148-90001
148-90001
    HELLERMAN(海尔曼太通)
    CONNINLINETAP12-22AWG
148-90001 数据手册
4.1 Electrical Installation Wire Connectors Connectors HelaCon Plus HelaCon connectors are used for fast, easy and reliable connection and distribution of cable and conductors in electrical installation applications. Features and Benefits • Sophisticated push-in wire connector • For professional cable connections in electrical installations • Double spring for easy assembly • Supports installers in difficult situations like overhead work • Correct installation can be visually checked through transparent housing • Different colour codes for easy identification of size • Separate voltage test entry on front • Safe application, installation and maintenance Connectors of the HelaCon Plus family offering multiple sizes and colours. One Step to the Web! MATERIAL Polycarbonate (PC) Max Current 24 A Max Voltage 450 V Wire Range (VDE) 0.5 to 2.5 mm² solid / stranded (max. 7 cores) Stripping Length 11 mm Flammability UL94 V2 Operating Temperature -30 °C to +105 °C Specifications CE, cULus, DEMKO, ENEC, FIMKO, GL, KEMA-KEUR, NEMKO, SEMKO, VDE For product specific approvals and specifications please refer to the Appendix. 356 Further information at www.HellermannTyton.com/installation Date of issue: October 2015 A huge variety of connectors from 2 to 8 poles is available according to the application. The transparent housings allow a quick and easy checking of the conductor fitting. Electrical Installation Wire Connectors 4.1 Connectors HelaCon Plus HelaCon Plus wire connector front view TYPE HelaCon Plus wire connector side view Drawing Number of Conductors Colour Width (W) Height (H) Depth (D) Pack Cont. Article-No. HECP-2 2 Transparent (CL), Yellow (YE) 11.8 10.5 19.0 100 pcs. 148-90000 HECP-3 3 Transparent (CL), Orange (OG) 15.9 10.5 19.0 100 pcs. 148-90001 HECP-4 4 Transparent (CL) 20.1 10.5 19.0 75 pcs. 148-90002 HECP-5 5 Transparent (CL), Blue (BU) 24.2 10.5 19.0 50 pcs. 148-90003 HECP-6 6 Transparent (CL), Violet (VT) 28.4 10.5 19.0 50 pcs. 148-90004 HECP-8 8 Transparent (CL), Grey (GY) 36.7 10.5 19.0 40 pcs. 148-90005 Date of issue: October 2015 All dimensions in mm. Subject to technical changes. Minimum Order Quantity (MOQ) may differ from package content. For product specific approvals and specifications please refer to the Appendix. Further information at www.HellermannTyton.com/installation 357
148-90001 价格&库存
很抱歉,暂时无法提供与“148-90001”相匹配的价格&库存,您可以联系我们找货
