REVISION AG
DO NOT
SCALE FROM
THIS PRINT
FIG 1
(No OF POS x .050 [1.27]) +
.570 [14.48] REF
EHF-1XX-01-XX-D-XX-XX-XX
EHF-110-01-XX-D-SM-LC
OPTION
-LC: LOCKING CLIP (FOR -D-SM ONLY)
(SEE NOTE 7)
-P: PICK & PLACE PAD (FOR -D-SM ONLY)
(FOR -03 & -04, USE PPP-25, SEE FIG 7, SHT 3)
(FOR -05 THRU -25, USE PPP-48, SEE FIG 2)
-K: POLYIMIDE FILM
(USE K-500-300, SEE FIG 3)
-TR: TAPE & REEL PACKAGING
(FOR -D-SM, -D-SM-P, & -D-SM-K ONLY)
(NOT AVAILABLE ON -D-SM-LC)
No OF POSITIONS
-03, -04,-05, -08, -10,
2 MAX SWAY
-13, -17, -20, -25
LEAD STYLE
.100 2.54
.310 7.87 REF
-01
(TYP) REF
(No OF POS - 1)
PLATING SPECIFICATION
.135 3.43
x .050 [1.27]
-L: 10µ" SELECTIVE GOLD IN CONTACT AREA,
REF
REF
MATTE TIN ON TAIL (USE T-1SXX-XX-L)
02
-F: 3µ" SELECTIVE GOLD IN CONTACT AREA,
"A"
MATTE TIN ON TAIL (USE T-1SXX-XX-F)
.263 6.67
-S: 30µ" SELECTIVE GOLD IN CONTACT AREA,
REF
MATTE TIN ON TAIL (USE T-1SXX-XX-S)
XX
-H: 30µ" GOLD IN CONTACT AREA, 3µ" GOLD
"A"
ON TAIL (USE T-1SXX-XX-H)
01
-LM: 10µ" SELECTIVE GOLD IN CONTACT AREA,
.020 0.51
(No OF POS x.050 [1.27])
-SM: 30µ" SELECTIVE GOLD IN CONTACT AREA,
REF
+ .200 [5.08] REF
.05 1.270
-FM: 3µ" SELECTIVE GOLD IN CONTACT AREA,
.016 0.41 REF
EHF-XX-D
POLARIZED OPTION
-XX = PIN OMITTED
(N/A ON -RA OPTION)
TAIL OPTION
(LEAVE BLANK FOR THROUGH HOLE,
SEE FIG 4, SHEET 2, USE T-1S63-01-XX)
-SM: SURFACE MOUNT (USE T-1S15-02-XX)
-RA: RIGHT ANGLE
(USE T-1S63-02-XX AND T-1S63-03-XX)
(SEE FIG 5, SHEET 2)
ROW SPECIFICATION
-D: DOUBLE
+2°
90° - 3°
.325 8.26
REF
.120 3.05 REF
.335 8.51 C
.004[0.10]
T-1S15-02-XX
POS 1 INDICATOR
SECTION "A"-"A"
LC-09-TM
.060 1.52
+ .290 [7.37] REF
NOTES:
.083 2.111
.170 4.318 (TYP)
-SM IN-PROCESS 1
(SCALE: 1.5:1)
-SM IN-PROCESS 2
.084 2.13
90°±3°
.296±.010 7.52±0.25
(SCALE: 1.5:1)
1. C REPRESENTS A CRITICAL DIMENSION.
2. COPLANARITY TO BE WITHIN .004[0.10].
3. MAXIMUM BURR ALLOWANCE: .0015 [0.038].
4. MINIMUM PUSHOUT FORCE: 1 LB.
5. MAXIMUM ALLOWABLE BOW: .002[0.05] INCH/INCH AFTER ASSEMBLY.
6. NOTE DELETED.
7. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, THE –LC OPTION IS NOT
COMPATIBLE WITH AUTO PLACEMENT. SAMTEC RECOMMENDS MANUAL PLACEMENT
FOR ALL ASSEMBLIES WITH THE –LC OPTION.
