HTSW-102-07-F-S
HTSW-102-07-F-S
    SAMTEC(申泰)
    插件,P=2.54mm
    排针 间距:2.54mm 1x2P 直插
HTSW-102-07-F-S 数据手册
REVISION BQ DO NOT SCALE FROM THIS PRINT HTSW-XXX-XX-XXX-X-XX-XX-XX TERMINAL SPACE SPEC -1= .100 [2.54] (FILL EVERY POSITION) -2= .200 [5.08] (FILL EVERY OTHER POSITION STARTING WITH THE 1st AND ENDING WITH THE LAST POSITION IN BODY) OPTION 3 *-MW: METAL WASHER (STRAIGHT TAIL OPTION ONLY) (AVAILABLE ON 05, 06, 07. 08. 16, 17, 18, 22, 23,24, 25, 41 & 42 LEAD STYLES ONLY) (N/A WITH -LC OPTION. 20 POS MIN, 30 POS MAX. SEE FIG 6, SHT 5) NUMBER OF POSITIONS PER ROW -1: -01 THRU -50 "A"= NUMBER OF POS x .100[2.54] -2: -02 THRU -25 "A"= (NUMBER OF POS x .200[5.08])-.100[2.54] OPTION 2 -POLARIZING SPECIFICATION XXX INDICATES POS TO BE OMITTED LEAD STYLE SEE TABLE 1, SHT 6 OPTION 1 -BLANK: STRAIGHT (SEE FIG 1, SHT 2) -RA: RIGHT ANGLE (SEE TABLE 3 & 4, FIG 5, SHT 4)(-RA OPTION WITH -LL OPTION EQUALS TO -LA OPTION) -RE: EXTENDED RIGHT ANGLE (SEE TABLE 3 & 4, FIG 5, SHT 4) (SINGLE ROW ONLY) -NA: RA OPTION WITH STRAIGHT OPTION BODY (SEE TABLE 3 & 4, FIG 5, SHT 4) (-NA OPTION WITH -LL OPTION IS VALID) -NE: RE OPTION WITH STRAIGHT OPTION BODY (SEE TABLE 3 & 4, FIG 5, SHT 4) -LC: LOCKING CLIP (4 POS MINIMUM; ONLY AVAILABLE ON: LEAD STYLES -08 THRU -13 & -22, WITH ROW OPTIONS -S & -D; N/A WITH -MW, -RA OR -RE OPTIONS; SEE FIG 2, SHT 2) -LA: -RA OPTION WITH -LL OPTION (SEE SHT 3) -LL: LOCKING LEAD (SEE FIG 4, SHT 3) (N/A WITH -RE OR -NE OPTIONS) (N/A IN SINGLE ROW, 1 OR 2 POSITIONS) PLATING SPECIFICATIONS -G: 10µ" GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL -T: MATTE TIN CONTACT AND TAIL -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -H: 30µ" HEAVY GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL -L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -F: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -E: 50µ" EXTRA HEAVY GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL (AVAILABLE ON LEAD STYLES -07, -08, -09 STRAIGHT AND -08-D-RA) -TL: TIN/LEAD (90/10 5%) CONTACT AND TAIL, (AVAILABLE ONLY ON LEAD STYLES -07, -08 & -09) -TM: MATTE TIN CONTACT AND TAIL -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -LM: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -FM: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -STL: 30µ" SELECTIVE GOLD IN CONTACT AREA, TIN/LEAD (90/10 5%) TAIL -LTL: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, TIN/LEAD (90/10 +/-5%) TAIL, (AVAILABLE ONLY ON LEAD STYLE -15) -SS: 30µ" STRIPE SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ONTAIL, (SEE NOTE 9) ROW SPECIFICATION (SEE TABLE 2) -S: SINGLE -D: DOUBLE -T: TRIPLE -Q: TRIPLE ROW, FILL OUTER ROWS ONLY * - MW OPTION, DO NOT DESIGN IN. SAMTEC WILL ONLY SUPPORT EXISTING BUSINESS 2/12/02. CRITICAL DIMENSION INSPECTION INSTRUCTION TABLE NOTES: 1. C REPRESENTS CRITICAL DIMENSION FOR STATISTICAL PROCESS CONTROL. 2. MINIMUM TERMINAL PUSHOUT FORCE: 3 LBS. 3. MAXIMUM HEIGHT VARIATION: .005[.127] (N/A ON -RA TAIL). 4. ASSEMBLE GOLD PLATE END AS SHOWN IN FIG 1. 5. STYLE -26: ROUND END OF PIN TO APPEAR ON BOTTOM (SEE FIG 7, SHT 6). 6. MINIMUM GOLD PLATED CONTACT AREA: .165[4.19] REF; PINS -18, -21 & -25: .050[1.27] REF. 7. CRIMP TWO PINS CLOSEST TO CENTER OF THE PART IF THERE IS A POLARIZED POSITION IN THE MIDDLE/CENTER. 8. MAXIMUM CUT FLASH: .010 [.25]. 9. -SS PLATING OPTION ONLY AVAILABLE ON -07, -08, -09 STRAIGHT AND -08 -RA LEAD STYLES. MATES WITH SSQ, SSW, SSM, BCS, ESQ & ESW. 10. MEASURE FROM THE BEND RADIUS OF THE TERMINALS. 11. ORIENTATE PINS TO PREVENT BANDOLIER MARKS FROM SHOWING IN THE POST AREA. (SEE TABLE 6, SHT 7). UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [.25] .XXX: .005 [.13] .XXXX: .0020 [.051] MATERIAL: 2 * ASSEMBLY OPERATION IN-PROCESS INSPECTION FILL C1 MULTI-CUT RIGHT ANGLE C2 C4 RIGHT ANGLE C5 RIGHT ANGLE C6 CRIMP C7 CPCs INTENTIONALLY DELETED: C3 PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3.5:1 INSULATOR: LCP, UL-94-V-0 COLOR: NATURAL 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .025 SQ POST HI-TEMP TERMINAL STRIP ASSEMBLY DWG. NO. HTSW-XXX-XX-XXX-X-XX-XX-XX F:\DWG\MISC\MKTG\HTSW-XXX-XX-XXX-X-XX-XX-XX-MKT.SLDDRW BY: PURVIS 02/17/87 SHEET 1 OF 7 REVISION BQ C +.005 +0.127 "A" - .015 "A" - 0.381 (SEE CALLOUT) TERMINAL SPACING -1XX= .100[2.54] -2XX= .200[5.08] .200 5.08 2 MAX SWAY (EITHER DIRECTION) .025 0.64 SQ REF .100 2.54 C "C" .008[0.20] (SEE TABLE 1, SHT 6) (SEE NOTE 3) 2 MAX SWAY (EITHER DIRECTION) .200 5.08 .100 2.54 MINIMUM GOLD PLATED CONTACT LENGTH (SEE NOTE 6) "L" REF (SEE TABLE 1, SHT 6) .100 2.54 REF 2 MAX SWAY (EITHER DIRECTION) SEE NOTE 5 .198 5.03 REF .0980 2.489 REF 2 MAX SWAY (EITHER DIRECTION) FIG 1 HTSW-110-07-XXX-D SHOWN -S .298 7.57 REF .298 7.57 REF -D -T -Q "G" REF .596 15.15 REF * "F" FIG 2: LOCKING CLIP HTSW-110-07-XXX-D-LC SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\HTSW-XXX-XX-XXX-X-XX-XX-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .025 SQ POST HI-TEMP TERMINAL STRIP ASSEMBLY