RC0402FR-0775RP
RC0402FR-0775RP
    YAGEO(国巨)
    贴片电阻 0402 75Ω ±1% 1/16W ±200ppm/℃
RC0402FR-0775RP 数据手册
DATA SHEET LEAD FREE CHIP RESISTORS RC_P series ±0.1%, ±0.5%, ±1%, ±5% Product specification – December 26, 2024 V.6 Sizes 0075/0100/0201/0402/0603/0805/ 1206/1210/1218/2010/2512 Product specification Chip Resistor Surface Mount RC_P SERIES SCOPE This specification describes RC series chip resistors with made by thick film process. ORDERING INFORMATION - GLOBAL PART NUMBER APPLICATIONS RC XXXX X X X XX XXXX P  All general purpose application FEATURES  Total lead free without RoHS exemption  Halogen Free Epoxy  Reducing environmentally hazardous wastes  High component and equipment reliability  Saving of PCB space  MSL class: MSL 1 2 11 0075 to 2512 Global part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0075/0100/0201/0402/0603/0805/1206/1210/1218/2010/2512 (2) TOLERANCE B = ± 0.1% D = ± 0.5% F = ± 1.0% J = ± 5.0% ( for jumper ordering, use code of J) (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel S = ESD safe reel (0100 only) (4) TEMPERATURE COEFFICIENT OF RESISTANCE - = Based on spec. (5) TAPING REEL 07 = 7 inch dia. Reel 13 =13 inch dia. Reel 7N = 7 inch dia. Reel, ESD safe reel (0100 only) 7W = 7 inch dia. Reel & 2 x standard power (6) RESISTANCE VALUE There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point. Example: 97R6 = 97.6Ω 9K76 = 9760Ω 1M = 1,000,000Ω (7) DEFAULT CODE Letter P is lead free (without RoHS exemption) ORDERING EXAMPLE The ordering code for a RC0402 0.0625W chip resistor value 100K with 5% tolerance, supplied in 7-inch tape reel of 10,000 units per reel is: RC0402JR-07100KP. www.yageo.com Dec. 26, 2024 V.6 Product specification Chip Resistor Surface Mount RC_P 3 11 0075 to 2512 SERIES MARKING RC0075 / RC0100 / RC0201 / RC0402 No Marking ynsc007 Fig. 1 RC0603 E24 series: 3 digits, 5% YNSC001 Fig. 2 First two digits for significant figure and 3rd digit for number of zeros Value = 10 KΩ RC0805 / RC1206 / RC1210 / RC1218 / RC2010 / RC2512 E24/E96 series: 4 digits, 1%, 0.5% YNSC004 Fig. 3 Value = 10 KΩ First three digits for significant figure and 4th digit for number of zeros Note For further marking information, please see special data sheet "Chip resistors marking". CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environmental influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Nibarrier) are added, as shown in Fig.4. Outlines For dimensions, please refer to Table 1 marking layer overcoat primary glass layer resistive layer (Jumper chip is a conductor) inner electrode termination(Ni/matte tin) inner electrode H ceramic substrate I2 overcoat I1 W YNSC086 L Fig. 4 Chip resistor outlines www.yageo.com Dec. 26, 2024 V.6 Product specification Chip Resistor Surface Mount RC_P SERIES 4 11 0075 to 2512 DIMENSION Table 1 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) RC0075 0.30± 0.01 0.15± 0.01 0.13± 0.01 0.08± 0.03 0.08± 0.03 RC0100 0.40± 0.02 0.20± 0.02 0.13± 0.02 0.10± 0.03 0.10± 0.03 RC0201 0.60± 0.03 0.30± 0.03 0.23± 0.03 0.10± 0.05 0.15± 0.05 RC0402 1.00± 0.05 0.50± 0.05 0.35± 0.05 0.20± 0.10 0.25± 0.10 RC0603 1.60± 0.10 0.80± 0.10 0.45± 0.10 0.25± 0.15 0.25± 0.15 RC0805 2.00± 0.10 1.25± 0.10 0.50± 0.10 0.35± 0.20 0.35± 0.20 RC1206 3.10± 0.10 1.60± 0.10 0.55± 0.10 0.45± 0.20 0.45± 0.20 RC1210 3.10± 0.10 2.60± 0.15 0.55± 0.10 0.45± 0.15 0.50± 0.20 RC1218 3.10± 0.10 4.60± 0.10 0.55± 0.10 0.45± 0.20 0.40± 0.20 RC2010 5.00± 0.10 2.50± 0.15 0.55± 0.10 0.45± 0.15 0.55± 0.20 RC2512 6.35± 0.10 3.10± 0.15 0.55± 0.10 0.60± 0.20 0.60± 0.20 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS TYPE POWER Fig. 4 Operating Max. Max. Dielectric Temperature Coefficient Temperature Working Overload Withstanding RESISTANCE RANGE of Resistance Range Voltage Voltage Voltage Chip resistor outlines E24 ± 5% 10Ω ≤ R ≤ 1MΩ RC0075 1/50W -55°C to +125°C 10V 25V 25V E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ Jumper< 50mΩ E24 ± 5% 1Ω ≤ R ≤ 10MΩ RC0100 1/32W -55°C to +125°C 15V 30V 30V E24/E96 ± 1% ± 0.5% ± 0.1% 1Ω ≤ R ≤ 10MΩ Jumper< 50mΩ 10Ω≤R
RC0402FR-0775RP 价格&库存
很抱歉,暂时无法提供与“RC0402FR-0775RP”相匹配的价格&库存,您可以联系我们找货
RC0402FR-0775RP
    • 50000+0.02043
    库存:20000
    RC0402FR-0775RP
    • 10000+0.0458710000+0.00593
    • 20000+0.0414320000+0.00536
    • 30000+0.0392630000+0.00508
    • 50000+0.0369350000+0.00478
    • 70000+0.0355970000+0.00460
    • 100000+0.03433100000+0.00444
    库存:26807
    RC0402FR-0775RP
      库存:880
      RC0402FR-0775RP
      • 1+0.885961+0.11452
      • 10+0.2732610+0.03533
      • 25+0.2011125+0.02600
      • 50+0.1641750+0.02122
      • 100+0.13418100+0.01735
      • 250+0.10487250+0.01356
      • 500+0.08828500+0.01141
      • 1000+0.075121000+0.00971
      • 5000+0.054565000+0.00706
      库存:26807
