TFM-105-02-L-S-WT
TFM-105-02-L-S-WT
    SAMTEC(申泰)
    SMD,P=1.27mm
    线对板针座 1x5P 立贴 间距:1.27mm
TFM-105-02-L-S-WT 数据手册
REVISION AN TFM-1XX-XX-X-S-XX NOTES: C DO NOT SCALE FROM THIS PRINT C 1. REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM PUSHOUT FORCE: 16 OZ FOR TERMINALS, 12 OZ FOR WELD TABS, AND 8 OZ FOR LOCKING CLIPS. 3. MEASURED FROM BEND. 4. MAXIMUM TERMINAL BURR: .003 [.08]. 5. MAXIMUM HEIGHT VARIATION BETWEEN ANY TWO PINS: .005 [.13]. 6. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, THE -LC OPTION IS NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC RECOMMENDS MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH THE -LC OPTION. LEAD STYLE -01: T-1R16-01-X-2 THROUGH HOLE -02: T-1R16-01-X-2 SURFACE MOUNT -03: T-1R16-10-X THROUGH HOLE ((No. OF POSITIONS x .050[1.27]) + .125[3.18])REF ((No. OF POSITIONS x .050[1.27]) + .025[.64])REF .100 2.54 REF .105 2.67 REF .065 1.65 OPTION -A: ALIGNMENT PIN (USE TFM-XX-S-01-A) (NOT AVAILABLE WITH -WT OPTION) (SEE FIG 5, SHEET 2) -LC: LOCKING CLIP (USE LC-05-TM) (NOT AVAILABLE WITH -WT OPTION) (SEE FIG 7, SHEET 3) (SEE NOTE 6) -P: PICK AND PLACE PAD (USE PPP-15) (SEE FIG 6, SHEET 2) (ONLY AVAILABLE ON -08 THRU -50 POSITIONS, -07 THRU -50 POSITIONS WITH -WT OPTION) -K: POLYIMIDE FILM (SEE FIG 3, SHEET 2) (USE K-DOT-.217-.313-.005) -WT: WELD TABS (USE WT-25-07-T) (SEE FIG 4, SHEET 2) (AVAILABLE ON -02 THRU -30 POS ONLY) (NOT AVAILABLE WITH -A OR -LC OPTIONS) -TR: TAPE & REEL (SEE SHEET 3, TAPE AND REEL VIEW) ** -SN: SOLDER NAIL (USE WT-27-03) (NOT AVAILABLE WITH -A, -LC, OR -WT OPTIONS) (SEE FIG 8, SHEET 3) No OF POSITIONS ALL POSITIONS AVAILABLE -02 THRU -50 PLATING SPECIFICATIONS -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -F: 3µ" FLASH GOLD IN CONTACT AREA, MATTE TIN ON TAIL -L: 15µ" LIGHT GOLD IN CONTACT AREA, MATTE TIN ON TAIL -H: 30µ" HEAVY GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL -T: MATTE TIN CONTACT AND TAIL BODY SPECIFICATION -S: SINGLE ROW (USE TFM-XX-S-XX-XX) 01 .083 2.11 .050 1.27 REF ** NOT TOOLED .175 4.45 REF C ((No. OF POSITIONS x .050[1.27]) - .050[1.27]) 2 MAX SWAY (EITHER DIRECTION) "A" 2 MAX SWAY (EITHER DIRECTION) .018 0.46 REF .1635 4.153 REF .2200 5.588 REF "B" REF C "A" .014 0.36 REF TABLE 1 POSITION COPLANARITY -02 THRU -29 .004 [.10] -030 THRU -39 .006 [.15] -40 THRU -50 .008 [.20] ((No. OF POSITIONS x .050[1.27]) - .050[1.27]) "C"±.003 2 MAX SWAY (EITHER DIRECTION) 2 MAX SWAY (EITHER DIRECTION) C SECTION "A"-"A" C IN-PROCESS FIG 1 (TFM-115-01-X-S-XX SHOWN) UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS LEAD STYLE -01 -02 -03 C .010 0.25 REF "A" .003 TABLE 2 BODY "A" "B" "C" "E" TFM-XX-S-01-XX .078 [1.98] .131 [3.33] .428 [10.87] .303 [7.70] TFM-XX-S-01-XX N/A .131 [3.33] .428 [10.87] .231 [5.87] TFM-XX-S-01-XX .111 [3.33] .139 [3.53] .645 [16.83] .356 [9.04] ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:0.4 INSULATOR: LCP, UL 94 V0, COLOR: BLACK TERMINAL: PHOSPHOR BRONZE F:\DWG\SW\EXISPROD\ASSEMBLY\050\TFM-1XX-XX-X-S-XX-ASM.