TFML-130-01-S-D
TFML-130-01-S-D
    SAMTEC(申泰)
    插件,P=1.27mm
TFML-130-01-S-D 数据手册
TFML-1XX-XX-XXX-D-XXX REVISION BF No OF POSITIONS -05,-07,-10 THRU -50 (PER ROW) (No OF POS x .050[1.27]) + .125[3.18] REF DO NOT SCALE FROM THIS PRINT (No OF POS x .050[1.27]) + .025[0.64] REF .130 3.30 REF 02 "B" "A" REF (TYP) (SEE NOTE 7 & TABLE 1) "A" .155 3.94 REF .075 1.91 REF "A" 01 "B" LEAD STYLE -01: THROUGH HOLE (SEE FIG 1) -02: SURFACE MOUNT (SEE FIG 3, SHT 2) .110 2.79 REF (SEE NOTE 11) .150 3.81 REF .225 5.72 REF TFML-XX-D-01-X FIG 1 -01: THROUGH HOLE PLATING SPECIFICATION -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -L: 15µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -F: 3µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -H: 30µ" GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL -FM: 3µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -LM: 15µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -STL: 30µ" SELECTIVE GOLD IN CONTACT AREA, TIN/LEAD (90/10+/-5%) TAIL .050 1.27 .220 5.59 REF .134 3.39 REF .075 1.91 (SEE NOTE 9, APPLY FOR BOTH ROWS) .014 0.36 REF 2 MAX SWAY (TYP) (No OF POS -1) x .050[1.27] C 2 MAX TOE (TYP) .018 0.46 .130 3.30 REF REF 2 MAX SWAY (TYP) C SECTION SECTION "A"-"A" FIG 2 NO OF POS. TABLE 1 EVEN ODD (EXCL. -05,-07 POS) PART NOTCH PAD NOTCH C REPRESENTS A CRITICAL DIMENSION. 2. COPLANARITY: POSITIONS -05 THRU -26: .004[0.10] POSITIONS -27 THRU -50: .006[0.15]. 3. MANUFACTURING IN-PROCESS DIMENSION C DESIGNED TO ACHIEVE FINISHED ASSEMBLY. 4. MINIMUM PUSHOUT FORCE: 12 OZ. C 5. MAXIMUM ALLOWABLE BOW: .004 INCH/INCH 2 MAX TOE [0.10 MM/MM]AFTER ASSEMBLY. 6. MEASURED FROM BEND. (TYP) 7. POSITIONS -05 AND -07 WILL ONLY HAVE ONE CLIP AT .050 1.27 DIMENSION SHOWN; POSITIONS -10 THROUGH -24 C WILL HAVE ONLY ONE CLIP AT DIMENSION SHOWN; POSITIONS -25 THROUGH -34 WILL HAVE TWO CLIPS AT DIMENSION SHOWN; POSITIONS -35 THROUGH -50 WILL "B"-"B" HAVE THREE; CLIPS: TWO AT DIMENSION SHOWN & ONE CENTERED ON INSULATOR. 8. NOTE DELETED. 9. .003[0.08] MAXIMUM TERMINAL BURR 10. .005[0.13] MAXIMUM HEIGHT VARIATION BETWEEN ANY TWO PINS. 11. DIMENSION IS NOT APPLICABLE FOR -05 AND -07 POSITION. 12. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, THE –LC OPTION IS NOT COMPATIBLE "A" WITH AUTO PLACEMENT. SAMTEC RECOMMENDS MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH .310 THE –LC OPTION. 13. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE .360 PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM .113 14. