FHG.0K.302.CLAC45
FHG.0K.302.CLAC45
    LEMO(雷莫)
    FHG.0K.302.CLAC45
FHG.0K.302.CLAC45 数据手册
Part Search Page 1 of 2 Part Number FHG . 0K . . Size/Series FHG.0K.302.CLAC45 MECHANICAL DETAILS PERFORMANCE DETAILS Shell Style/Model FH*: Elbow plug, cable collet Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Cable Fixing  : 4.1 - 4.5 mm Variant mm. in. : A 11.5 0.45 D 7.6 0.30 Request a quote /K H 27 1.06 L 36 1.42 M 25 0.98 S1 10 0.39 S2 8 0.31 S3 8 0.31 Insert Configuration Insulator Specifications Contact Type: Max. Matings: Contact Dia.: Bucket Dia.: Max. Solid Conductor: Max. Stranded Conductor: R (max): Vtest (contact-shell): Vtest (contact-contact): Rated Current: Copyright OTHER CHARACTERISTICS 0K.302 : 2 Low Voltage L: PEEK Solder 5000 0.9 mm (0.035in) 0.8 mm (0.031in) 0.34 mm^2 (AWG 22) 0.34 mm^2 (AWG 22) Humidity (max): Vibration: Shock Resistance: Salt Spray Corrosion: Climatical Category: Shielding (min): Shielding (min): IP Rating Catalog 144 hr 50/175/21 95 dB (10 MHz) 80 dB (1 GHz) 68 4.8 mOhm 1050 V (AC), 1490 V (DC) 1300 V (AC), 1840 V (DC) 10 A (AC/DC) Privacy policy Product safety http://intra.lemo.ch/PartSearch/SinglePartDisplay/nDECALFC~wdoZGtXRU53QUhhLgA... 2/21/2012
FHG.0K.302.CLAC45 价格&库存
很抱歉,暂时无法提供与“FHG.0K.302.CLAC45”相匹配的价格&库存,您可以联系我们找货
FHG.0K.302.CLAC45
  • 1+1113.146891+144.00255
  • 10+946.2549610+122.41253
  • 25+887.0694725+114.75598
  • 50+844.7802750+109.28523
  • 100+810.36931100+104.83364
库存:3