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 C.L. SINGLE ROW SHROUDED TERMINAL STRIP DWG. NO. TFM-1XX-XX-X-S-XX BY: D. SCHMELZ 8/21/2008 SHEET 1 OF 3 REVISION AN NOTE: “R” = OVERALL LENGTH REF “S” = ((“R” - .216[5.49]) /2) ±.020[.51] 2 MAX SWAY (EITHER DIRECTION) .021±.020 0.52±0.508 .216 5.49 "B" 90° C 0 .226±.006 5.74±0.152 SEE TABLE 1, SHT 1 C "R" 7 FLUSH TO .012 0.30 MAX (SEE NOTE 3) 2 MAX SWAY (EITHER DIRECTION) C .185 4.70 MAX 02 03 "E" (SEE TABLE 2, SHT 1) "S" "B" SECTION "B"-"B" 01 "E" (SEE TABLE 2, SHT 1) ((No. OF POSITIONS x .050[1.27]) -.050[1.27]) (TOL ACCUM ±.005[.13] OVER 50 POS.) FIG 2 SURFACE MOUNT (TFM-115-02-X-S-XX SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) ((NO OF POSITIONS X .050[1.27]) +.263[6.68]) REF "D" TFM-XX-S-01-WT FIG 3 -K: POLYIMIDE FILM PAD (TFM-115-02-X-S-K SHOWN) NOTE: “M” = (No. OF POSITIONS X .050[1.27]) + .125[3.18] REF WITH -WT “M” = (No. OF POSITIONS X .050[1.27]) + .263[6.68] REF “P” = ((“M” - .375[9.53]) /2) ±.020[.51] WT-25-07-T "M" C .175 4.45 REF "P" .093 2.36 (TYP) .010 0.25 REF (TYP) C "D" 2 MAX SWAY (EITHER DIRECTION) .025 0.64 REF SECTION "D"-"D" .050 1.27 .375 9.53 REF C PPP-15 SECTION "E"-"E" "E" ((No. OF POSITIONS x .050[1.27]) + .154[3.91]) FIG 4 -WT OPTION (TFM-114-01-X-S-WT SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) FIG 6 "E" CL -P OPTION (TFM-115-02-X-S-P SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) (PAD TO BE POSITIONED ON CL AS SHOWN) F:\DWG\SW\EXISPROD\ASSEMBLY\050\TFM-1XX-XX-X-S-XX-ASM.SLDDRW .045 1.14 REF .050 1.27 REF ((No. OF POSITIONS x .050[1.27]) + .075[1.91]) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. FIG 5 R.025 0.64 -A OPTION (TFM-115-02-X-S-A SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 C.L. SINGLE ROW SHROUDED TERMINAL STRIP DWG. NO. TFM-1XX-XX-X-S-XX BY: D. SCHMELZ 8/21/2008 SHEET 2 OF 3 REVISION AN PT-1-24-11-09 ROUND HOLES (No OF POSITIONS x .050[1.27]) + .275 REF POSITION 01 FLUSH TO .005 0.13 ABOVE "G" OBLONG HOLES .054 1.37 REF WT-27-03-X USER DIRECTION OF UN-REELING POCKET NOT DETAILED PACKAGING TUBE VIEW "G" (No. OF POSITIONS x .050[1.27]) +.175[4.45] .075 1.91 REF .026 0.66 REF (2 PLCS) 2 MAX SWAY (EITHER DIRECTION) NOTES: SECTION "G"-"G" SCALE 3 : 1 1. USE PT-1-24-11-09 TUBE AND (2) TP-09. 2. USE PT-1-24-03-09 TUBE AND (2) TP-09 FOR -P AND -K OPTIONS. 3. LOAD TUBE WITH 1ST POSITION IN SAME DIRECTION AS ARROW TAPE AND REEL VIEW FIG 8 -SN OPTION (TFM-110-02-X-S-SN SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) CL C .050 1.27 LC-05-TM .056 1.42 REF .010 0.25 REF 2 MAX SWAY (EITHER DIRECTION) ((No. OF POSITIONS x .050[1.27]) + .075[1.91])±.005[.13] 2 MAX SWAY (EITHER DIRECTION) FIG 7 -LC OPTION (TFM-115-02-X-S-LC SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 2) * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\SW\EXISPROD\ASSEMBLY\050\TFM-1XX-XX-X-S-XX-ASM.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 C.L. SINGLE ROW SHROUDED TERMINAL STRIP DWG. NO. TFM-1XX-XX-X-S-XX BY: D. SCHMELZ 8/21/2008 SHEET 3 OF 3
TFM-105-02-L-S-WT 价格&库存
很抱歉,暂时无法提供与“TFM-105-02-L-S-WT”相匹配的价格&库存,您可以联系我们找货
TFM-105-02-L-S-WT
  • 41+24.68983
  • 82+20.14361
  • 123+17.14505
  • 533+15.17421
  • 1025+12.42955
  • 2009+11.48646
  • 5002+9.68490
  • 10004+7.88334
库存:83
TFM-105-02-L-S-WT
  • 1+23.987471+3.11830
