy checking of the
conductor fitting.
Wire Connectors
4.1
Connectors
HelaCon Plus
HelaCon Plus wire connector
front view
TYPE
HelaCon Plus wire connector side view
Drawing
Number of
Conductors
Colour
Width
(W)
Height
(H)
Depth
(D)
Pack
Cont.
Article-No.
HECP-2
2
Transparent (CL),
Yellow (YE)
11.8
10.5
19.0
100 pcs.
148-90000
HECP-3
3
Transparent (CL),
Orange (OG)
15.9
10.5
19.0
100 pcs.
148-90001
HECP-4
4
Transparent (CL)
20.1
10.5
19.0
75 pcs.
148-90002
HECP-5
5
Transparent (CL),
Blue (BU)
24.2
10.5
19.0
50 pcs.
148-90003
HECP-6
6
Transparent (CL),
Violet (VT)
28.4
10.5
19.0
50 pcs.
148-90004
HECP-8
8
Transparent (CL),
Grey (GY)
36.7
10.5
19.0
40 pcs.
148-90005
All dimensions in mm. Subject to technical changes.
Minimum Order Quantity (MOQ) may differ from package content.
357
很抱歉,暂时无法提供与“148-90000”相匹配的价格&库存,您可以联系我们找货
