Product data sheet
21 03 881 1830
M12 PushPull 8-pole X-coded male
Part number
21 03 881 1830
Specification
HARTING eCatalogue
https://b2b.harting.com/21038811830
Image is for illustration purposes only. Please refer to product description.
Identification
Category
Connectors
Series
Circular connectors M12
Identification
PushPull
Element
Cable connector
Specification
Straight
Version
Termination method
Crimp termination
Gender
Male
Locking type
PushPull
Shielding
Shielded
Number of contacts
8
Coding
X-coding
Details
Please order crimp contacts separately.
Details
For Ethernet applications up to 10 Gbit only
Technical characteristics
Conductor cross-section
0.08 ... 0.25 mm²
AWG 28 ... AWG 23
Wire outer diameter
≤1.4 mm
Rated current
0.5 A
Rated voltage
48 V
Rated impulse voltage
0.8 kV
Page 1 / 3 | Creation date 2020-06-07 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to
the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality,
conformity with applicable laws and directives, as well as for the electrical safety in the particular application.
HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany
Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com
Product data sheet
21 03 881 1830
Pollution degree
3
Insulation resistance
>108 Ω
Contact resistance
≤10 mΩ
Ambient temperature
-40 ... +85 °C
Mating cycles
≥500
Degree of protection acc. to IEC 60529
IP65 / IP67 when mated
Cable diameter
5.7 ... 8.8 mm
Transmission characteristics
Cat. 6A Class EA up to 500 MHz
Overvoltage category
III
Isolation group
I (600 ≤ CTI)
Material properties
Material (insert)
Liquid crystal polymer (LCP)
Material (hood/housing)
Zinc die-cast
RoHS
compliant with exemption
RoHS exemptions
6(a) / 6(a)-I: Lead as an alloying element in steel for machining purposes and
in galvanised steel containing up to 0,35 % lead by weight / Lead as an alloying
element in steel for machining purposes containing up to 0,35 % lead by weight
and in batch hot dip galvanised steel components containing up to 0,2 % lead by
weight
6(c): Copper alloy containing up to 4 % lead by weight
ELV status
China RoHS
50
REACH Annex XVII substances
No
REACH ANNEX XIV substances
No
REACH SVHC substances
Yes
Lead
Specifications and approvals
Specifications
IEC 61076-2-109
UL / CSA
UL 2238 CYJV2.E302521
CSA-C22.2 No. 182.3 CYJV8.E302521
PROFINET
Yes
Commercial data
Packaging size
1
Page 2 / 3 | Creation date 2020-06-07 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to
Product data sheet
21 03 881 1830
Commercial data
Net weight
43 g
Country of origin
Romania
European customs tariff number
85366990
eCl@ss
27440102 Circular connector (for field assembly)
Page 3 / 3 | Creation date 2020-06-07 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the
很抱歉,暂时无法提供与“21038811830”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+461.041401+58.71960
- 10+403.9345010+51.44630
- 25+378.6755025+48.22920
- 50+367.8302050+46.84790
- 100+350.32610100+44.61860
- 250+321.90680250+40.99900
- 国内价格
- 1+392.26842
- 5+385.40570
- 25+378.32429
