CSNL Series
Stackpole Electronics, Inc.
Resistive Product Solutions
Metal Plate Current Sensing Chip Resistor
Features:
Metal element current sensing resistor
High power current sense resistor
TCR of ±50 ppm/C
Resistances down to 0.0005 (1/2mΩ)
Current handling up to 63 amps
Non-standard resistance values available
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
For CSNL2512 with power rating of 3W, see SEI-CSNL2512-3W
Electrical Specifications
Dielectric Withstanding
Voltage (V)
TCR (ppm/ºC)
CSNL1206
Power Rating
(W)
1 @ 80ºC
CSNL2010
1.5 @ 80ºC
200
± 50
CSNL2512
2 @ 70ºC
Type/Code
Ohmic Range (Ω) and Tolerance
1%, 5%
0.001 - 0.05
0.0005 - 0.1
0.0005 - 0.01
Mechanical Specifications
Type/Code
Resistance Range
(Ω)
CSNL1206
0.001 - 0.05
≤ 0.003
CSNL2010
≥ 0.0031
0.0005
0.00075
0.001
0.0015
0.002
CSNL2512
0.0025
0.003
0.004
0.005
0.006
0.0065
H
Body Height
0.025 ± 0.010
0.65 ± 0.25
0.031 ± 0.010
0.79 ± 0.25
0.025 ± 0.010
0.65 ± 0.25
0.049 ± 0.008
1.25 ± 0.20
0.030 ± 0.008
0.75 ± 0.20
0.026 ± 0.008
0.65 ± 0.20
0.018 ± 0.008
0.45 ± 0.20
0.014 ± 0.008
0.35 ± 0.20
0.026 ± 0.008
0.65 ± 0.20
0.022 ± 0.008
0.55 ± 0.20
0.018 ± 0.008
0.45 ± 0.20
0.014 ± 0.008
0.35 ± 0.20
0.013 ± 0.008
0.32 ± 0.20
0.012 ± 0.008
0.30 ± 0.20
Rev Date: 10/22/2020
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
a
Top Termination
0.020 ± 0.010
0.51 ± 0.25
0.051 ± 0.010
1.30 ± 0.25
0.031 ± 0.010
0.79 ± 0.25
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
1
b
Bottom
0.020 ± 0.010
0.51 ± 0.25
0.051 ± 0.010
1.30 ± 0.25
0.031 ± 0.010
0.79 ± 0.25
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
L
Body Length
0.126 ± 0.010
3.20 ± 0.25
0.200 ± 0.010
5.08 ± 0.25
0.200 ± 0.010
5.08 ± 0.25
0.250 ± 0.010
6.35 ± 0.25
0.250 ± 0.010
6.35 ± 0.25
0.250 ± 0.010
6.35 ± 0.25
0.250 ± 0.010
6.35 ± 0.25
0.250 ± 0.010
6.35 ± 0.25
0.250 ± 0.010
6.35 ± 0.25
0.250 ± 0.010
6.35 ± 0.25
0.250 ± 0.010
6.35 ± 0.25
0.250 ± 0.010
6.35 ± 0.25
0.250 ± 0.010
6.35 ± 0.25
0.250 ± 0.010
6.35 ± 0.25
W
Body Width
0.063 ± 0.010
1.60 ± 0.25
0.100 ± 0.010
2.54 ± 0.25
0.100 ± 0.010
2.54 ± 0.25
0.125 ± 0.010
3.18 ± 0.25
0.125 ± 0.010
3.18 ± 0.25
0.125 ± 0.010
3.18 ± 0.25
0.125 ± 0.010
3.18 ± 0.25
0.125 ± 0.010
3.18 ± 0.25
0.125 ± 0.010
3.18 ± 0.25
0.125 ± 0.010
3.18 ± 0.25
0.125 ± 0.010
3.18 ± 0.25
0.125 ± 0.010
3.18 ± 0.25
0.125 ± 0.010
3.18 ± 0.25
0.125 ± 0.010
3.18 ± 0.25
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
marketing@seielect.com
CSNL Series
Mechanical Specifications (cont.)
