EM211504H
EM211504H
    EATON(伊顿)
    P=5mm
    接线端子 间距:5.00mm 1x4P 自由悬挂
EM211504H 数据手册
EuroMag Series PCB Mount Pluggable Terminal Blocks Terminal Blocks: Single Row Series EM2115 Series Pluggable Terminal Block with Flanges; (Mates with EM2215 Series);5.00 Centers SPECIFICATIONS: Rating: 16A, 300V Center Spacing: 0.197" (5.00mm) Wire Range: #12-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Phosphor Bronze Screw Size: M2.6 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -55°C (-67°F) min. Torque Rating: 7.0 lb-in. Construction: Mold-to-Length Agency Information: File E62622; CE Certified L (mm) L (Inch) 2 3 4 5 6 7 8 9 10 11 12 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 70.0 0.787 0.984 1.181 1.378 1.575 1.772 1.969 2.165 2.362 2.559 2.756 13 14 15 16 17 18 19 20 21 22 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 2.952 3.149 3.346 3.543 3.740 3.937 4.133 4.330 4.527 4.724 0.71" (18.00) L 0.32" (8.20) 0.59" (15.0) Ø.11" (2.70) 0.10" (2.50) 0.197" (5.00) VERTICAL 0.39" (9.80) Ø.11" (2.70) 0.49" (12.5) L 0.197" (5.00) 0.10" (2.50) 1.02" (25.8) WIRE ENTRY WIRE ENTRY LEFT Part Numbering System En Mn 2n 1n 1n 5 n Series nn # of Poles 02 to 22 1.02" (25.8) 0.32" (8.20) 0.32" (8.20) RIGHT Inches (Millimeters) n Orientation V - Vertical H - Horizontal n Wire Entry Mating Header: EM2215 pg. 95 L - Left wire entry R - Right wire entry (specify for V orientation) For additional product information, visit www.eaton.com/connectors EuroMag Series Poles HORIZONTAL Compliance References L (Inch) Dimensions - in (mm) Edge Connectors, One-Sided Boards L (mm) Plug & Header Poles EM211514VL 93
EM211504H 价格&库存
很抱歉,暂时无法提供与“EM211504H”相匹配的价格&库存,您可以联系我们找货
