572 SERIES
WATERPROOF WIRE TO WIRE & WIRE TO BOARD CONNECTORS
Features:
5.8mm pitch, rated current: 10A max
Fully waterproof with double latch solution
Available in wire to wire and wire to board options
Available in 1, 2, or 3 positions
True crimp and poke solution
Internal polarization to prevent mismating
Available with wire already installed
Wide range of wire sizes available
Waterproof Grade: IP67 Certified
Specifications:
No. of Positions
1, 2, 3
Pitch
5.8 mm
Rated Voltage
300 V
Rated Current
10 amps maximum
Dielectric Withstanding Voltage
1700 V AC (rms)
Contact Resistance
10 milliohms maximum
Insulation Resistance
1000 megaohms minimum/DC 500 V
Operating Temperature
-40°C to +105°C
PCB Thickness
1.6 mm
Ordering Code:
Crimp Contact:
572-002-000-100
Male Contact (Pin)
SERIES:
572, WIRE TO WIRE
WIRE TO BOARD
NO. OF CONTACTS:
001 - 1 CONTACT
002 - 2 CONTACTS
003 - 3 CONTACTS
CONTACT CODE:
000 - NO CONTACTS (ONLY FOR CRIMP CONTACTS)
420 - BOARD MOUNT CONTACTS
AWG#
Ins. Dia.
Pcs/Reel
Part No (Material)
AWG#
Ins. Dia.
Pcs/Reel
570-290-751 (Brass)
14
Max.
Ø3.1
4,000
570-290-761 (Brass)
14
Max. Ø3.1
4,000
570-291-731 (Ph. Brz.)
20-16
Max.
Ø3.1
4,000
570-291-741 (Ph. Brz.)
20-16
Max. Ø3.1
4,000
570-290-741 (Brass)
20-16
Max. Ø3.1
4,000
570-290-731 (Brass)
20-16
Max.
Ø3.1
4,000
570-291-721 (Ph. Brz.)
22-20
Max. Ø2.7
4,000
570-290-721 (Brass)
22-20
Max. Ø2.7
4,000
Max.
Ø2.7
4,000
570-290-711 (Brass)
STYLE:
101 - WHITE MALE HOUSING (ONLY FOR BOARD MOUNT CONTACTS)
301 - BLUE MALE HOUSING (ONLY FOR BOARD MOUNT CONTACTS)
100 - WHITE MALE HOUSING FOR CRIMP CONTACTS
300 - BLUE MALE HOUSING FOR CRIMP CONTACTS
200 - WHITE FEMALE HOUSING FOR CRIMP CONTACTS
400 - BLUE FEMALE HOUSING FOR CRIMP CONTACTS
Female Contact (Socket)
Part No (Material)
22-20
Materials:
Crimp & Poke
PCB Header
Housing
PBT, UL 94V-0
Contact
Ph. Brz. or Brass
Housing
PBT with Glass, UL
94V-0
Contact
Brass
Assembly Layout:
47.0
Contact Plating
Tin Plating
Wire & Housing Seals
Silicone Rubber
Wire Seal:
Wire O.D.
Color
AWG#
Ø Dia.
Height
570-260-001
Ø1.7~Ø2.1
Black
22
Ø 5.0
6.0
570-260-002
Ø2.1~Ø2.7
Light Blue
22-20
Ø 5.0
6.0
570-260-003
Ø2.1~Ø2.7
Blue
22-20
Ø 5.0
6.7
570-260-004
Ø2.7~Ø3.1
Brown
20-14
Ø 4.9
5.0
www.edac.net
570-260-002
Double Latch
570-260-004
30.5
Part No.
570-260-001
570-260-003
support@edac.net
572 SERIES
WIRE TO WIRE / WIRE TO BOARD 5.8MM PITCH
Male Housing:
Female Housing:
PCB Header
572-001-000-XXX
572-001-000-XXX
572-001-420-XXX
572-002-000-XXX
572-002-000-XXX
572-002-420-XXX
572-003-000-XXX
572-003-000-XXX
572-003-420-XXX
Male Housing:
Female Housing:
PCB Header:
Housing Color:
XXX:
Housing Color:
YYY:
Housing Color:
XXX:
White
100
White
200
White
101
Blue
300
Blue
400
Blue
301
www.edac.net
support@edac.net
572 SERIES
Recommended PCB Layout
www.edac.net
support@edac.net
很抱歉,暂时无法提供与“572-001-420-101”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+40.52061
- 5+16.96416
- 25+12.39351