DWG. NO. HTSW-XXX-XX-XXX-X-XX-XX-XX BY: PURVIS 02/17/87 SHEET 2 OF 7 REVISION BQ 50 FIG 3 TERMINAL SPACING (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) 01 02 01 01 03 03 CL -S 02 99 01 100 -S 148 150 148 -1 = .100 TERMINAL SPACING 01 25 02 01 -Q -T STRAIGHT VERSION EVEN POSITIONS STRAIGHT VERSION ODD POSITIONS 150 01 03 03 CL 04 04 03 -D -Q (FILL OUTER ROWS ONLY) -T -D -S -Q -T -D CL 02 49 50 -S 73 73 75 -T -D -T -D -S 01 -Q RIGHT ANGLE VERSION ODD POSITIONS 75 -Q (FILL OUTER ROWS ONLY) -2 = .200[5.08] TERMINAL SPACING CL FIG 4 -LL: LOCKING LEAD (NOTE: END VIEWS SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) -T -D -S SEE CRIMP DETAIL -Q RIGHT ANGLE VERSION EVEN POSITIONS .017 0.43 -LL:LOCKING LEAD = CRIMP LOCATION TWO CENTER MOST PINS TO BE CRIMPED AS SHOWN. C .04 1.0 (TYP) .0080 0.203 CRIMP DETAIL -S -LC-LL -D -LC-LL -S -LL -D -LL -T -LL SCALE: 2x [TYP- ALL CRIMPS] * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\HTSW-XXX-XX-XXX-X-XX-XX-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .025 SQ POST HI-TEMP TERMINAL STRIP ASSEMBLY DWG. NO. HTSW-XXX-XX-XXX-X-XX-XX-XX BY: PURVIS 02/17/87 SHEET 3 OF 7 REVISION BQ PIN #1 CL CL 2 MAX SWAY (EITHER DIRECTION) 2 MAX SWAY (EITHER DIRECTION) PIN #2 CL C 90° (TYP) 2 MAX SWAY (EITHER DIRECTION) PIN #1 CL 90° (TYP) .04 1.0 .06 1.5 C SINGLE -RA / -RE PIN #3 CL .04 1.0 'D' .120 3.05 REF CL C 90° (TYP) .04 1.0 .06 1.5 "E" REF 2 MAX SWAY (EITHER DIRECTION) C 90°(TYP) .04 1.0 CL PIN #1 PIN #1 CL C PIN #3 PIN #2 .100 2.54 (TYP) (SEE NOTE 10) C .100 2.54 (TYP) (SEE NOTE 10) .06 1.5 C .200 5.08 (TYP) (SEE NOTE 10) "E" REF .240 6.10 REF DOUBLE -RA .200 5.08 (TYP) (SEE NOTE 10) C "E" REF "E" REF .320 8.13 REF FIG 5 .320 8.13 REF TRIPLE -RA QUAD -RA -RA: RIGHT ANGLE (-LA OPTION IS SHOWN ON ALL -RA VIEWS FOR DIMENSIONAL PURPOSES) (SEE CRIMP DETAIL VIEW, SHT 3) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) -XX -RA / -NA -RE / -NE * PROPRIETARY NOTE TABLE 3 * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 4:1 F:\DWG\MISC\MKTG\HTSW-XXX-XX-XXX-X-XX-XX-XX-MKT.SLDDRW "D" .06 [1.5] .16 [4.1] 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .025 SQ POST HI-TEMP TERMINAL STRIP ASSEMBLY DWG. NO. HTSW-XXX-XX-XXX-X-XX-XX-XX BY: PURVIS 02/17/87 SHEET 4 OF 7 REVISION BQ # - MW OPTION, DO NOT DESIGN IN. SAMTEC WILL ONLY SUPPORT EXISTING BUSINESS 2/12/02. .003 0.08 MAX .005 0.13 MAX ESQ-04-MW-T -S -D FIG 6 *-MW: METAL WASHER (ONE PER POSITION) PT-1-24-01-22 PT-1-24-07-51 PT-1-24-08-03 