REVISION R
IPBT-1XX-XX-XX-S-XX
OPTION
-RA: RIGHT ANGLE (SEE FIG 2, SHT 2)
[STYLE -H2 NOT AVAILABLE]
-GP: GUIDE POSTS (USE IPBT-XX-S-GP,
SEE FIG 4, SHT 3)
*-K: KEYED POLARIZATION (USE IPBT-XX-S-K)
(SEE FIG 5, SHT 2)
(NOT AVAILABE W/-GP OPTION)
No OF POSITIONS
-02 THRU -10
DO NOT
SCALE FROM
THIS PRINT
LEAD STYLE
-H1: HIGH POWER, THRU HOLE
(USE T-1S55-XX-XX-2)
-H2: HIGH POWER, SURFACE MOUNT
((No OF POSITIONS x .165[4.19]) + .0525) REF
.109 2.76
REF
(No OF POSITIONS -1) x .165[4.19] REF
01
.259 6.58 REF
02
PLATING SPECIFICATION
-T: MATTE TIN CONTACT AND TAIL
(USE T-1S55-XX-T-2)
-TM: MATTE TIN CONTACT AND TAIL
(USE T-1S55-XX-T-2)
-L: 10μ" GOLD ON CONTACT, TIN ON TAIL
(USE T-1S55-XX-L-2)
-S: 30μ" GOLD ON CONTACT, TIN ON TAIL
(USE T-1S55-XX-S-2)
CL
CL
.205 5.21 REF
.050 1.27 REF
"A"
.380 9.65
REF
C
ROW SPECIFICATION
-S: SINGLE (USE IPBT-XX-S)
IPBT-XX-S
.259 6.58
REF
.260 6.60
REF
.405 10.29
REF
"A"
2 MAX SWAY
(EITHER DIRECTION)
'A' REF
.130 3.30 C
(SEE NOTE 4)
C .165 4.19
.045 1.14 SQ
REF
2 MAX SWAY C
(EITHER DIRECTION)
T-1S55-01-X-2
C
(* = LEAVE BLANK FOR NO KEYED OPTION.
SAMTEC WILL ONLY SUPPORT EXISTING
BUSINESS AS OF REV F)
((No OF POSITIONS -1) x .165[4.19]) .008[.20]
SECTION "A"-"A"
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. PARTS TO BE MOLDED TO POSITION.
3. MINIMUM TERMINAL RETENTION: 1 LB[4.45 N].
4. POST MUST BE WITHIN .005[.13] OF EACH OTHER.
5. PARTS TO BE TUBE PACKAGED, SEE PACKAGING VIEWS SHT 3.
6. THIS FEATURE NOT PRESENT ON -02-S AND -03-S POSITIONS.
ONLY CORNER RIBS (4 PLCS) ARE PRESENT.
7. ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING
EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM.
IPBT-108-H1-XX-S SHOWN
FIG 1
F:\DWG\SW\Exisprod\Assembly\165\IPBT-1XX-XX-XX-S-XX-ASM.SLDDRW
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01[0.3]
2
.XXX: .005[0.13]
.XXXX: .0020[0.051]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: LCP, UL 94 VO COLOR: BLACK
TERMINAL: HIGH COPPER ALLOY
SHEET SCALE: 2:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
.165 SINGLE ROW TERMINAL ASSEMBLY
DWG. NO.
IPBT-1XX-XX-XX-S-XX
BY: KEVIN B
05/06/03
SHEET 1 OF 3
REVISION R
.036 0.90 REF
LATCH
90°
.173 4.38
REF
IPBT-05-S-K
FIG 5
-K: POLARIZATION
(IPBT-105-H1-XX-S-K SHOWN)
(SAME AS FIG 1 UNLESS OTHERWISE STATED)
.686 17.43
REF
C .3936±.0050 9.998±0.127
.1475±.0050 3.75±0.13
.147 3.73 REF
SEE NOTE 6
T-1S55-03-X-2
.036 0.90 REF
IN-PROCESS 2
IN-PROCESS 1
2 MAX SWAY
C
(EITHER DIRECTION)
IPBT-03-S
FIG 6
(IPBT-103-H1-XX-S-K SHOWN)
.259 6.58
REF
01
02
T-1S55-03-X-2
"B"
90° C
.260 6.60
REF
"B"
.060 1.52
C (MEASURE AT
BEND)
FIG 2
.147 3.73 REF
SECTION "B"-"B"
-RA: RIGHT ANGLE
(IPBT-108-H1-XX-S-RA SHOWN)
(DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1)
(STYLE -H2 NOT AVAILABLE)
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
IPBT-1XX-XX-XX-S-XX
BY: KEVIN B
05/06/03
SHEET 2 OF 3
01
REVISION R
.46 11.6
.160 4.06
REF
02
.607 15.42
REF
"C"
.327 8.31 C
.260 6.60 REF
T-1S55-02-X-2
+0°
IN-PROCESS 1
90° - 4°
C .450 11.43
C
C
SEE TABLE 2
"C"
T-1S55-02-X-2
SECTION "C"-"C"
+0°
90° - 4°
FIG 3
STYLE -H2: SURFACE MOUNT
(IPBT-108-H2-XX-S SHOWN)
.145 3.68
.46 11.6
IN-PROCESS 2
((No OF POSITIONS x .165[4.19]) +.240[6.10] REF
01
02
RIGHT ANGLE
.160 4.06
REF
.259 6.58
REF
THROUGH HOLE
TUBE: PT-1-24-06-51
PLUG: TP-07
TUBE: PT-1-24-01-40
PLUG: TP-13
.110 2.79 REF
SURFACE MOUNT
TUBE: PT-1-24-01-58
PLUG: TP-13
PACKAGING VIEW
[PARTS TO HAVE POSITION #1 LOADED IN
SAME DIRECTION AS ARROW ON TUBE]
IPBT-XX-S-GP
.135 3.43 REF
((No OF POSITIONS x .165[4.19]) +.483[12.27] REF
FIG 4
-GP: GUIDE POSTS
(IPBT-108-H1-XX-S-RA-GP SHOWN)
(DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1, 2 OR 3)
(AVAILABLE WITH THROUGH HOLE, SURFACE MOUNT & -RA OPTION)
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
IPBT-1XX-XX-XX-S-XX
BY: KEVIN B
05/06/03
SHEET 3 OF 3
