FTS-105-01-F-D
FTS-105-01-F-D
    SAMTEC(申泰)
    插件,P=1.27mm
    排针 间距:1.27mm 2x5P 直插
FTS-105-01-F-D 数据手册
REVISION CH FTS-1XX-XX-XX-XX-XX DO NOT SCALE FROM THIS PRINT No OF POSITIONS -02 THRU -50 (UNSHROUDED) -05 THRU -46 (SHROUDED) (No OF POS x .0500[1.27]) ±.010[0.25] LEAD STYLE SEE TABLE 1 .050 1.27 REF 02 PLATING SPECIFICATION -L: 10µ" GOLD IN CONTACT AREA, MATTE TIN ON TAIL -F: 3µ" GOLD IN CONTACT AREA, MATTE TIN ON TAIL -S: 30µ" GOLD IN CONTACT AREA, MATTE TIN ON TAIL -H: 30µ" GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL -SM: 30µ" GOLD IN CONTACT AREA, MATTE TIN ON TAIL -LM: 10µ" GOLD IN CONTACT AREA, MATTE TIN ON TAIL -FM: 3µ" GOLD IN CONTACT AREA, MATTE TIN ON TAIL -G: 10µ" GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL 50 .135 3.43 REF CL 01 49 FTS-XX-DV-XX (No OF POS x .0500[1.270]) - .0500[1.270] .016 0.41 SQ REF (TYP) 2 MAX SWAY (EITHER DIRECTION) 2 MAX SWAY (EITHER DIRECTION) "A" (SEE NOTE 15) .050±.004 1.27±0.10 .070 1.78 REF (CONTACT AREA) (SEE NOTE 5) .090±.010 2.29±0.25 (SEE NOTE 3) NOTES: 1. REPRESENTS A CRITICAL DIMENSION. 2. PARTS MAY BE CUT TO POSITION. 3. SHEAR TAILS TO DIMENSION SHOWN. 4. MEASURED AT BEND RADIUS, NOT AT END OF PIN. C 5. GOLD PLATING TO BE ON POST, TIN PLATING TO BE ON TAIL. 6. 4 POSITIONS PER ROW WILL BE COVERED BY SHROUDS. (2 POSITIONS PER ROW ON EACH END). 7. 4 POSITIONS MUST BE ADDED TO PART CALLOUT TO ALLOW FOR SHROUDS, EXAMPLE FTS-125-02-L-D-SA REQUIRES A 29 POSITION BODY. 8. NOTE DELETED. 9. MINIMUM PUSHOUT FORCE: .5 LB (8 OZ) 10. MAXIMUM CUT FLASH: .015[0.38] 11. PPP-25-NT MUST BE USED FOR ALL TAPE AND REEL PACKAGING. 12. FILL BODY SO THAT THE LEAD IN OF THE CORE IS ON THE TAILS SIDE FOR -DV OPTION ONLY. 13. MAXIMUM BURR ALLOWANCE: .003[0.08] 14. FOR PACKAGING OPTION LEFT BLANK. POSITIONS -05 THRU -50 TO BE TUBED. POSITIONS -02 THRU -04 ON TAIL OPTION -D TO BE LAYER PACKAGED. POSITIONS -02 THRU -04 ON TAIL OPTION -DV TO BE TAPE AND REELED. 15. MAX HEIGHT VARIATION BETWEEN ROWS: .005[0.13]. 16. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM. 17. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL, BASED ON OPTIONS SELECTED. .034 0.86 REF T-1SXX-XX-X (SEE TABLE 1) (SEE NOTE 13) 2 MAX SWAY (EITHER DIRECTION) (No OF POS x .0500[1.270]) - .0500[1.270] 02 OPTIONS -P: PICK AND PLACE PAD (USE PPP-25) (AVAILABLE ON POSITIONS 04 THRU 50) (SEE FIG 5, SHT 2 & FIG 7, SHT 3) (USE PPP-25-NT FOR TAPE & REEL) -TR: TAPE & REEL PACKAGING (SEE FIG 10, SHT 4) (SEE NOTE 16) (ONLY AVAILABLE WITH -DV OPTION) -S: END SHROUDS (SEE FIG 3, SHT 2 & FIG 6 SHT 3) (LEAD STYLE -02 & -03 ONLY) (05 POS MINIMUM, 46 POS MAXIMUM) (NOT AVAILABLE WITH -A OPTION; ORDER -SA FOR ALIGNMENT PIN WITH SHROUD) (SEE NOTES 6 & 7) -SA: END