PT-1-24-03-29 PT-1-24-01-63 * PROPRIETARY NOTE DO NOT SCALE DRAWING PT-1-24-02-04 F:\DWG\MISC\MKTG\HTSW-XXX-XX-XXX-X-XX-XX-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 2.5:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .025 SQ POST HI-TEMP TERMINAL STRIP ASSEMBLY DWG. NO. HTSW-XXX-XX-XXX-X-XX-XX-XX BY: PURVIS 02/17/87 SHEET 5 OF 7 REVISION BQ .025 0.64 REF(TYP) .018 0.46 REF(TYP) FIG 7 -26 LEAD STYLE (SAME AS FIG 1, DIFFERENT AS SHOWN) (1) WITH -RA or -RE OPTION (5) AVAILABLE IN -LL OPTION. (2) OMIT WITH -Q ROW SPECIFICATION (6) AVAILABLE IN -LA OPTION. (3) NOT AVAILABLE IN -RA OR -RE OPTION. (7) ON STYLE -08 -RA & -LA (4) NOT AVAILABLE IN -RE OPTION. OPTIONS ONLY; 'C' = .230+.005/-.008 [5.84+.13/-.20] *SQUARE END OF PIN(T-1RS7-01-XXX-2)SHOULD BE LOCATED AT "C" DIMENSION DURING FILL PROCESS. (SEE FIG 7) * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 3.5:1 F:\DWG\MISC\MKTG\HTSW-XXX-XX-XXX-X-XX-XX-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .025 SQ POST HI-TEMP TERMINAL STRIP ASSEMBLY DWG. NO. HTSW-XXX-XX-XXX-X-XX-XX-XX BY: PURVIS 02/17/87 SHEET 6 OF 7 REVISION BQ POST AREA BANDOLIER (REF) TAIL AREA IN PROCESS 1 (SAME AS FIG. 1, DIFFERENT AS SHOWN) -T PLATING ONLY * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\HTSW-XXX-XX-XXX-X-XX-XX-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .025 SQ POST HI-TEMP TERMINAL STRIP ASSEMBLY DWG. NO. HTSW-XXX-XX-XXX-X-XX-XX-XX BY: PURVIS 02/17/87 SHEET 7 OF 7
HTSW-102-07-F-S
物料型号:HTSW-XXX-XX-XXX-X-XX-XX-XX
器件简介:.025 SQ POST HI-TEMP TERMINAL STRIP ASSEMBLY,一种高温度下使用的端子带状组装。
引脚分配:根据配置不同,每行的端子数量从1至50不等,端子间距有.100(2.54mm)和.200(5.08mm)两种规格。
参数特性: - 绝缘体材料:LCP, UL-94-V-0 - 接触面积镀金规格多样,如10µ"金接触区和3µ"金尾部,或30µ"选择性金接触区和MATTE TIN尾部等。
- 端子推力:最小3 LBS。
- 最大高度变化:.005(.127mm)(-RA尾部不适用)。
- 接触区镀金面积最小值:.165"[4.19mm]。
功能详解:该器件为高温度下使用的端子带状组装,具有多种端子间距和排布选项,支持多种不同的镀金和镀锡选项,以适应不同的电气和环境要求。
应用信息:适用于需要高可靠性电气连接的应用,特别是在高温环境中。
封装信息:多种行配置(单行、双行、三行)和端子样式(直、直角、延长直角等),以及多种端子镀层选项。
还提供了锁定夹(-LC)和锁定铅(-LL)选项以实现机械锁定。
特定配置下还提供金属垫圈(-MW)选项。
HTSW-102-07-F-S 价格&库存
很抱歉,暂时无法提供与“HTSW-102-07-F-S”相匹配的价格&库存,您可以联系我们找货
HTSW-102-07-F-S
    • 5+0.99987
    • 50+0.81357
    • 150+0.72036
    • 500+0.50738
    • 2500+0.46383
    • 5000+0.44202
    库存:1923
    HTSW-102-07-F-S
    • 1+0.885271+0.11437
    HTSW-102-07-F-S
    • 1+0.876801+0.11330
    • 50+0.6839050+0.08840
    • 100+0.58690100+0.07590
    • 500+0.51740500+0.06690
    • 1000+0.491101000+0.06350
    • 2000+0.456402000+0.05900
    • 5000+0.394105000+0.05100
    库存:63436
