M55 Sect 3 p59 10-23m
10/24/06
11:46 AM
Page 59
PLUGGABLE WITH PIN STRIPS
supplied in strips of 24. Simply snap off the desired number of
positions required and insert into PC board. The modular
terminal block can be plugged into the header strip at anytime.
• Space saving low profile design
• Easy access horizontal wire entry
• Convenient screw head access on top of terminal block
• Headers mount easily in pre-drilled or stamped holes
• Wire guards help prevent damage to conductors
• Accepts #22-16 AWG wire
• Because of accumulating tolerances, we
recommend a maximum of 24 positions per row
• Header strips and terminal blocks sold separately
SPECIFICATIONS
MATERIAL:
ELECTRICAL:
MECHANICAL:
Contact: Brass, Tin Plate
Header Pins: Brass, Tin Plate
Housing: Blue PBT, UL Rated 94V-0
Screw: Steel, Zinc Plate & Clear
Chromate (captivated)
Dielectric Strength: 2500V
Insulation Breakdown: 1500V AC/min.
Rated voltage: 250V
Operating Temp:
22°F to 248°F (-30°C to 120°C)
Peak Temp: +393°F (+200°C)
HORIZONTAL ENTRY
• Use header strip to connect to PCB
A
.375 [9.5]
.051 [1.30]
.024
[0.61]
.073
[1.9]
.473
[12.0]
.394
[10.0]
.069
[1.75]
.268 [6.8]
.148
[3.8]
.138 [3.5]
.138 [3.5]
.039 [0.99]
8723
8722
Recommended Mtg. Hole Size: .047(1.19)
CAT.
NO.
8722
8723
3.5mm SPACING
A
CURRENT
POSITIONS
DIM.
RATING
2
.276 (7.0)
6 Amps
3
.413 (10.5)
Pin Header Strips
(24 pins per strip)
8724
CAT. NO. 8724
HORIZONTAL ENTRY
.531 [13.5]
A
.028 [0.71]
.078
[2.0]
.502
[12.8]
.436
[11.1]
.358 [9.1]
.197 [5.0]
.098 [2.5]
.148
[3.8]
.197 [5.0]
8726
8725
.051 [1.30]
Recommended Mtg. Hole Size: .059 (1.50)
CAT.
NO.
8725
8726
5mm SPACING
A
CURRENT
POSITIONS
DIM.
RATING
2
.394 (10.0)
10 Amps
3
.591 (15.0)
Pin Header Strips
(24 pins per strip)
8727
CAT. NO. 8727
NOTES
Tel (718) 956-8900 • Fax (718) 956-9040
(800) 221-5510 • kec@keyelco.com
RoHS COMPLIANT ~ ISO 9001 CERTIFIED
www.keyelco.com
31-07 20th Road – Astoria, NY 11105-2017
MODULAR INTERLOCKING PC TERMINAL BLOCKS
These unique modular terminal blocks are convenient and easy to
use. They may be interlocked to achieve the required number of
positions.The header pins, for both the 6 and 10 Amp models are
59
很抱歉,暂时无法提供与“8723”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+23.814871+3.07218
- 10+18.4333310+2.37795
- 国内价格 香港价格
- 58+21.8417058+2.81764
- 国内价格 香港价格
- 15+54.9368915+7.08700
- 25+42.2589025+5.45151
- 国内价格 香港价格
- 58+22.2129458+2.86553
