RC0805FR-077K68L
RC0805FR-077K68L
    YAGEO(国巨)
    贴片电阻 0805 7.68KΩ ±1% 1/8W ±100ppm/℃
RC0805FR-077K68L 数据手册
DATA SHEET GENERAL PURPOSE CHIP RESISTORS RC0805 (Pb Free) Product specification – Sep 03, 2004 V.2 5%; 1% Product specification Chip Resistor Surface Mount RC SERIES 2 10 0805 (Pb Free) SCOPE This specification describes RC0805 series chip resistors with lead-free terminations made by thick film process. ORDERING INFORMATION Part number is identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. YAGEO ORDERING CODE CTC ORDERING EXAMPLE CODE RC0805 X X X XX XXXX L (1) (2) (3) (4) (5) (6) (1) TOLERANCE F = ±1% J = ±5% (2) PACKAGING TYPE R = Paper/PE taping reel (3) TEMPERATURE COEFFICIENT OF RESISTANCE – = Base on spec The ordering code of a RC0805 chip resistor, value 56 X with ±1% tolerance, supplied in 7-inch tape reel is: RC0805FR-0756RL. NOTE 1. The “L” at the end of the code is only for ordering. On the reel label, the standard CTC will be mentioned an additional stamp “LFP”= lead free production. 2. Products with lead in terminations fulfil the same requirements as mentioned in this datasheet. 3. Products with lead in terminations will be phased out in the coming months (before July 1st, 2006) (4) TAPING REEL 07 = 7 inch dia. Reel 10 = 10 inch dia. Reel (not preferred) 13 = 13 inch dia. Reel (5) RESISTANCE VALUE 5R6, 56R, 560R, 5K6, 56K, 22M. (6) RESISTOR TERMINATIONS L = Lead free terminations (pure Tin) www.yageo.com Sep 03, 2004 V.2 Product specification Chip Resistor Surface Mount RC SERIES 3 10 0805 (Pb Free) MARKING RC0805 E-24 series: 3 digits ynsc001 Fig. 1 Value=10 KΩ First two digits for significant figure and 3rd digit for number of zeros Both E-24 and E-96 series: 4 digits ynsc004 Fig. 2 Value=10 KΩ First three digits for significant figure and 4th digit for number of zeros For marking codes, please see EIA-marking code rules in data sheet “Chip resistors instruction”. CONSTRUCTION The resistors are constructed out of a high-grade ceramic body. Internal handbook, 4 columns metal electrodes are added at each end and connected by a resistive H paste. The composition of the paste is adjusted to give the approximate I2 required resistance and laser cutting of this resistive layer that achieves Fig. 3 Chip resistor construction tolerance trims the value. The resistive layer is covered with a protective coat and printed with the resistance value. Finally, the two external terminations (pure Tin) are added. See fig. 3. protective coat resistor layer inner electrode end termination ceramic substrate MBE940_a DIMENSIONS Table 1 TYPE protective coat RC0805 L (mm) 2.00 ±0.10 W (mm) 1.25 ±0.10 H (mm) 0.50 ±0.10 I1 (mm) 0.35 ±0.20 I2 (mm) 0.35 ±0.20 I1 W MBE940_a L Fig. 4 Chip resistor dimension For dimension see Table 1 www.yageo.com Sep 03, 2004 V.2 Product specification Chip Resistor Surface Mount RC SERIES ELECTRICAL CHARACTERISTICS FOOTPRINT AND SOLDERING PROFILES Table 2 RC0805 1/8 W CHARACTERISTICS Operating Temperature Range –55 °C to +155 °C Maximum Working Voltage 150 V Maximum Overload Voltage 300 V Dielectric Withstanding Voltage 300 V 5% (E24) 1 Ω to 22 MΩ Resistance Range 1% (E96) 1 Ω to 10 MΩ Zero Ohm Jumper < 0.05 Ω Temperature Coefficient Jumper Criteria 4 10 0805 (Pb Free) 10 Ω < R ≤ 10 MΩ ±100 ppm/°C R ≤ 10 Ω; R > 10 MΩ ±200 ppm/°C Rated Current 2.0 A Maximum Current 5.0 A For recommended footprint and soldering profiles, please see the special data sheet “Chip resistors mounting”. ENVIRONMENTAL DATA For material declaration information (IMDS-data) of the products, please see the separated info “Environmental data”. PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PRODUCT TYPE PACKING STYLE REEL