CKB.M16.GLLG
www.lemo.com
SUMMARY
# Wires
Low voltage
16
Image is for illustrative purpose only
Series
2P
Termination type
Female solder
IP rating
50
AWG wire size
30.00 - 22.00
Cable Ø
0.00 - 0.00 mm
Status
active
Matching parts
CAB.M16.GLA.C52G
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
CK*: Fixed receptacle with two nuts (back panel mounting)
Keying
No keying
Housing Material
PSU (Polysulfone), gray
Weight
6.55 g
Performance
Configuration
2P.M16 : 16 Low V.
Insulator
L: PEEK for solder contacts
Rated Current
6 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.7 mm (0.027in)
Bucket Dia.: 0.8 mm (0.031in)
Test voltage (kV rms) Contact-contact: 1.5
Air clearance min.: 0.47 mm
Creepage distance min.: 0.47 mm
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/2
Endurance (Shell): >1000 mating cycles
Temp (min / max): -50°C / +150°C
F ret (min): 150 N
F ret (max): 250 N
Steam sterilization: 20 times
DRAWINGS
Dimensions
N
a
mm.
23.8
3.4-4.9
in.
0,94
0,13
RECOMMENDED BY LEMO
Tools
2/2
很抱歉,暂时无法提供与“CKB.M16.GLLG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+597.429791+76.96942
- 10+507.8137210+65.42380
- 30+469.9607130+60.54703
- 50+453.3393950+58.40564
- 100+431.72975100+55.62158
