FGG.00.304.CLAD35Z
FGG.00.304.CLAD35Z
    LEMO(雷莫)
    FGG.00.304.CLAD35Z
FGG.00.304.CLAD35Z 数据手册
FGG.00.304.CLAD35Z www.lemo.com SUMMARY # Wires Low voltage 4 Image is for illustrative purpose only Series 00 Termination type Male solder IP rating 50 AWG wire size 34.00 - 28.00 Cable Ø 2.80 - 3.50 mm Status active Matching parts EGG.00.304.CLL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 4.01 g Performance Configuration 00.304 : 4 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 2 Amps Specifications Contact Type: Solder Contact Dia.: 0.5 mm (0.02in) Bucket Dia.: 0.4 mm (0.016in) Max. Solid Conductor: 0.09 mm^2 (AWG 28) Max. Stranded Conductor: 0.05 mm^2 (AWG 30) R (max): 8.7 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-shell): 650 V (AC), 920 V (DC) Vtest (contact-contact): 800 V (AC), 1130 V (DC) Others Salt Spray Corrosion: >1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 6.4 28.5 20.7 5.5 6 in. 0,25 1,12 0,81 0,22 0,24 RECOMMENDED BY LEMO Tools Caps: BFG.00.100.PCSG Cables CMN.04.T28.031PGCE CMN.04.T28.031PGZE PVC GREY Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 CMN.04.T28.031PNCE PVC Black CMN.04.T28.031QGC TPR Grey 4041 PVC Grey 4050 PVC Black CMN.04.T28.031PNZE LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.00.304.CLAD35Z 价格&库存
很抱歉,暂时无法提供与“FGG.00.304.CLAD35Z”相匹配的价格&库存,您可以联系我们找货