Type/Code
Resistance Range
(Ω)
0.007
CSNL2512
0.01
H
Body Height
0.011 ± 0.008
0.27 ± 0.20
0.010 ± 0.008
0.25 ± 0.20
a
Top Termination
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
b
Bottom
0.051 ± 0.015
1.30 ± 0.38
0.051 ± 0.015
1.30 ± 0.38
L
Body Length
0.250 ± 0.010
6.35 ± 0.25
0.250 ± 0.010
6.35 ± 0.25
W
Body Width
0.125 ± 0.010
3.18 ± 0.25
0.125 ± 0.010
3.18 ± 0.25
Unit
inches
mm
inches
mm
Performance Characteristics
Test
Test Method
Test Specification
Typical
Load Life
MIL-STD-502F-Method 108A
RCWV at 70°C; 1.5 hour ON; 0.5 hour OFF
Total 1024 ± 24 hours
± 1%
≤ 0.5%
Resistance to Soldering Heat
MIL-STD-202F-Method 210E
260 ± 5°C for 10 ± 1 seconds
± 0.5%
≤ 0.25%
Solderability
MIL-STD-202F-Method 208H
245 ± 5°C for 2 ± 0.5 seconds
minimum 95% coverage
> 95%
Thermal Shock
MIL-STD-202F-Method 107G
-55°C to 150°C, 100 cycles
± 0.5%
≤ 0.5%
Short Time Overload
JIS-C-5202-5.5
5x rated power for 5 seconds
± 0.5%
≤ 0.5%
Temperature Cycling
JIS-C-5202-7.4
-55°C: 30 minutes 25°C: 2 to 3 minutes
155°C: 30 minutes 25°C: 2 to 3 minutes
± 0.5%
≤ 0.5%
Moisture Resistance
MIL- STD-202F-Method 106G
± 0.5%
≤ 0.5%
Insulation Resistance
MIL-STD-202F-Method 302
Apply 100 Vdc for 1 minute
1M Ω minimum
≥ 1M Ω
90 seconds minimum
≥ 90 seconds
Leach Resistance
Operating temperature range is -55°C to +170°C
Power Derating Curve:
2
www.seielect.com
CSNL Series
Recommended Pad Layout
Type/Code
Resistance Range (Ω)
CSNL1206
0.001 - 0.05
≤ 0.003
CSNL2010
≥ 0.0031
0.0005
0.00075
0.001
0.0015
CSNL2512
0.002 - 0.0035
0.004 - 0.0045
0.005 - 0.006
0.0065 - 0.007
0.008 - 0.01
a
0.063
1.60
0.114
2.89
0.090
2.29
0.123
3.13
0.115
2.93
0.094
2.38
0.074
1.88
0.064
1.63
0.104
2.63
0.094
2.38
0.074
1.88
0.064
1.63
b
0.086
2.18
0.115
2.92
0.115
2.92
0.134
3.40
0.134
3.40
0.134
3.40
0.134
3.40
0.134
3.40
0.134
3.40
0.134
3.40
0.134
3.40
0.134
3.40
i
0.039
1.00
0.048
1.22
0.095
2.41
0.020
0.52
0.037
0.94
0.080
2.04
0.120
3.04
0.139
3.54
0.061
1.54
0.080
2.04
0.120
3.04
0.139
3.54
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Recommended Solder Profile
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
Wave Soldering
Description
Maximum
Recommended
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max.
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Defference between final preheat stage and soldering stage.
3
Minimum
60 seconds
100°C
240°C
N/A
www.seielect.com
CSNL Series
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
Recommended Lead Free Resistor Reflow Profile
Taping Specifications – Embossed Plastic Tape
Type / Code
Ohmic Value (Ω)
Quantity
CSNL1206
0.001 - 0.05
4000
CSNL2010
0.0005 - 0.01
2000
CSNL2512
0.0005 - 0.00075
2000
CSNL2512
0.001 - 0.01
2000
A
0.072
1.83
0.114
2.90
0.134
3.40
B
W
F
E
0.004 0.137 ± 0.004 0.315 ± 0.006 0.138 ± 0.004 0.069 ±
0.10
3.48 ± 0.10
8.00 ± 0.15
3.50 ± 0.10
1.75 ±
0.004 0.215 ± 0.004 0.472 ± 0.006 0.217 ± 0.004 0.069 ±
0.10
5.45 ± 0.10 12.00 ± 0.15
5.50 ± 0.10
1.75 ±
0.004 0.266 ± 0.004 0.472 ± 0.004 0.217 ± 0.002 0.069 ±
0.10
6.75 ± 0.10 12.00 ± 0.10
5.50 ± 0.05
1.75 ±
P0
Unit
0.004 0.157 ± 0.004 inches
0.10
4.00 ± 0.10
mm
0.10
4.00 ± 0.10
mm
0.10
4.00 ± 0.10
mm
0.134 ± 0.004 0.266 ± 0.004 0.472 ± 0.004 0.217 ± 0.002 0.069 ± 0.004 0.157 ± 0.004 inches
3.40 ± 0.10
5.50 ± 0.05
1.75 ± 0.10
4.00 ± 0.10
mm
4
www.seielect.com
CSNL Series
Taping Specifications – Embossed Plastic Tape (cont.)
Type / Code
Ohmic Value (Ω)
Quantity
CSNL1206
0.001 - 0.05
4000
CSNL2010
0.0005 - 0.01
2000
CSNL2512
0.0005 - 0.00075
2000
CSNL2512
0.001 - 0.01
2000
T
0.043
1.10
0.052
1.33
0.057
1.45
0.032
0.81
P1
0.004
0.10
0.004
0.10
0.008
0.20
0.004
0.10
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
P2
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
ØD0
0.004
0.10
0.004
0.10
0.002
0.05
0.002
0.05
0.059
1.50
0.059
1.50
0.061
1.55
0.061
1.55
0.004
0.10
0.004
0.10
0.002
0.05
0.002
0.05
ØD1
Unit
0.055
1.40
0.055
1.40
min.
min.
min.
min.
inches
mm
inches
mm
inches
mm
inches
mm
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
CSNL
Description
Package /
Termination
Type
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
Surface Mount Chip Resistor
SMD
YES
100% Matte Sn over Ni
May-04
04/18
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
5
www.seielect.com
CSNL Series
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
14
C
S
N
L
1
2
F
T
1
L
Product Series
Code Description
CSNL Metal Plate
Size
Code
W
1206
1
2010
1.5
2512
2
Tolerance
Code Tol
F
1%
J
5%
Code
T
Packaging
Description
7" Reel - Plastic Tape
6
Size
1206
2010, 2512
Quantity
4000
2000
Resistance Value
Four characters with the
multiplier used as the decimal
holder. "L" used as multiplier of
-3
10 for any value under
0.1 ohm.
0.0005 ohm = L500
0.001 ohm = 1L00
0.01 ohm = 10L0
0.1 ohm = R100
www.seielect.com
很抱歉,暂时无法提供与“CSNL2512FTL500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2000+1.810022000+0.21825
- 国内价格 香港价格
- 1+4.347111+0.52417
- 10+3.4154410+0.41183
- 25+3.0834425+0.37180
- 50+2.7750950+0.33462
- 100+2.29297100+0.27648
- 250+2.15907250+0.26034
- 500+1.81002500+0.21825
