EGG.1B.305.CLL
EGG.1B.305.CLL
    LEMO(雷莫)
    EGG.1B.305.CLL
EGG.1B.305.CLL 数据手册
EGG.1B.305.CLL www.lemo.com SUMMARY # Wires Low voltage 5 Image is for illustrative purpose only Series 1B Termination type Female solder IP rating 50 AWG wire size 30.00 - 22.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FGG.1B.305.CLAD52Z Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model EG*: Fixed receptacle, nut fixing Keying No keying Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 8.96 g Performance Configuration 1B.305 : 5 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 9 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) R (max): 4.8 mOhm Vtest (contact-shell): 1150 V (AC), 1630 V (DC) Vtest (contact-contact): 1250 V (AC), 1770 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M N S1 S3 e mm. 14 16 7.5 23 1.5 21.1 10.5 14 M12x1.0 in. 0,55 0,63 0,30 0,91 0,06 0,83 0,41 0,55 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables CMN.05.T22.051QGZE TPR (medical) Grey CMN.05.T28.029PGCE PVC GREY CMN.05.T28.029PGZE CMN.05.T28.029PNCE Grey PVC Black 150250 PVC Grey 50090 PVC Black 50140 PVC Grey 5050 PVC Black CMN.05.T28.029PNZE LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
EGG.1B.305.CLL
物料型号:EGG.1B.305.CLL
器件简介: - 该产品是LEMO公司B系列室内带锁连接器的一部分。 - 具有5个低电压接触点。 - 适用于固定面板前安装的插座/插孔。 - 采用推拉式锁定系统。
引脚分配: - 接触点配置值为1B.305 - 5 Low Voltage。 - 接触点类型为焊接。 - 最大固体导体为0.34mm²(AWG 22)。 - 最大绞合导体为0.34mm²(AWG 22)。
参数特性: - 额定电流为9A。 - 接触点之间的测试电压为1250V(交流),1770V(直流)。 - 接触点与外壳之间的测试电压为1150V(交流),1630V(直流)。 - 绝缘材料为PEEK(UL 94/V-0/1.5)。
功能详解: - 该连接器适用于音频视频、能源工业、医疗、半导体、特殊用途、测试测量、交通、航空航天和无人机等多个技术领域。 - 环境密封等级为IP50。 - 工作温度范围为-55°C至+250°C。 - 气候类别为50/175/21。 - 最大湿度为60°C/140°F时的95%。 - 屏蔽效果最小为10 MHz时的75 dB和1 GHz时的40 dB。 - 抗冲击能力为100 g(6 ms)。 - 耐振性为15 g(10 Hz - 2000Hz)。 - 耐盐雾腐蚀时间超过1000小时。
应用信息: - 推荐配件包括扳手(型号:DCA.91.201.4TN)。 - 推荐电缆包括CMN.05.T22.051QGZE(TPR医用级,灰色)等。
封装信息: - 外壳材料为黄铜(镀铬[SAE AMS 2460]),锁环和中件为镍镀黄铜(SAE AMS QQ N 290)。 - 重量为8.96克。
EGG.1B.305.CLL 价格&库存
很抱歉,暂时无法提供与“EGG.1B.305.CLL”相匹配的价格&库存,您可以联系我们找货
EGG.1B.305.CLL
    库存:18
    EGG.1B.305.CLL
    • 1+183.96044
    • 5+178.44110
    • 25+174.86916
    库存:20
    EGG.1B.305.CLL
      • 1+294.869821+37.78262
      • 10+284.5236510+36.45693
      • 25+265.8731925+34.06719
      • 50+249.5038950+31.96974
      • 100+235.03979100+30.11641
      库存:55
