EN2C4F22DC
EN2C4F22DC
    SWITCHCRAFT
    EN2C4F22DC
EN2C4F22DC 数据手册
8 7 6 5 4 3 2 2 3 2 3 2-#20 3 1 4 1 3-#20 4 1 4-#22 4 3 2 5 5 1 F 4 2 1 6 5-#26 SPECIFICATIONS: 3 2 5 MECHANICAL Life:600 cycles minimum Vibration: Mil-Std 202G Method 201A Hex Nut Tongue: 5-6 in-lb 2 6 6-#26 7 7-#26 1 Feed the free end of cable through the handle, cable-clamp/grommet, and coupling ring in the order shown. E 0.375 MAX 9.5 Strip cable end and conductors as shown. CABLE-CLAMP HANDLE D GROMMET (INSIDE) CABLE Connector Type: C - Cord P - Panel* L - In-Line** Packaging Options: Leave blank for Bulk K - Kit (one unit/bag) # of Contacts: 2-3 for #20 4 for #22 5-7 for #26 EN2 CORD CONNECTOR CRIMP OR SOLDER ENVIRONMENTAL Operating Temperature Limits:-40ºC to +85ºC (-40ºF to +185°F), see Current Rating Table. Moisture Resistance: Mil-Std 202G Method 106G Insulation Resistance: Mil-Std 202G Method 302 Thermal Shock: Mil-Std 202G Method 107G Salt Atmosphere (Corrosion): Mil-Std 202G Method 101E Wearthetight Ratings: IP16, IP18, IP66, IP67, IP68 per IEC60529 NEMA 250 (6P), CFR 46 Part 110.20 PART NUMBER SCHEME: EN2 0.188±0.015 4.8±0.4 COUPLING RING Coupling Ring option: Leave blank for Ribbed W - Winged Gender: M - Male F - Female Grommet Code - Cable O.D. Range: DC - Daisy Chain (all 3 sizes) G1 - 0.100-0.140 (2.5-3.6) G2 - 0.140-0.180 (3.6-4.6) G3 - 0.180-0.220 (4.6-5.6) Soldering or crimping conductors to contacts is recommended before insertion into connector. If crimping, use hand or pneumatic crimp tool with crimp positioner per contact size. If soldering after contacts are inserted in the connector, limit exposure of contacts to soldering iron temperature to 4 sec. maximum. Soldering iron temperature should not exceed 650°F (343°C). Contacts 2 #20 3 #20 Insert wired contacts into connector housing using an insertion tool and per contacts arrangements. 4 #22 5-7 #26 C E MATERIAL Connector Housing ----- Thermoplastic, black Hex Nut: ------------------- Thermoplastic, black Coupling Ring ------------ Thermoplastic, black Cable Clamp -------------- Thermoplastic, black Handle (back-shell) ----- Thermoplastic, black Insulator ------------------- Elastomer, black Seal Grommet ----------- Elastomer, black Contacts ------------------- Copper Alloy, plated Contact Size: Contact Style: 20 - #20 Leave blank for Solder or Crimp 22 - #22 P - PC tail (Panel connectors only) 26 - #26 * for mating Panel-mount connectors refer to EN2P SERIES drawing. ** Mating In-Line connectors not currently available. CONTACTS F ELECTRICAL Voltage Rating: 250 V AC/DC for 2 contact arrangement 125 V AC/DC for 3-7 contact arrangements Insulation Resistance: 1000 MΩ minimum Contact Resistance: 10 mΩ maximum Current Rating: Refer to Current Rating Table CONTACT ARRANGEMENTS CORD CONNECTOR REAR (WIRING SIDE) VIEW EN2 CORD CONNECTOR FIELD ASSEMBLY INSTRUCTIONS: 1 Wire (awg) 20 22 24 26 20 22 24 26 20 22 24 26 26 28 30 Current Rating (A) at Operating Temperature (°C) 45°C max. 55°C max. 65°C max. 75°C max. 85°C max. 7 6 5 4 3.5 5.5 5 4 3 2.5 5.5 5 4 3 2.5 4 3.5 2.5 2 1 6.5 5.5 4.5 3.5 2 5 4.5 3.5 3 1.5 5 4.5 3.5 3 1.5 3 2.5 2 1.5 0.5 5 4.5 3.5 3 1.5 4.5 4 3 2 1 4.5 4 3 2 1 3 2.5 2 1.5 0.5 3 2.5 2 1.5 1 2.5 2 1.5 1 0.5 2 1.5 1 0.5 0.5 D C Align coupling ring over housing and bring forward. Align cable-clamp/grommet on the rear of housing. Make certain grommet is completely inside the cable-clamp in the final position. 1.50 - 1.57 [38 - 40] Bring forward and thread handle onto housing until tight. Do not exceed 2 in-lb torque. B PIN CONTACTS (MALE) 0.94 23.8 B 0.16 [4.1] TYP 0.11 [2.8] FOR 5-7 #26 CONTACTS 0.53 13.5 TYPICAL CORD CONNECTOR WITH RIBBED COUPLING RING TOOL TOOL TYPE EN3CR A HAND CRIMP TOOL EN3CRAUTO PNEUMATIC CRIMP TOOL HAND CRIMP TOOL LARGE FRAME EN2CRL EN2CRAUTOL PNEUMATIC CRIMP TOOL LARGE FRAME EN3INS20 EN3INS26 CONTACT INSERTION/EXTRUCTION 8 SOCKET CONTACTS (FEMALE) 0.70 17.8 TYPICAL CORD CONNECTOR WITH WINGED COUPLING RING POSITIONER CONTACT SIZE WIRE SIZES EN2POS20 EN3POS26 EN2POS20 EN3POS26 20 and 22 26 20 and 22 26 20 and 22 AWG 26, 28, and 30 AWG 20 and 22 AWG 26, 28, and 30 AWG EN2POS20L 20 and 22 20, 22, 24, and 26 AWG --- 7 0.90 22.8 20 and 22 26 ALL DIMENSIONS FOR REFERENCE ONLY THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. UNLESS OTHERWISE SPECIFIED WIDTH MULT - TWO PLACE DECIMALS 0.02 - THREE PLACE DECIMALS 0.005 09/20/12 PNK SRC TOOLS REVISED 05/14/12 PNK * DATE DRAWN BY CHKD APVD 0A PRELIMINARY 02/08/12 PNK * 02/08/12 PNK PNK 02/08/12 SRC 02/08/12 REV ECO NUMBER 4 APVD 1.5:1 NAME DO NOT SCALE DRAWING SolidWorks CAD File A SPEC No. SPECS UPDATED BY TEMPER SCALE 0B DATE LBS/M MATERIAL SPEC No. FIRST USED ON 0C REVISIONS 5 SIZE FINISH 1. ALL DIMENSIONS IN INCHES --- 6 CUSTOMER DRAWING EN2C SERIES CONNECTORS, RoHS C SHEET PART No. 1 OF EN2C SERIES 1 REV 0C
EN2C4F22DC 价格&库存
很抱歉,暂时无法提供与“EN2C4F22DC”相匹配的价格&库存,您可以联系我们找货