DIMENSION RC0805 Paper / PE Taping Reel (R) 7" (178 mm) QUANTITY PER REEL 5,000 units 10" (254 mm) / not preferred 10,000 units 13" (330 mm) 20,000 units NOTE 1. For Paper/PE tape and reel specification/dimensions, please see the special data sheet “Packing” document. www.yageo.com Sep 03, 2004 V.2 Product specification Chip Resistor Surface Mount RC SERIES 5 10 0805 (Pb Free) FUNCTIONAL DESCRIPTION POWER RATING MRA632 Pmax (%Prated) RC0805 rated power at 70°C is 1/8 W RATED VOLTAGE 100 The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: 50 V=√(P X R) 0 −55 0 155 100 Tamb (°C) 50 70 Where V=Continuous rated DC or AC (rms) working voltage (V) Fig. 5 Maximum dissipation (Pmax) in percentage of rated power as a function of the operating ambient temperature (Tamb ) P=Rated power (W) R=Resistance value (X) PULSE LOADING CAPABILITIES MBD587 10 4 Vmax (V) 10 1.2/50 µs 3 10/700 µs 10 2 10 10 10 2 10 3 10 4 10 5 10 6 R n (Ω) 10 7 Fig. 6 Maximum permissible peak pulse voltage without failing to open circuit’ in accordance with DIN IEC 60040 (CO) 533 for type: RC0805 www.yageo.com Sep 03, 2004 V.2 Product specification Chip Resistor Surface Mount RC SERIES 6 10 0805 (Pb Free) MBD588 10 3 P max (W) 10 2 10 single pulse t p /t i =1000 1 10 1 10 6 10 5 10 4 10 3 10 2 10 1 1 t i (s) Fig. 7 Pulse on a regular basis for type: RC0805; maximum permissible peak pulse power as a function of pulse duration for single pulse and repetitive pulse tp/ti = 1000 MLB722 600 Vmax (V) 400 200 0 10 6 10 5 10 4 10 3 10 2 10 1 t i (s) 1 Fig. 8 Pulse on a regular basis for type: RC0805; maximum permissible peak pulse voltage as a function of pulse duration www.yageo.com Sep 03, 2004 V.2 Product specification Chip Resistor Surface Mount RC 7 10 0805 (Pb Free) SERIES TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST Temperature Coefficient of Resistance (T.C.R.) TEST METHOD PROCEDURE REQUIREMENTS MIL-STD-202F-method 304; At +25/–55 °C and +25/+125 °C Refer to table 3 JIS C 5202-4.8 Formula: R2–R1 T.C.R= ------------------------×106 (ppm/°C) R1(t2–t1) Where t1=+25 °C or specified room temperature t2=–55 °C or +125 °C test temperature R1=resistance at reference temperature in ohms R2=resistance at test temperature in ohms Thermal Shock MIL-STD-202F-method 107G; IEC 60115-1 4.19 Low Temperature Operation MIL-R-55342D-Para 4.7.4 Short Time Overload MIL-R-55342D-Para 4.7.5; At –65 (+0/–10) °C for 2 minutes and at +155 (+10/–0) °C for 2 minutes; 25 cycles ±(0.5%+0.05 Ω) for 1% tol. At –65 (+0/–5) °C for 1 hour; RCWV applied for 45 (+5/–0) minutes ±(0.5%+0.05 Ω) for 1% tol . ±(1.0%+0.05 Ω) for 5% tol. ±(1.0%+0.05 Ω) for 5% tol. No visible damage IEC 60115-1 4.13 2.5 × RCWV applied for 5 seconds at room temperature ±(1.0%+0.05 Ω) for 1% tol. ±(2.0%+0.05 Ω) for 5% tol. No visible damage Insulation Resistance MIL-STD-202F-method 302; RCOV for 1 minute IEC 60115-1 4.6.1.1 Type Voltage (DC) Dielectric Withstand Voltage ≥10 GΩ RC0805 300 V MIL-STD-202F-method 301; Maximun voltage (Vrms) applied for 1 minute IEC 60115-1 4.6.1.1 Type RC0805 Voltage (AC) 300 Vrms Resistance to Soldering Heat MIL-STD-202F-method 210C; Life MIL-STD-202F-method 108A; IEC 60115-1 4.18 Unmounted chips; 260 ±5 °C for 10 ±1 seconds No breakdown or flashover ±(0.5%+0.05 Ω) for 1% tol. ±(1.0%+0.05 Ω) for 5% tol. No visible damage IEC 60115-1 4.25.1 At 70±2 °C for 1,000 hours; RCWV applied for 1.5 hours on and 0.5 hour off ±(1%+0.05 Ω) for 1% tol. ±(3%+0.05 Ω) for 5% tol. www.yageo.com Sep 03, 2004 V.2 Product specification Chip Resistor Surface Mount TEST Solderability Bending Strength Resistance to Solvent Noise RC SERIES TEST METHOD PROCEDURE REQUIREMENTS MIL-STD-202F-method 208A; Solder bath at 245±3 °C