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL, BASED ON OPTIONS SELECTED. .096 2.44 REF 1. .1635 4.153 REF -TR: TAPE & REEL OPTION -05,-07 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS .4270 10.846 MATERIAL: OBLONG HOLES USER DIRECTION OF UNREELING .XX: .01 .XXX: .005 .XXXX: .0020 IN-PROCESS ROW SPECIFICATION -D: DOUBLE ROW NOTES: .010 0.25 REF T-1R16-01-XXX-2 ROUND HOLES OPTION -A: ALIGNMENT PIN (USE TFML-XX-D-01-A) (SEE FIG 7, SHT 3) -LC: LOCKING CLIP (USE LC-05-TM) SEE NOTE 12 (SEE FIG 9, SHT 3, N/A ON -RA OPTION) -P: PICK & PLACE PAD (USE PPP-72 FOR -05 & -07. USE PPP-04 FOR -10 THRU -50) (AVAIL IN ALL POSITIONS, N/A ON -RA OPTION, SEE FIG 5, SHT 2) -RA: RIGHT ANGLE (LEAD STYLE -01 ONLY) (SEE FIG 4, SHT 2) -TR: TAPE & REEL (SEE FIG 2)(N/A ON -01 LEAD STYLE) (SEE NOTE 13) -SA: STAKED ALIGNMENT PIN (USE SM-A5) (SEE FIG 8, SHT 3) -K: POLYIMIDE FILM (USE K-DOT-.217-.313-.005) (SEE FIG 6, SHT 2) (N/A ON -RA) -SN: SOLDER NAIL (USE TFML-XX-D-01-SN & WT-27-01-T) (SEE FIG 10, SHEET 4) (AVAILABLE ON -02 LEAD STYLE ONLY) -SN2: SOLDER NAIL FOR .093 BOARD (USE TFML-XX-D-01-SN & WT-27-02-T) (SEE FIG 10, SHEET 4) (AVAILABLE ON -02 LEAD STYLE ONLY) (NOT AVAILABLE WITH -A, -LC, - RA, -SA) -FR: FULL REEL QTY. TAPE & REEL (N/A ON -01 LEAD STYLE) (SEE NOTE 14) ANGLES 2 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING VECTRA E130i, LCP, UL 94 VO COLOR: BLACK CONTACT: PHOS BRONZE, THICKNESS: .018 F:\DWG\MISC\MKTG\TFML-1XX-XX-XXX-D-XXX-MKT.SLDDRW SHEET SCALE: 1.75:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: DWG. NO. .050 SHROUDED TERMINAL ASSEMBLY TFML-1XX-XX-XXX-D-XXX BY: DEANP 4/8/99 SHEET 1 OF 4 REVISION BF FIG 3 FIG 5 -02: SURFACE MOUNT (SHOWN: TFML-125-02-XXX-D) (SAME AS FIG 1, UNLESS OTHERWISE STATED) -P: PICK & PLACE PAD OPTION (SHOWN: TFML-125-02-XXX-D-P) (SAME AS FIG 1, UNLESS OTHERWISE STATED) NOTCH ON PAD TO BE ON SAME END AS NOTCH IN TFM BODY "C" C +.012 .220 - .000 +3 +0.30 0.00 5.59 "P" SEE NOTE 2 "C" 3 MAX SWAY (TYP) "M" REF C -3 FLUSH TO .012[0.30] MAX (SEE NOTE 6) .230 5.84 REF C SECTION "C"-"C" 01 03 PPP-04 .050 1.27 PAD NOTCH .394 10.01 REF .225 5.72 REF 02 (No OF POS -1) x .050[1.27] (TOL ACCUM .005[0.13] OVER 50 POS) NOTE: "M" = (No OF POS x .050[1.27]) + .125[3.18] "P" = {("M" - .394[10.00]) / 2} .020[0.51] FIG 4 FIG 6 -RA: RIGHT ANGLE OPTION (SHOWN: TFML-125-01-XXX-D-RA) (SAME AS FIG 1, UNLESS OTHERWISE STATED) -K: POLYIMIDE FILM PAD OPTION (SHOWN: TFML-125-02-XXX-D-K) (SAME AS FIG 1, UNLESS OTHERWISE STATED) NOTCH TO BE ORIENTED AS SHOWN T-1R16-03-XXX "D" .216 5.49 T-1R16-02-XXX .075 1.91 