SHROUDS W/ ALIGNMENT PINS (SEE FIG 4, SHT 2 & FIG 8, SHT 3) (LEAD STYLE -02 & -03 ONLY) (05 POS MINIMUM, 46 POS MAXIMUM) (SEE NOTES 6 & 7) -A: MOLDED ALIGMENT PIN (USE FTS-XX-DV-XX) (ONLY AVAILABLE IN -DV OPTION, 5 POS MINIMUM) (SEE FIG 9, SHT 3) (NOT AVAILABLE WITH -S OPTION; ORDER -SA FOR ALIGNMENT PIN AND SHROUD) -FR: FULL REEL QTY. TAPE & REEL (SEE NOTE 17) TAIL OPTION -D: DOUBLE ROW THROUGH HOLE -DV: DOUBLE ROW VERTICAL SURFACE MOUNT FIG 1 FTS-1XX-01-XX-D SHOWN 50 CL 01 49 MAY SUBSTITUTE ASP-61746-05-X FOR RETENTION PURPOSES FOR -DV STYLE ONLY "B" .050±.006 1.27±0.15 +0.13 .050+-.005 .000 1.27 0.00 90°±3° (SEE NOTE 4) "B" FIG 2 DECIMALS ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] .004[0.10 .230±.010 5.84±0.25 (SEE NOTE 3) FTS-1XX-03-XX-DV SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: MATERIAL: * PROPRIETARY NOTE DO NOT SCALE DRAWING INSULATOR: LCP, UL 94 V0, COLOR: BLACK TERMINAL: PHOS BRONZE SEE NOTE 12 SEE NOTE 13 SECTION "B"-"B" * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. F:\DWG\MISC\MKTG\FTS-1XX-XX-XX-XX-XX-MKT.SLDDRW SHEET SCALE: 4:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .050 X .050 C.L. LOW PROFILE TERMINAL STRIP ASSEMBLY FTS-1XX-XX-XX-XX-XX BY: BRATCHER 11/29/1993 SHEET 1 OF 4 REVISION CH (No OF POS x .050[1.27]) + .034[0.86] CL .137 3.48 REF (No OF POS x .050[1.27]) + .325[8.26] REF (No OF POS x .050[1.27]) + .200[5.08] REF .137 3.48 REF CL (No OF POS x .050[1.27]) + .034[0.86] .200 5.08 REF .185 4.70 REF FES .115 2.92 REF .2625 6.668 REF FES-A .140 3.56 .115 2.92 REF FIG 3 -DV-S OPTION (SEE NOTES 6 & 7) FTS-106-02-XX-DV-S SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) NOTE: 4 POSITIONS MUST BE ADDED TO PART CALLOUT TO ACHIEVE DIMS (NOT AVAILABLE WITH -A OPTION; ORDER -SA FOR ALIGNMENT PIN WITH SHROUD) {[(No OF POS x .050[1.27]) - .200[5.08]] / 2} ±.020[0.51] .20 5.1 REF .185 4.70 REF .140 3.56 .050 1.27 REF .055 1.40 REF (No OF POS x .050[1.27]) + .275[6.99]] .23 5.8 REF "B" REF .130 3.30 PPP-25-NT (USE PPP-25-NT FOR TAPE AND REEL PACKAGING ONLY) {[(No OF POS x .050[1.27]) - .200[5.08]] / 2} ±.020[0.51] .20 5.1 REF FIG 4 -DV-SA OPTION (SEE NOTES 6 & 7) FTS-106-02-XX-DV-SA SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) NOTE: 4 POSITIONS MUST BE ADDED TO PART CALLOUT TO ACHIEVE DIMS .130 3.30 REF PPP-25 F:\DWG\MISC\MKTG\FTS-1XX-XX-XX-XX-XX-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. "B" REF FIG 5 -DV-P OPTION FTS-110-02-XX-DV-P SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) DO NOT SCALE DRAWING SHEET SCALE: 4:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .050 X .050 C.L. LOW PROFILE TERMINAL STRIP ASSEMBLY FTS-1XX-XX-XX-XX-XX BY: BRATCHER 11/29/1993 SHEET 2 OF 4 REVISION