142-1711-016
142-1711-016
    CINCH
    SMA
142-1711-016 数据手册
50 Ohm SMA 2-Hole Right Angle Flange Mount Jack Receptacle Extended Dielectric 90° Orientation INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST GOLD PLATED NICKEL PLATED 142-1711-011 142-1711-016 Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com SMA - 50 Ohm Connectors Specifications INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST ELECTRICAL RATINGS Impedance: 50 ohms Frequency Range: Dummy loads .......................................................................... 0-2 GHz Flexible cable connectors ................................................... 0-12.4 GHz Uncabled receptacles, RA semi-rigid and adapters ........... 0-18.0 GHz Straight semi-rigid cable connectors and field replaceable connectors ............................................... 0-26.5 GHz VSWR: (f = GHz) Straight Right Angle Cabled Connectors Cabled Connectors RG-178 cable .............................. 1.20 + .025f 1.20 + .03f RG-316, LMR-100 cable .............. 1.15 + .02f 1.15 + .03f RG-58, LMR-195 cable ................ 1.15 + .01f 1.15 + .02f RG-142 cable ............................... 1.15 + .01f 1.15 + .02f LMR-200, LMR-240 cable ............ 1.10 + .03f 1.10 + .06f .086 semi-rigid ............................ 1.07 + .008f 1.18 + .015f .141 semi-rigid (w/contact) .......... 1.05 + .008f 1.15 + .015f .141 semi-rigid (w/o contact) ...... 1.035 + .005f Jack-bulkhead jack adapter and plug-plug adapter ................. 1.05 + .01f Jack-jack adapter and plug-jack adapter ............................... 1.05 + .005f Uncabled receptacles, dummy loads .................................................. N/A Field replaceable (see page 59) ......................................................... N/A Working Voltage: (Vrms maximum) Connectors for Cable Type Sea Level 70K Feet RG-178 ...................................................................... 170 45 RG-316; LMR-100, 195, 200 ..................................... 250 65 RG-58, RG-142, LMR-240, .086 semi-rigid, uncabled receptacles, .141 semi-rigid w/o contact ... 335 85 .141 semi-rigid with contact and adapters ................. 500 125 Dummy loads ................................................................................. N/A Dielectric Withstanding Voltage: (VRMS minimum at sea level) Connectors for RG-178 ................................................................... 500 Connectors for RG-316; LMR-100, 195, 200 .................................. 750 Connectors for RG-58, RG-142, LMR-240, .086 semi-rigid, field replaceable, uncabled receptacles ...................................... 1000 Connectors for .141 semi-rigid with contact and adapters ............ 1500 Connectors for .141 semi-rigid w/o contact, dummy loads .............. N/A Corona Level: (Volts minimum at 70,000 feet) Connectors for RG-178 ................................................................... 125 Connectors for RG-316; LMR-100, 195, 200 .................................. 190 Connectors for RG-58, RG-142, LMR-240, 086 semi-rigid, uncabled receptacles, .141 semi-rigid w/o contact .......................... 250 Connectors for .141 semi-rigid with contact and adapters .............. 375 Dummy loads ...................................................................................... N/A Insertion Loss: (dB maximum) Straight flexible cable connectors and adapters ...................... 0.06 f (GHz), tested at 6 GHz Right angle flexible cable connectors ......................... 0.15 f (GHz), tested at 6 GHz Straight semi-rigid cable connectors with contact ..... 0.03 f (GHz), tested at 10 GHz Right angle semi-rigid cable connectors ......................... 0.05 f (GHz), tested at 10 GHz Straight semi-rigid cable connectors w/o contact ...... 0.03 f (GHz), tested at 16 GHz Straight low loss flexible cable connectors ................ 0.06 f (GHz), tested at 1 GHz Right Angle low loss flexible cable connectors ................ 0.15 f (GHz), tested at 1 GHz Uncabled receptacles, field replaceable, dummy loads ..................... N/A Insulation Resistance: 5000 megohms minimum Contact Resistance: (milliohms maximum) Initial After Environmental Center contact (straight cabled connectors and uncabled receptacles) ........................... 3.0* 4.0* Center contact (right angle cabled connectors and adapters) .............................. 4.0 6.0 Field replaceable connectors ........................ 6.0 8.0 Outer contact (all connectors) ........................... 2.0 N/A Braid to body (gold plated connectors) ............. 0.5 N/A Braid to body (nickel plated connectors) ........... 5.0 N/A *N/A where the cable center conductor is used as a contact RF Leakage: (dB minimum, tested at 2.5 GHz) Flexible cable connectors, adapters and .141 semi-rigid connectors w/o contact ............................................................. -60 dB Field replaceable w/o EMI gasket .............................................. -70 dB .086 semi-rigid connectors and .141 semi-rigid connectors with contact, and field replaceable with EMI Gasket ................ -90 dB Two-way adapters ...................................................................... -90 dB Uncabled receptacles, dummy loads .............................................. N/A RF High Potential Withstanding Voltage: (Vrms minimum, tested at 4 and 7 MHz) Connectors for RG-178 ................................................................... 335 Connectors for RG-316; LMR-100, 195, 200 .................................. 500 Connectors for RG-58, RG-142, LMR-240, .086 semi-rigid, .141 semi-rigid cable w/o contact, uncabled receptacles .............. 670 Connectors for .141 semi-rigid with contact and adapters ............ 1000 Power Rating (Dummy Load): 0.5 watt @ + 25°C, derated to 0.25 watt @ +125°C MECHANICAL RATINGS Engagement Design: MIL-C-39012, Series SMA Engagement/Disengagement Force: 2 inch-pounds maximum Mating Torque: 7 to 10 inch-pounds Bulkhead Mounting Nut Torque: 15 inch-pounds Coupling Proof Torque: 15 inch-pounds minimum Coupling Nut Retention: 60 pounds minimum Contact Retention: 6 lbs. minimum axial force (captivated contacts) 4 inch-ounce minimum torque (uncabled receptacles) ENVIRONMENTAL RATINGS Temperature Range: - 65°C to + 165°C Thermal Shock: MIL-STD-202, Method 107, Condition B Corrosion: MIL-STD-202, Method 101, Condition B Cable Retention: Axial Force*(lbs) Torque (in-oz) Connectors for RG-178 ............................ 10 N/A Connectors for RG-316, LMR-100 ........... 20 N/A Connectors for LMR-195, 200 .................. 30 N/A Connectors for RG-58, LMR-240 ............. 40 N/A Connectors for RG-142 ............................ 45 N/A Connectors for .086 semi-rigid ................. 30 16 Connectors for .141 semi-rigid ................. 60 55 *Or cable breaking strength whichever is less. Durability: 500 cycles minimum 100 cycles minimum for .141 semi-rigid connectors w/o contact (Meets or exceed the applicable paragraph of MIL-C-39012) Shock: MIL-STD-202, Method 213, Condition I Vibration: MIL-STD-202, Method 204, Condition D Moisture Resistance: MIL-STD-202, Method 106 †Avoid user injury due to misapplication. See safety advisory definitions inside front cover. Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
142-1711-016 价格&库存
很抱歉,暂时无法提供与“142-1711-016”相匹配的价格&库存,您可以联系我们找货
  • 8+178.89847
  • 18+175.60126
  • 36+172.28771
  • 72+169.00682
库存:80