REF "S" "D" "R" REF C .014 0.36 REF .225 5.72 90° .020 0.51 NOTE: "R" = (No OF POS x .050[1.27]) + .125[3.18] "S" = {("R" - .216[5.49]) / 2} .020[0.51] .050 1.27 .422 10.72 (TYP) C T-1R16-03-XXX T-1R16-02-XXX IN-PROCESS SECTION "D"-"D" F:\DWG\MISC\MKTG\TFML-1XX-XX-XXX-D-XXX-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1.75:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 SHROUDED TERMINAL ASSEMBLY DWG. NO. TFML-1XX-XX-XXX-D-XXX BY: DEANP 4/8/99 SHEET 2 OF 4 REVISION BF PACKAGING VIEWS FIG 7 PARTS TO BE POSITIONED WITH POLARIZING NOTCH FACING THE SAMTEC LOGO AND ARROW. -A: ALIGNMENT PIN OPTION (SHOWN: TFML-125-02-XXX-D-A) (SAME AS FIG 1, UNLESS OTHERWISE STATED) -NOT AVAILABLE WITH -RA DIRECTION INDICATOR TFML-XX-D-01-A .045 1.14 REF POLARIZING NOTCH PT-1-24-01-09 (No OF POS x .050[1.27]) + .075[1.91] REF .050 1.27 REF FIG 8 TFML-XX-D-01 -SA: STAKED ALIGNMENT PIN OPTION (SHOWN: TFML-125-02-XXX-D-SA) (SAME AS FIG 1, UNLESS OTHERWISE STATED) -NOT AVAILABLE ON -RA PARTS TO BE POSITIONED WITH TAILS FACING LOGO SIDE OF TUBE AND POLARIZING NOTCH ORIENTED AS SHOWN .050 1.27 DIRECTION INDICATOR SM-A5 POLARIZING NOTCH (No OF POS x .050[1.27]) + .075[1.91] .035 0.89 REF FIG 9 -LC: LOCKING CLIP OPTION (SHOWN: TFML-125-02-XXX-D-LC) (SAME AS FIG 1, UNLESS OTHERWISE STATED) -NOT AVAILABLE ON -RA PT-01-24-05-17 POSITION PARTS WITH POLARIZING NOTCH ORIENTED AS SHOWN TFML-XX-D-01 DIRECTION INDICATOR POLARIZING NOTCH PT-1-24-03-09 .050 1.27 LC-05-TM .010 0.25 REF (No OF POS x .050[1.27]) + .075[1.91] .056 1.42 REF F:\DWG\MISC\MKTG\TFML-1XX-XX-XXX-D-XXX-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1.75:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 SHROUDED TERMINAL ASSEMBLY DWG. NO. TFML-1XX-XX-XXX-D-XXX BY: DEANP 4/8/99 SHEET 3 OF 4 REVISION BF FIG 10 -SNX: SOLDER NAIL (SHOWN: TFML-125-02-XXX-D-SN) (SAME AS FIG 1, UNLESS OTHERWISE STATED) (ONLY AVAILABLE ON -02 LEAD STYLE) (NO OF POS. X .050[1.27])+.275 REF TFML-XX-D-01-SN "E" CL CL C FLUSH TO .005[0.13] ABOVE "B" REF .075 1.91 REF WT-27-XX-T .026 0.66 REF (2 PLCS) "E" 2 MAX SWAY (TYP) SECTION "E"-"E" C (No OF POS x .050[1.27]) + .175[4.45] OPTION -SN -SN2 TABLE 2 "B" .071[1.80] .106[2.69] * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\TFML-1XX-XX-XXX-D-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 SHROUDED TERMINAL ASSEMBLY DWG. NO. TFML-1XX-XX-XXX-D-XXX BY: DEANP 4/8/99 SHEET 4 OF 4
TFML-130-01-S-D 价格&库存
很抱歉,暂时无法提供与“TFML-130-01-S-D”相匹配的价格&库存,您可以联系我们找货
TFML-130-01-S-D
    • 1+61.85160
    • 10+59.62680
    库存:31
