TFC-110-02-L-D-A
TFC-110-02-L-D-A
    SAMTEC(申泰)
    SMD,P=1.27mm
    线对板针座 2x10P 立贴 间距:1.27mm
TFC-110-02-L-D-A 数据手册
REVISION AO DO NOT SCALE FROM THIS PRINT TFC-1XX-XX-XX-D-XX NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM CONTACT RETENTION: 12 OZS. 3. MINIMUM LOCKING CLIP RETENTION: 8 OZS. No OF POSITIONS 4. MAXIMUM HEIGHT VARIATION BETWEEN ANY TWO PINS: .005[0.13]. LEAD STYLE -01, -02: -02 THRU -50 (ALL 5. MAXIMUM TERMINAL BURR: .003[0.08]. POSITIONS AVAILABLE) 6. COPLANARITY: .004[0.10] = POS 02 THRU 26 LEAD STYLES -11, -12: (-05 THRU -50 MULTIPLES OF 5) .006[0.15] = POS 27 THRU 50. C POSITIONS -12, -16, -17 ALSO AVAILABLE 7. MEASURED FROM BEND. LEAD STYLES -21, -22: (-05 THRU -50 MULTIPLES OF 5) 8. MEASURE FROM TIPS OF PIN. POSITIONS -12 & -13 ALSO AVAILABLE 9. SIDES OF PLASTIC BODIES ON ALL LEAD STYLES EXCEPT THE -01 & -02 LEAD STYLES -31, -32: (-05 THRU -50 MULTIPLES OF 5) WILL BE SOLID AND WITHOUT SIDE SLOTS. -12 POSITION ALSO AVAILABLE 10. THIS FEATURE ONLY PRESENT ON -01 & -02 LEAD STYLES. 11. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, THE –LC OPTION IS NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC RECOMMENDS MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH THE LEAD STYLE –LC OPTION. THROUGH HOLE SURFACE MOUNT 12. NOTE DELETED. -01 (SEE FIG 1) -02 (SEE FIG 2, SHT 2) 13. NOT ALL PARTS FOLLOW EIA-481 ORIENTATION IN THE T&R POCKET. -11 (SEE FIG 1) -12 (SEE FIG 2, SHT 2) 14. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE PACKAGED ACCORDING -21 (SEE FIG 1) -22 (SEE FIG 2, SHT 2) TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM. -31 (SEE FIG 1) -32 (SEE FIG 2, SHT 2) 15. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL, BASED ON OPTIONS SELECTED. OPTION -A: ALIGNMENT PIN (USE TFM-XX-D-XX-A, SEE TABLE 1, SHT 3) (SEE FIG 5, SHT 3) (NOT AVAILABLE WITH -RA) -LC: LOCKING CLIP (USE LC-05-TM) (NOT AVAILABLE WITH -RA) (SEE FIG 6, SHT 3, NOTE 3 & 11) -P: PICK AND PLACE PAD (USE PPP-04) (AVAILABLE IN ALL POSITIONS -05 THRU -50) (NOT AVAILABLE WITH -RA) (SEE FIG 7, SHT 3) -RA: RIGHT ANGLE (AVAILABLE ONLY IN LEAD STYLE: -01) (SEE FIG 8, SHT 2) -TR: TAPE AND REEL (SEE FIG 4, SHT 4) (FOR -X2 ONLY) (NOT AVAILABLE WITH -RA) (SEE NOTE 13 & 14) -K: POLYIMIDE FILM (SEE FIG 3, SHT 2) (SEE TABLE 1, SHT 3) (ALL LEAD STYLES EXCEPT -21 AVAILABLE) (NOT AVAILABLE FOR -RA) (USE K-DOT-.217-.313-.005) -FR: FULL REEL QTY. TAPE & REEL (FOR -X2 ONLY) (NOT