Well tinned (≥95% covered) IEC 60115-1 4.17 Dipping time: 2±0.5 seconds No visible damage Resistors mounted on a 90 mm glass epoxy resin PCB (FR4) ±(1.0%+0.05 Ω) for 1% tol. Bending: 5 mm No visible damage No smeared IEC 60115-1 4.29 lsopropylalcohol (C3H7OH) or dichloromethane (CH2Cl2) followed by brushing JIS C 5202 5.9; Maximum voltage (Vrms) applied. Resistors range Value R < 100 Ω 10 dB 100 Ω ≤ R < 1 KΩ 20 dB 1 KΩ ≤ R < 10 KΩ 30 dB 10 KΩ ≤ R < 100 KΩ 40 dB 100 KΩ ≤ R < 1 MΩ 46 dB 1 MΩ ≤ R ≤ 22 MΩ 48 dB JIS C 5202.6.14; IEC 60115-1 4.15 MIL-STD-202F-method 215; IEC 60115-1 4.12 Humidity (steady state) Leaching Intermittent Overload Resistance to Vibration Moisture Resistance Heat 8 10 0805 (Pb Free) ±(1.0%+0.05 Ω) for 5% tol. JIS C 5202 7.5; 1,000 hours; 40±2 °C; 93(+2/–3)% RH IEC 60115-8 4.24.8 ±(0.5%+0.05 Ω) for 1% tol. RCWV applied for 1.5 hours on and 0.5 hour off ±(2.0%+0.05 Ω) for 5% tol. EIA/IS 4.13B; Solder bath at 260±5 °C No visible damage IEC 60115-8 4.18 Dipping time: 30±1 seconds JIS C 5202 5.8 At room temperature; 2.5 × RCWV applied for 1 second on and 25 seconds off; total 10,000 cycles ±(1.0%+0.05 Ω) for 1% tol. ±(2.0%+0.05 Ω) for 5% tol. On request On request MIL-STD-202F-method 106F; 42 cycles; total 1,000 hours ±(0.5%+0.05Ω) for 1% tol. IEC 60115-1 4.24.2 Shown as figure 9 ±(2.0%+0.05Ω) for 5% tol. No visible damage www.yageo.com Sep 03, 2004 V.2 Product specification Chip Resistor Surface Mount 75 RC 80 − 98% RH 90 − 98% RH temperature [°C] SERIES 90 − 98% RH 9 10 0805 (Pb Free) 80 − 98% RH 90 − 98% RH initial drying 24 hours rate of change of temperature is unspecified, however, specimens shall not be subjected to radiant heating from chamber conditioning processes 50 end of final cycle; measurements as specified in 2.7 +10 °C (+18 °F) −2 °C (−3.6 °F) 25 initial measurements as specified in 2.2 0 temperature tolerance ±2 °C (±3.6 °F) unless otherwise specified voltage applied as specified in 2.4 STEP1 STEP2 prior to first cycle only HBK073 optional sub-cycle if specified (2.3); sub-cycle performed during any 5 of the first 9 cycles; humidity uncontrolled during sub-cycle circulation of conditioning air shall be at a minimum cubic rate per minute equivalent to 10 times the volume of the chamber STEP3 STEP4 STEP5 STEP6 STEP7 one cycle 24 hours; repeat as specified in 2.5 0 5 10 15 20 25 time [h] Fig. 9 Moisture resistance test requirements www.yageo.com Sep 03, 2004 V.2 Product specification Chip Resistor Surface Mount RC SERIES 10 10 0805 (Pb Free) REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 2 Sep 03, 2004 - - Test method and procedure updated - PE tape added (paper tape will be replaced by PE tape) www.yageo.com Sep 03, 2004 V.2
RC0805FR-077K68L
物料型号:RC0805系列,这是YAGEO公司生产的表面贴装芯片电阻器。
器件简介:RC0805系列芯片电阻器采用无铅端接,由厚膜工艺制造,具有优良的电气特性和可靠性。
引脚分配:文档中没有明确指出引脚分配,但通常这类电阻器为两个端接点,用于连接电路。
参数特性: - 尺寸:长2.00mm±0.10mm,宽1.25mm±0.10mm,高0.50mm±0.10mm。 - 电阻值范围:5%(E24系列)1Ω至22MΩ;1%(E96系列)1Ω至10MΩ。 - 公差:±1%和±5%。 - 温度系数:根据规格而定。 - 额定功率:在70°C时为1/8W。
功能详解: - 电阻器由高等级陶瓷基体、内部金属电极和电阻浆料构成,通过激光切割调整电阻值。 - 电阻器表面覆盖有保护层,并印有标记代码,以指示电阻值。
应用信息:适用于一般电子设备中的电阻作用,如电源电路、信号处理等。
封装信息:RC0805封装,提供7英寸、10英寸和13英寸的卷轴包装,其中7英寸卷轴每卷5000个单位,10英寸卷轴每卷10000个单位(不推荐),13英寸卷轴每卷20000个单位。
环境数据:有关材料声明信息(IMDS数据),请参考单独的环境数据信息。
测试和要求:文档列出了一系列的测试条件、程序和要求,包括温度系数、热冲击、温度循环、短时间过载、绝缘电阻、耐电压、耐焊接热、寿命、可焊性、弯曲强度、耐溶剂、噪声、稳态湿热、浸出和间歇过载等测试。
RC0805FR-077K68L 价格&库存
很抱歉,暂时无法提供与“RC0805FR-077K68L”相匹配的价格&库存,您可以联系我们找货
RC0805FR-077K68L
  • 1+0.839601+0.10140
  • 10+0.1341010+0.01620
  • 100+0.08400100+0.01020
  • 1000+0.058301000+0.00710
  • 5000+0.033805000+0.00410
  • 100000+0.02570100000+0.00310
库存:27964
RC0805FR-077K68L
  • 50+0.00829
  • 500+0.00753
  • 5000+0.00651
  • 30000+0.00625
  • 90000+0.00600
