EMPCB.SMAFSTJ.B.HT
EMPCB.SMAFSTJ.B.HT
    TAOGLASLIMITED
    SMD
    射频和同轴连接器 立贴 SMA连接器插孔 母插座50Ω
EMPCB.SMAFSTJ.B.HT 数据手册
SPECIFICATION Part No. : EMPCB.SMAFSTJ.B.HT Product Name : SMA (F) Jack For Edge PCB Mount Feature : SMA(F) Jack Straight Edge Mount PCB Jack Frequency Range: 12.4GHz Finish: Gold Leg Length: 3.8mm Total Length: 13.3mm RoHS Compliant SPE-12-8-134/B/WY Page 1 of 4 1. Introduction The EMPCB.SMAFSTJ.B.HT connector was designed to be mounted on a PCB edge. The edge mount configuration allows the connector to be easily slotted onto a PCB board; the maximum thickness of PCB that the connector can be used with is 0.8mm. The connector pin is directly soldered onto pads on the PCB. The connector is a standard SMA (F) Jack. The SMA connector is the most popular type connector for RF applications. Taoglas connectors are all RoHS compliant. 2. Specification ELECTRICAL Impedance 50Ω Frequency Range 0~12.4 GHz Working Voltage Max. 335 Vrms Insulation Resistance Min. 5000M ohms MECHANICAL Connector Dimension 6.35 X 6.35 X13.3 mm Max. Thickness PCB acceptable 0.8 mm Connector Pin Diameter 0.76 mm Connector Type SMA (F) to PCB Edge Mounted ENVIRONMENTAL RoHS compliant Operating Temperature -40°C to +85°C SPE-12-8-134/B/WY Page 2 of 4 3. Connector Drawing Name Material Finish QTY 1 Body Brass Gold 1 2 Pin Brass Gold 1 3 Insulator Teflon White 1 SPE-12-8-134/B/WY Page 3 of 4 3.1 Footprint Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-12-8-134/B/WY Page 4 of 4
EMPCB.SMAFSTJ.B.HT 价格&库存
很抱歉,暂时无法提供与“EMPCB.SMAFSTJ.B.HT”相匹配的价格&库存,您可以联系我们找货
EMPCB.SMAFSTJ.B.HT
  • 1+33.800701+4.39307
  • 10+28.7279210+3.73377
  • 25+26.9261525+3.49959
  • 50+25.6392250+3.33233
  • 100+24.41505100+3.17322
  • 250+22.88586250+2.97448
  • 500+21.79356500+2.83251
  • 1000+20.754051000+2.69740
  • 2500+19.455832500+2.52867
库存:7654
EMPCB.SMAFSTJ.B.HT
    • 1+7.80840
    • 200+3.02400
    • 500+2.91600
    • 1000+2.86200
