EGG.1B.310.CLL
EGG.1B.310.CLL
    LEMO(雷莫)
    EGG.1B.310.CLL
EGG.1B.310.CLL 数据手册
EGG.1B.310.CLL www.lemo.com SUMMARY # Wires Low voltage 10 Image is for illustrative purpose only Series 1B Termination type Female solder IP rating 50 AWG wire size 34.00 - 28.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FGG.1B.310.CLAD52Z Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model EG*: Fixed receptacle, nut fixing Keying No keying Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 8.69 g Performance Configuration 1B.310 : 10 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 2.5 Amps Specifications Contact Type: Solder Contact Dia.: 0.5 mm (0.02in) Bucket Dia.: 0.45 mm (0.018in) Max. Solid Conductor: 0.09 mm^2 (AWG 28) Max. Stranded Conductor: 0.09 mm^2 (AWG 28) R (max): 8.7 mOhm Vtest (contact-shell): 1500 V (AC), 2120 V (DC) Vtest (contact-contact): 900 V (AC), 1270 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M N S1 S3 e mm. 14 16 7.5 23 1.5 21.1 10.5 14 M12x1.0 in. 0,55 0,63 0,30 0,91 0,06 0,83 0,41 0,55 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables CMN.10.T28.052PGZE Grey CMN.10.T28.052PNZE CMN.10.T28.053QGZE TPR (medical) Grey 110280 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
EGG.1B.310.CLL
物料型号: - 型号:EGG.1B.310.CLL
器件简介: - EGG.1B.310.CLL是LEMO公司生产的一种连接器,具有10个低电压接触点,适用于多种技术领域,包括音视频、能源工业、医疗、半导体、特殊用途、测试测量、交通、航空航天和无人机等。
引脚分配: - 接触点数量:10个低电压接触点 - 接线规格:34-28 AWG
参数特性: - 电气配置:焊接 - 最大电阻(R):8.7毫欧姆 - 插入配置值:1B.310 - 10低电压 - 绝缘体:PEEK(UL 94/V-0/1.5) - 额定电流:2.5安培 - 接触-接触测试电压:900V(交流),1270V(直流) - 接触-外壳测试电压:1500V(交流),2120V(直流) - 最大固体导体:0.09 mm²(AWG 28) - 最大绞合导体:0.09 mm²(AWG 28) - 桶径:0.45 mm(0.018英寸) - 接触直径:0.5 mm(0.02英寸)
功能详解: - 该连接器具有推拉式锁定系统,固定面板前安装的插座/插孔,以及G型钥匙(1个钥匙,α=0,插头:男性接触,插座:女性接触)。
应用信息: - 技术领域:音视频、能源工业、医疗、半导体、特殊用途、测试测量、交通、航空航天和无人机等。 - 环境密封(IP等级):IP50 - 耐久性:5000次配对周期 - 温度范围:-55°C至+250°C - 气候类别:50/175/21 - 最大湿度:60°C/140°F时≤95% - 屏蔽效果:10 MHz时至少75 dB,1 GHz时至少40 dB - 抗冲击性:100 g [6 ms] - 振动:15 g [10 Hz - 2000 Hz] - 盐雾腐蚀:>1000小时
封装信息: - 外壳样式/型号:EG - 固定插座,螺母固定 - 外壳材料:黄铜(镀铬[SAE AMS 2460])外壳和套筒螺母,镍黄铜(SAE AMS QQ N 290)拉袖和中件 - 颜色:灰色 - 重量:8.69克
EGG.1B.310.CLL 价格&库存
很抱歉,暂时无法提供与“EGG.1B.310.CLL”相匹配的价格&库存,您可以联系我们找货
EGG.1B.310.CLL
    库存:15
    EGG.1B.310.CLL
    • 1+270.29114
    • 5+267.12534
    • 25+260.40841
    • 50+253.91018
    库存:78
