PKG.M1.4SL.LG
www.lemo.com
SUMMARY
# Wires
Low voltage
14
Image is for illustrative purpose only
Series
1P
Termination type
Female solder
IP rating
50
AWG wire size
28.00 - 0.00
Cable Ø
0.00 - 0.00 mm
Status
active
Matching parts
PAG.M1.4SL.AC52GZ
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
PK*: Fixed receptacle with two nuts (back panel mounting)
Keying
1 key (alpha=0; Plug: male contact; Receptacle: female contact)
Housing Material
PEI (Polyetherimide), gray
Variant
G : Gray front nut
Performance
Configuration
1P.M14 : 14 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
2 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.5 mm (0.0201in)
Bucket Dia.: 0.45 mm (0.018in)
Max. Solid Conductor: 0.09 mm^2 (AWG 28)
Max. Stranded Conductor: 0.09 mm^2 (AWG 28)
R (max): 8.5 mOhm
Test voltage (kV rms) Contact-contact: 0.6
Air clearance min.: 0.5 mm
Creepage distance min.: 0.5 mm
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/2
Others
Endurance (Shell): >2000 mating cycles
Temp (min / max): -50°C / +170°C
F ret (min): 50 N
F ret (max): 150 N
Steam sterilization: > 100 times (with potting on rear connection)
DRAWINGS
Dimensions
A
N
a
mm.
19.5
20.522.2
0-4.5
in.
0,77
0,81
0,00
RECOMMENDED BY LEMO
Tools
2/2
很抱歉,暂时无法提供与“PKG.M1.4SL.LG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+458.196361+59.03138
- 10+389.4294210+50.17185
- 25+383.4314425+49.39910