CH (No OF POS x .050[1.27]) + .034[0.86] CL .137 3.48 REF (No OF POS x .050[1.27]) + .325[8.26] REF (No OF POS x .050[1.27]) + .200[5.08] REF .137 3.48 REF CL (No OF POS x .050[1.27]) + .034[0.86] .200 5.08 REF .185 4.70 REF FES .115 2.92 REF .2625 6.668 REF FES-A .124 3.15 .115 2.92 REF .185 4.70 REF .124 3.15 FIG 6 -D-S OPTION (SEE NOTES 6 & 7) FTS-106-02-XX-D-S SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) NOTE: 4 POSITIONS MUST BE ADDED TO PART CALLOUT TO ACHIEVE DIMS (NOT AVAILABLE WITH -A OPTION; ORDER -SA FOR ALIGNMENT PIN WITH SHROUD) .050 1.27 REF .071 1.80 REF (No OF POS x .050[1.27]) + .275[6.99]] {[(No OF POS x .050[1.27]) - .200[5.08]] / 2} ±.020[0.51] .20 5.1 REF .13 3.3 REF FIG 8 FIG 7 "B" REF (SEE TABLE 3, SHT 2) -D-P OPTION FTS-110-02-XX-D-P SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) -D-SA OPTION (SEE NOTES 6 & 7) FTS-106-02-XX-D-SA SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) NOTE: 4 POSITIONS MUST BE ADDED TO PART CALLOUT TO ACHIEVE DIMS FTS-XX-DV-XX F:\DWG\MISC\MKTG\FTS-1XX-XX-XX-XX-XX-MKT.SLDDRW * .050 1.27 REF (No OF POS - 2) x .050[1.27] REF .035 0.89 REF FIG 9 -A MOLDED ALIGNMENT PIN FTS-110-02-XX-DV-A SHOWN (ONLY AVAILABLE IN -DV OPTION) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 4:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .050 X .050 C.L. LOW PROFILE TERMINAL STRIP ASSEMBLY FTS-1XX-XX-XX-XX-XX BY: BRATCHER 11/29/1993 SHEET 3 OF 4 TUBE PACKAGING VIEW REVISION CH POSITION 1 SEE NOTE 11 "A" -D-S(A)-P -01-D, -02-D, -03-D SEE NOTE 14 -DV-S(A)-P "A" USER DIRECTION OF UNREELING POCKET NOT DETAILED -DV-S(A) -DV -D-S(A) -DV-P -D-P IN PROCESS VIEWS (HANDFILL ONLY) NOTE: -02 & -03 LEAD STYLES WITH -A PINS; BKT MACHINE ONLY SECTION "A"-"A" "A" - .034[0.86] (SEE NOTE 15) FIG 10 -TR: TAPE AND REEL PACKAGING WITH PPP-25-NT PAD NOT AVAILABLE ON THROUGH HOLE LEAD STYLES .350 8.89 REF "A" - .034[0.86] (SEE NOTE 15) "A" - .034[0.86] (SEE NOTE 15) .125±.010 3.18±0.25 (SEE NOTE 3) IN PROCESS 2 IN PROCESS 1 W/O -A PINS .050 1.27 IN PROCESS 2 W/O -A PINS "A" - .084[2.13] (SEE NOTE 15) W/O -A PINS "A" - .084[2.13] (SEE NOTE 15) "A" - .084[2.13] (SEE NOTE 15) .175±.010 4.45±0.25 (SEE NOTE 3) .350 8.89 REF .100 2.54 IN PROCESS 3 IN PROCESS 2 IN PROCESS 1 WITH -A PINS * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\FTS-1XX-XX-XX-XX-XX-MKT.SLDDRW WITH -A PINS WITH -A PINS 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .050 X .050 C.L. LOW PROFILE TERMINAL STRIP ASSEMBLY FTS-1XX-XX-XX-XX-XX BY: BRATCHER 11/29/1993 SHEET 4 OF 4
FTS-105-01-F-D 价格&库存
很抱歉,暂时无法提供与“FTS-105-01-F-D”相匹配的价格&库存,您可以联系我们找货
SSM-120-S-SV
    库存:17490
    FTS-105-01-F-D
      • 1+5.17320
      • 10+5.04360
      • 30+4.95720
      库存:38
