FGG.1B.304.CLAD42Z
FGG.1B.304.CLAD42Z
    LEMO(雷莫)
    FGG.1B.304.CLAD42Z
FGG.1B.304.CLAD42Z 数据手册
FGG.1B.304.CLAD42Z www.lemo.com SUMMARY # Wires Low voltage 4 Image is for illustrative purpose only Series 1B Termination type Male solder IP rating 50 AWG wire size 30.00 - 22.00 Catalog Cable Ø 3.10 - 4.20 mm See video assembly instructions Status active Matching parts EGG.1B.304.CLL Download Request a quote Eplan PHG.1B.304.CLLD42Z TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 16.90 g Performance Configuration 1B.304 : 4 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 10 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) R (max): 4.8 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-shell): 1450 V (AC), 2050 V (DC) Vtest (contact-contact): 1350 V (AC), 1910 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 12 42 31 10 9 in. 0,47 1,65 1,22 0,39 0,35 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Spanner wrench: DCD.1B.ZZZ.PA090 Caps: BFG.1B.100.PCSG Cables CMN.04.T28.031PGCE PVC CMN.04.T28.031PGZE CMN.04.T28.031PNCE GREY Grey PVC Black CMN.04.T28.031QGC TPR Grey 40080 PVC Black 40086 PVC Blue 40140 PVC Black 40240 PTFE White 4260 PTFE White CMN.04.T28.031PNZE LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.1B.304.CLAD42Z 价格&库存
很抱歉,暂时无法提供与“FGG.1B.304.CLAD42Z”相匹配的价格&库存,您可以联系我们找货
FGG.1B.304.CLAD42Z
    • 1+326.910401+41.88808
    • 10+315.4335910+40.41752
    • 25+294.7526225+37.76760
    • 50+276.6121250+35.44320
    • 100+260.57381100+33.38816
    库存:112
