SEK
IEC 60 603-13
Number of contacts
6--64
Strain relief clamp/Locking lever
No. of
contacts
Strain relief
clamp
6
10
14
16
26
30
34
40
50
60
64
with bulk packaging
3) Packaging unit
5,000 pieces
4) Packaging unit
3,000 pieces
6
10
14
16
30
34
40
Part number
Drawing
09 18 506 9002
09 18 510 9002
09 18 514 9002
09 18 516 9002
09 18 520 9002
09 18 524 9002
09 18 526 9002
09 18 530 9002
09 18 534 9002
09 18 540 9002
09 18 550 9002
09 18 560 9002
09 18 564 9002
No. of
contacts
6
10
14
16
26
30
34
40
50
60
64
6
09 18 506 9002 58U3)
09 18 510 9002 58U3) 10
09 18 514 9002 58U3) 14
09 18 516 9002 58U3) 16
09 18 520 9002 58U3) 20
09 18 526 9002 58U3) 26
09 18 530 9002 58U3) 30
09 18 534 9002 58U4) 34
09 18 540 9002 58U4) 40
Locking lever
for female connector
A
12.2
17.3
22.4
24.9
30.0
35.18
37.6
42.7
47.8
55.4
68.1
80.8
85.9
12.2
17.3
22.4
24.9
30.0
37.6
42.7
47.8
55.4
Strain relief clamp
Only in conjunction
with low-profile male header
and strain relief
ackaging unit
P
100 pieces
6) Packaging unit
5,000 pieces
Dimensions in mm
SEK
Identification
09 18 000 99051)5)
09 18 000 9905 58U1)6)
5)
Female connector
Low-profile male header
When the security of latching is required and space is a premium,
these locking levers can be fitted onto the strain relief of the H
ARTING
female connector. This can then be used in c onjunction with male
low-profile headers (see pages 08.14 and 08.15).
Coding system with
loss of contact
Code pin
Removal tool for
male contacts
1)
2)
rder 2 per female connector
O
Part number comprises 6 code pins
09 18 000 99012)
09 99 000 0133
To avoid cross-plugging adjacent connectors a
coding system is required. A code pin is inserted
into the appropriate cavity in the female connector.
The corresponding male contact is removed by a
special removal tool.
08
23
很抱歉,暂时无法提供与“09185609002”相匹配的价格&库存,您可以联系我们找货
