FGG.1B.305.CLAD52Z
FGG.1B.305.CLAD52Z
    LEMO(雷莫)
    FGG.1B.305.CLAD52Z
FGG.1B.305.CLAD52Z 数据手册
FGG.1B.305.CLAD52Z www.lemo.com SUMMARY # Wires Low voltage 5 Image is for illustrative purpose only Series 1B Termination type Male solder IP rating 50 AWG wire size 30.00 - 22.00 Catalog Cable Ø 4.30 - 5.20 mm See video assembly instructions Status active Matching parts EGG.1B.305.CLL Download Request a quote Eplan PHG.1B.305.CLLD52Z TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 16.68 g Performance Configuration 1B.305 : 5 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 9 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) R (max): 4.8 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-shell): 1150 V (AC), 1630 V (DC) Vtest (contact-contact): 1250 V (AC), 1770 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 12 42 31 10 9 in. 0,47 1,65 1,22 0,39 0,35 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Spanner wrench: DCD.1B.ZZZ.PA090 Caps: BFG.1B.100.PCSG Cables CMN.05.T22.051QGZE TPR (medical) Grey 50090 PVC Black 50140 PVC Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.1B.305.CLAD52Z
物料型号:FGG.1B.305.CLAD52Z
器件简介:LEMO的B系列连接器,适用于室内使用,具有5个低压接触点。
引脚分配:5个低压接触点,适用于AWG 30至22的线缆。
参数特性: - 接触终止:焊接 - 最大电阻:4.8毫欧 - 额定电流:9安培 - 接触-接触电压测试:1250V AC/1770V DC - 接触-外壳电压测试:1150V AC/1630V DC - 最大实心导体:0.34 mm² (AWG 22) - 最大绞合导体:0.34 mm² (AWG 22)
功能详解: - 外壳风格/型号:FG - 直插头,电缆卡环和螺母用于安装弯曲缓解 - 锁定系统:推拉式 - 键槽:1个键(alpha=0,插头:男性接触,插座:女性接触)
应用信息: - 技术领域:音视频、能源与工业、医疗、半导体、特殊用途、测试与测量、交通、航空航天和无人机 - 环境密封(IP等级):IP50 - 温度范围:-55°C/+250°C
封装信息: - 重量:16.68克 - 推荐配件:兼容的帽BFG.1B.100.PCSG,扳手DCP.91.001.TN,扳手DCC.1B.ZZZ.PA090 - 推荐电缆:CMN.05.T22.051QGZE(TPR医用级)、50090(PVC黑色)、50140(PVC灰色)
FGG.1B.305.CLAD52Z 价格&库存
很抱歉,暂时无法提供与“FGG.1B.305.CLAD52Z”相匹配的价格&库存,您可以联系我们找货
FGG.1B.305.CLAD52Z
    • 1+341.568781+43.77984
    • 10+329.5843410+42.24376
    • 25+307.9685325+39.47320
    • 50+289.0222450+37.04480
    • 100+272.26674100+34.89720
    库存:74