ARM ASSEMBLY & ROTATION
EHA-02
.180 4.57
.296±.010 7.52±0.25
.200 5.08 REF
FIG 2
CL
.295 7.50 REF
.445 11.31
REF
{(No OF POS X .050[1.27] + .370[9.40]) / 2}
.020[0.51]
PPP-48
CL
-P: PICK AND PLACE PAD
(SCALE 1.5:1)
.293 7.44
REF
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
MATERIAL:
FIG 3
-K: POLYIMIDE FILM
(SCALE: 1.5:1)
ANGLES
.XX: .01[0.3]
2
.XXX: .005[0.13]
.XXXX: .0020[0.051]
{(NO OF POS X .050[1.27] + .275[6.98]) / 2}
.020[0.51]
.260 6.60
REF
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: VECTRA E130i, COLOR BLACK
50% REGRIND
TERMINAL: PHOS BRONZE 510 SPRING
SHEET SCALE: 1.75:1
F:\dwg\sw\exisprod\assembly\050\EHF-1XX-01-XX-D-XX-XX-XX-ASM.SLDDRW
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
DESCRIPTION:
.050 EJECTOR HEADER ASSEMBLY
DWG. NO.
BY: ERIC M.
08/17/01
SHEET 1 OF 3
REVISION AG
02
FIG 4
FIG 5
-RA: RIGHT ANGLE OPTION
(SHOWN: EHF-110-01-XX-D-RA)
(SAME AS FIG 1, UNLESS OTHERWISE STATED)
STANDARD THROUGH HOLE
(SHOWN: EHF-110-01-XX-D)
01
T-1S63-01-XX
"B"
"C"
2 MAX SWAY
(TYP)
T-1S63-03-XX
T-1S63-02-XX
90°±3°
.350 8.89
REF
.120 3.05 REF
C .107 2.72
"B"
SECTION "B"-"B"
.050 1.27
.090 2.29
"C"
SECTION "C"-"C"
C .050 1.27
PACKAGING VIEWS
(LOAD PARTS WITH POSITION #1 INDICATOR
IN SAME DIRECTION AS ARROW ON TUBE)
REF
-RA IN-PROCESS 2
-RA IN-PROCESS 1
.210 5.34
90°±3°
.120 3.05
.120 3.05
.480 12.19
.580 14.73
NOTE: ARROW POINTS INTO THE SHEET AWAY FROM YOU.
PT-1-24-01-51
T-1S63-03-XX
.050 1.27
.180 4.57
PT-1-24-16-29
T-1S63-02-XX
.09 2.3 REF
EJECTOR ARM MUST BE IN UPPRIGHT
POSITION WHEN LOADED INTO TUBES
PROPRIETARY NOTE
SHEET SCALE: 2:1
PT-1-24-05-09
PT-1-24-01-52
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
BY: ERIC M.
08/17/01
SHEET 2 OF 3
REVISION AG
(NO. OF POSITIONS x .050 [1.27])
+.715 [18.16] REF
FIG 6
.343 8.70
REF
-SM: SURFACE MOUNT OPTION
(SHOWN: EHF-110-01-XX-D-SM-LC)
(SHOWN WITH LATCHES OPEN)
.400 10.16
REF (TYP)
R.028 0.70
REF (TYP)
.526 13.36
REF
.097 2.47
REF (TYP)
FIG 8
APPLICATION VIEW
EHF MATED WITH FFSD AND ECF
FIG 7
-03 & -04 PICK AND PLACE PAD
(SHOWN: EHF-104-01-XX-D-SM-XX-P)
.200 5.08
REF
ROUND HOLES
PPP-25
POS 01 INDICATOR
.283 7.19
REF
LATCHES OMITTED FOR CLARITY
OBLONG HOLES
FIG 9
-TR: TAPE & REEL
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
BY: ERIC M.
08/17/01
SHEET 3 OF 3