AVAILABLE WITH -RA) (SEE NOTE 13 & 15) (No. OF POSITIONS x .050[1.27]) + .125[3.18] REF (No. OF POSITIONS x .050[1.27]) + .025[.64] REF PLATING SPECIFICATION -F: 3µ" FLASH GOLD ON CONTACT AREA, MATTE TIN TAIL -L: 15µ" SELECTIVE GOLD ON CONTACT AREA, MATTE TIN TAIL -LM: 15µ" SELECTIVE GOLD ON CONTACT AREA, MATTE TIN TAIL -FM: 3µ" FLASH GOLD ON CONTACT AREA, MATTE TIN TAIL .110 2.79 REF 02 .155 3.94 REF 01 .050 1.27 REF .135 3.43 REF .075 1.91 REF BODY SPECIFICATION -D: DOUBLE ROW .225 5.72 REF SEE NOTE 10 C (No. OF POSITIONS x .050[1.27]) - .050[1.27] .050 1.27 .018 0.46 REF 2 MAX SWAY (EITHER DIRECTION) "A" 2 MAX SWAY (EITHER DIRECTION) "D" REF (SEE TABLE 1, SHT 3) "A" REF (SEE TABLE 1, SHT 3) SEE NOTE 9 C "A" .014 0.36 REF 2 MAX SWAY (EITHER DIRECTION) .096 2.44 .1635 4.153 REF .010 0.25 REF "F"±.003[0.08] (SEE TABLE 1, SHT 3) 2 MAX SWAY (EITHER DIRECTION) .050 1.27 C (No. OF POSITIONS x .050[1.27]) - .050[1.27] SECTION "A"-"A" C C "C"±.003[0.08] (SEE TABLE 1, SHT 3) FIG 1 THROUGH HOLE -01, -11, -21, -31 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] MATERIAL: IN-PROCESS C * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2.5:1 INSULATOR: LCP, UL 94-V0 COLOR: BLACK TERMINAL: PHOSPHOR BRONZE F:\dwg\sw\exisprod\assembly\050\TFC-1XX-XX-XX-D-XX-ASM.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .050 X .050 TERMINAL STRIP TFC-1XX-XX-XX-D-XX BY: BRATCHER 05/25/2001 SHEET 1 OF 4 REVISION AO NOTE: "R" = OVERALL LENGTH (REF) "S" = {("R" - .216[5.49] /2} ±.020[.51] "J"±.006[0.15] (SEE TABLE 1, SHT 3) "B" C C 3 SEE NOTE 9 "B" C 01 03 .005±.020 0.11±0.508 .216 5.49 2 "E" (SEE TABLE 1, SHT 3) SEE NOTE 6 FLUSH TO .012 [0.30] MAX (SEE NOTE 7) 7 (-12, -22 & -32 STYLES) 3 (-02 STYLE ONLY) C 3 MAX SWAY (EITHER DIRECTION) .235 5.97 MAX "S" (SEE NOTE) SEE NOTE 10 "R" (SEE NOTE) SECTION "B"-"B" "E" (SEE TABLE 1, SHT 3) 02 SEE NOTE 10 (No. OF POSITIONS x .050) -.050[1.27] (TOL ACCUM ±.005[0.13] OVER 50 POS) FIG 2 SURFACE MOUNT -02, -12, -22, -32 DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1 NOTCH TO BE ORIENTED AS SHOWN "C" 02 01 "A" REF (SEE TABLE 1, SHT 3) FIG 3 -K: POLYIMIDE FILM PAD TERMINAL 2 (SEE TABLE 1, SHT 3) TERMINAL 1 (SEE TABLE 1, SHT 3) .075 1.91 REF .014 0.36 REF (TYP) "C" 2 MAX SWAY (EITHER DIRECTION) C C .020 0.51 (SEE NOTE 8) 90° C .050 1.27 (SEE NOTE 8) C FIG 8 SECTION "C"-"C" -RA OPTION DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1 TERMINAL 2 (SEE TABLE 1, SHT 3) .422 10.72 "A" REF (SEE TABLE 1, SHT 3) .422 10.72 TERMINAL 2 (SEE TABLE 1, SHT 3) F:\dwg\sw\exisprod\assembly\050\TFC-1XX-XX-XX-D-XX-ASM.SLDDRW TERMINAL 1 (SEE TABLE 1, SHT 3) .075 1.91 REF CARRIER STRIP TERMINAL 1 (SEE TABLE 1, SHT 3) I.D. MARK C IN-PROCESS 1 (ORIENT I.D. MARK AS SHOWN) (FOR -RA OPTION ONLY) 90° .020 0.51 C IN-PROCESS 2 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .050 X .050 TERMINAL STRIP TFC-1XX-XX-XX-D-XX BY: BRATCHER 05/25/2001 SHEET 2 OF 4 REVISION AO "M" (SEE NOTE) "P" (SEE NOTE) C .045 1.14 REF (No. OF POSITIONS x .050[1.27]) + .075[1.91] .050 1.27 REF R.025 [0.64] REF .394 10.01 REF .050 1.27 *PPP-04 FIG 5 -A OPTION DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1 .225 5.72 REF "E" CL .050 1.27 C CL "E" SECTION "E"-"E" LC-05-TM 2 MAX SWAY (EITHER DIRECTION) .010 0.25 REF NOTE: "M" = (No. OF POS X .050[1.27]) + .125[3.18] (REF) "P" = {(“M” - .394[10.01]) /2} ±.020[.51] .056 1.42 REF 2 MAX SWAY (EITHER DIRECTION) ((No. OF POSITIONS x .050[1.27]) + .075[1.91])±.002[0.05] FIG 6 * NOTCH ON PAD TO BE ON SAME END AS THE NOTCH IN THE TFM BODY -LC OPTION DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1 (NOT AVAILBLE ON -RA) FIG 7 -P OPTION DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1 (PAD TO BE POSITIONED ON CL AS SHOWN) F:\dwg\sw\exisprod\assembly\050\TFC-1XX-XX-XX-D-XX-ASM.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .050 X .050 TERMINAL STRIP TFC-1XX-XX-XX-D-XX BY: BRATCHER 05/25/2001 SHEET 3 OF 4 REVISION AO ROUND HOLES LOADING DIRECTION ARROW PART NOTCH POLARIZATION NOTCH PT-1-24-18-09 (SEE TABLE 2) OBLONG HOLES FIG 9 USER DIRECTION OF UN-REELING POCKET NOT DETAILED PT-1-24-XX-09 FIG 4 -TR: TAPE AND REEL (SEE NOTE 13) LOADING DIRECTION ARROW POLARIZATION NOTCH PT-1-24-05-17 (SEE TABLE 2) FIG 10 PT-1-24-05-17 LOADING DIRECTION ARROW POLARIZATION NOTCH NOTE: PARTS TO BE PACKAGED WITH THE LOADING DIRECTION ARROW POINTED IN SAME DIRECTION AS THE ARROW ON TUBE. F:\dwg\sw\exisprod\assembly\050\TFC-1XX-XX-XX-D-XX-ASM.SLDDRW * PT-FTSH002-DV-A-P-M (SEE TABLE 2) PROPRIETARY NOTE DO NOT SCALE DRAWING FIG 11 PT-FTSH002-DV-A-P-M * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .050 X .050 TERMINAL STRIP TFC-1XX-XX-XX-D-XX BY: BRATCHER 05/25/2001 SHEET 4 OF 4
TFC-110-02-L-D-A 价格&库存
很抱歉,暂时无法提供与“TFC-110-02-L-D-A”相匹配的价格&库存,您可以联系我们找货
TFC-110-02-L-D-A
    • 1+28.96560
    • 10+28.29600
    • 35+27.85320
    库存:13
