TSS-113-01-S-D
TSS-113-01-S-D
    SAMTEC(申泰)
    插件,P=2.54mm
    线对板针座 2x13P 直插 间距:2.54mm
TSS-113-01-S-D 数据手册
TSS-1XX-XX-XXX-X-XX-XX REVISION AE NO OF POS X .100[2.54] +.150[3.81] REF DO NOT SCALE FROM THIS PRINT POLARIZE OPTION XX INDICATES POSITION OMITTED OPTION BLANK: STRAIGHT (STYLE 04 & 05 N/A) -RA: RIGHT ANGLE (STYLE -01, -02 & -03 N/A) -LL: LOCKING LEAD -LA: -RA OPTION WITH -LL OPTION No OF POSITIONS -02 THRU -18 & 20, 21, 24, 25, 28, 30, 32, 36 (PER ROW) NO OF POS X .100[2.54] +.050[1.27] REF LEAD STYLE SEE TABLE 1 01 02 .150 3.81 REF ROW SPECIFICATION -D: DOUBLE -S: SINGLE PLATING SPECIFICATION -G: GOLD, 10µ'' Au / 50µ'' Ni NICKEL MIN ON CONTACT, 3µ'' AU / 50µ'' NI MIN ON TAIL -T: MATTE TIN CONTACT AND TAIL -S: SELECTIVE, 30µ'' Au / 50µ'' Ni MIN ON CONTATCT, MATTE TIN TAIL -L: LIGHT SELECTIVE, 10µ'' Au / 50µ'' Ni MIN ON CONTACT, MATTE TIN TAIL -H: HEAVY GOLD, 30µ'' Au / 50µ'' Ni MIN ON CONTACT, 3µ'' Au / 50µ'' Ni MIN ON TAIL -F: FLASH SELECTIVE, 3µ'' Au / 50µ'' Ni MIN ON CONTACT, MATTE TIN TAIL -STL: SELECTIVE, 30µ'' Au / 50µ'' Ni MIN ON CONTACT, TIN/LEAD (90/10+/-5%) TAIL (AVAILABLE IN -01 STYLE ONLY) -SS: STRIPE SELECTIVE, 30µ'' Au / 50µ'' Ni MIN ON CONTACT, MATTE TIN TAIL (SEE NOTE 7) .265 6.73 REF .165 4.19 REF (GOLD PLATE) (SEE NOTE 3) 02 04 .250 6.35 .365 9.27 REF REF .100 2.54 REF 01 03 C .250 6.35 REF C +.010 "A" - .000 .100 2.54 REF FIRST POSITION INDICATOR SEE NOTE 4 .165 4.19 REF (GOLD PLATE) (SEE NOTE 3) +.010 C "A" - .000 C .04 1.0 (TYP) .16 [4.1] (-02 & -03 POSITIONS) REF .20 [5.1] (-04 THRU -36) REF (N/A ON SINGLE ROW -02 THRU -05 POSITIONS) .04 1.0 (TYP) TERMINAL 1 (SEE TABLE 1) 'CRIMP' TERMINAL 1 (SEE TABLE 1) STRAIGHT (-LL IS SHOWN FOR DIMENSIONAL PURPOSES) .017 0.43 MIN TSS-XX-X .350 8.89 REF DETAIL 'CRIMP' SCALE 8 : 1 .015 0.38 REF .0080 0.203 (TYP ALL CRIMPS) NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM PUSHOUT FORCE: 3 LB. 3. ASSEMBLE GOLD PLATED END AS SHOWN. 4. TERMINALS TO BE FLUSH TO .010 [.25] BELOW TOP OF SHROUD. 5. TSS-1XX-04-X-D-RA-XX ASSEMBLIES ARE TO BE PACKAGED IN A PT-1-24-01-40 TUBE WITH TWO TP-13 PLUGS PER TUBE (ALL POSITIONS). C 6. ORIENTATE PINS TO REDUCE THE NUMBER OF BANDOLIER MARKS IN THE POST AREA (SEE TABLE 2). UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] MATERIAL: PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: PBT, UL 94 VO, COLOR: BLACK TERMINAL: PHOSPHOR BRONZE 7. AVAILABLE ON STRAIGHT LEAD STYLES -01, -02, -03 AND ON –RA LEAD STYLE -04. MATES WITH SSW, SSQ, SSM, BCS, ESW & ESQ ONLY. F:\DWG\MISC\MKTG\TSS-1XX-XX-XXX-X-XX-XX-MKT.SLDDRW SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: SLIM TOP SHROUD TERMINAL STRIP DWG. NO. TSS-1XX-XX-XXX-X-XX-XX BY: JORDAN 01/23/1990 SHEET 1 OF 2 REVISION AE C SINGLE -LL/-LA SEE NOTE 4 SEE NOTE 4 "B" REF 90° .035±.010 0.89±0.25 C 90° .100 2.54 TERMINAL 2 (SEE TABLE 1) .04 1.0 (TYP) "B" REF C CL C C .035±.010 0.89±0.25 .04 1.0 (TYP) ODD POS EVEN POS TERMINAL 1 (SEE TABLE 1) DOUBLE -LL/-LA RIGHT ANGLE (-LA IS SHOWN FOR DIMENSIONAL PURPOSES) C SEE NOTE 4 (2ND ROW ONLY) CL .075 1.91 REF .130 3.30 REF ODD POS EVEN POS = CRIMP LOCATION C +.010 "D" - .000 FIG 1 +.010 "C" - .000 +.010 "C" - .000 * PINS TO BE FLIPPED OPPOSITE OF SELECTIVE PLATING BEFORE BEING INSERTED TERMINAL 1 (SEE TABLE 1) TERMINAL 2 (SEE TABLE 1) -RA IN-PROCESS VIEW TERMINAL 1 (SEE TABLE 1) POST AREA BANDOLIER REF .150 3.81 REF (BEFORE RIGHT ANGLE) C (SEE NOTE 6) (SEE TABLE 2) TAIL AREA IN-PROCESS VIEW (-T PLATING ONLY) PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\TSS-1XX-XX-XXX-X-XX-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: SLIM TOP SHROUD TERMINAL STRIP DWG. NO. TSS-1XX-XX-XXX-X-XX-XX BY: JORDAN 01/23/1990 SHEET 2 OF 2
TSS-113-01-S-D 价格&库存
很抱歉,暂时无法提供与“TSS-113-01-S-D”相匹配的价格&库存,您可以联系我们找货
TSS-113-01-S-D
  • 1+43.000681+5.54362
  • 25+38.8895225+5.01361
  • 50+36.1186550+4.65639
  • 100+35.98673100+4.63939
库存:33
