Additional Resources:
Product Page
PCB Footprint
date
08/05/2022
page 1 of 9
SERIES: SDF-J | DESCRIPTION: STANDARD DIN CONNECTOR
FEATURES
• PCB mount
• front shielded
• right angle
PART NUMBER KEY
SDF - XX J
Base Number
Pin Options
30 = 3 pins*
40 = 4 pins
50 = 5 pins, 180 degrees
60 = 6 pins
70 = 7 pins*
80 = 8 pins
130 = 13 pins
* Discontinued models SDF-30J & SDF-70J.
SPECIFICATIONS
parameter
conditions/description
min
max
100
24
rated input voltage
rated input current
typ
at 100 Vac
at 24 Vdc
contact resistance
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
Vac
Vdc
2
1
A
A
mΩ
500
Vac
6.5
kg
5.0
kg
100
MΩ
insertion force
withdrawal force
1
operating temperature
-40
life
85
1,000
flammability rating
UL94V-0
RoHS
yes
units
°C
cycles
SOLDERABILITY
parameter
wave soldering
for 10 seconds max
hand soldering
for 5±1 seconds
cuidevices.com
min
typ
240
245
max
units
260
°C
250
°C
Product Page
PCB Footprint
CUI DEVICES | SERIES: SDF-J | DESCRIPTION: STANDARD DIN CONNECTOR
date 08/05/2022 | page 2 of 9
MECHANICAL DRAWING (SDF-30J)
units: mm
tolerance: ±0.3 mm
ITEM
DESCRIPTION
MATERIAL
PLATING/COLOR
1
body
PBT (UL94V-0)
black
nickel
2
shielded terminal
brass
3
plate
bakelite
4
terminals
brass
14.8 0.583
20.7 0.815
2.2 0.087
7.0 0.276
1.6 0.063
(2 PLCS)
21.4 0.843
1
3
10.0 0.394
2
1.85 0.073
(2 PLCS)
18.4 0.724
6.0 0.236
6.5 0.256
2.7 0.106
(2 PLCS)
1.0 0.039
(2 PLCS)
5.0 0.197
5.0 0.197
14.7 0.579
1.3 0.051
(5 PLCS)
15.0 0.591
3
5.0 0.197
(2 PLCS)
2
1.0 0.039
(3 PCLS)
10.0 0.394
15.0 0.591
2.4 0.094
(2 PLCS)
3.5 0.138
(TYP)
2.7 0.106
1
10.0 0.394
(3 PLCS)
5.0 0.197
Mounting Hole
(2 PLCS)
Recommended PCB Layout
Top View
cuidevices.com
tin
Product Page
PCB Footprint
date 08/05/2022 | page 3 of 9
MECHANICAL DRAWING (SDF-40J)
units: mm
tolerance: ±0.3 mm
unless otherwise noted
ITEM
DESCRIPTION
MATERIAL
PLATING/COLOR
1
body
PBT (UL94V-0)
black
nickel
2
shield terminal
brass
3
plate
bakelite
4
contact
brass
tin
4
3
2
1
E
Top View
(Date Codes prior to 03/03/2022)
E
Top View
(Date Codes after 03/03/2022)
cuidevices.com
Product Page
PCB Footprint
date 08/05/2022 | page 4 of 9
MECHANICAL DRAWING (SDF-50J)
units: mm
tolerance: ±0.3 mm
ITEM
DESCRIPTION
MATERIAL
PLATING/COLOR
1
body
PBT (UL94V-0)
black
nickel
2
earth terminal
brass
3
plate
bakelite
4
contact
brass
tin
1
3
2
3
1
5
2
4
4
4
5
3
2
5
1
3
Top View
4
2
1
Top View
cuidevices.com
Product Page
PCB Footprint
date 08/05/2022 | page 5 of 9
MECHANICAL DRAWING (SDF-60J)
units: mm
tolerance: ±0.3 mm
ITEM
DESCRIPTION
MATERIAL
PLATING/COLOR
1
body
PBT (UL94V-0)
black
nickel
2
earth terminal
brass
3
plate
bakelite
4
contact
brass
tin
6
4
5
2
3
1
Top View
Top View
cuidevices.com
Product Page
PCB Footprint
date 08/05/2022 | page 6 of 9
MECHANICAL DRAWING (SDF-70J)
units: mm
tolerance: ±0.2mm
20.7 0.815
7.0 0.276
MATERIAL
PLATING
housing
PBT
black
shielded terminal
brass
nickel
terminal
brass
tin
18.8 0.740
2.2 0.087
45°
7
6
3
21.4 0.843
1
4
5
10.0 0.394
2
1.85 0.073
(2 PLCS)
19.5 0.768
6.0 0.236
45°
6.5 0.256
2.70 0.106
(2 PLCS)
1.6 0.063
(2 PLCS)
1.0 0.039
(2 PLCS)
5.0 0.197
10.0 0.394
1.0 0.039
(7 PLCS)
12.5 0.492
15.0 0.591
2.40 0.094
(2 PLCS)
5.0 0.197
10.0 0.394
14.70 0.579
1.30 0.051
(9 PLCS)
3.5 0.138
(TYP)
2.7 0.106
15.0 0.591
Mounting Hole
(2 PLCS)
10.0 0.394
7
5
3
10.0 0.394
(3 PLCS)
2
4
6
1
12.5 0.492
(4 PLCS)
5.0 0.197
(2 PLCS)
5.00 0.197
Top View
cuidevices.com
Product Page
PCB Footprint
date 08/05/2022 | page 7 of 9
MECHANICAL DRAWING (SDF-80J)
units: mm
tolerance: ±0.3 mm
ITEM
DESCRIPTION
MATERIAL
PLATING/COLOR
1
body
PBT (UL94V-0)
black
2
shield terminal
brass
nickel
3
cover
PBT (UL94V-0)
black
4
contact
brass
tin
Top View
Top View
cuidevices.com
Product Page
PCB Footprint
date 08/05/2022 | page 8 of 9
MECHANICAL DRAWING (SDF-130J)
units: mm
tolerance: ±0.30 mm
PCB: ±0.05 mm
MATERIAL
PLATING
1
terminal
phosphor bronze
silver
2
ground contact
phosphor bronze
silver
3
housing
PBT 4815
UL94V-0
black
4
cover
PBT 4815
UL94V-0
black
5
sealed plate
copper alloy
copper/tin
Top View
cuidevices.com
Product Page
PCB Footprint
date 08/05/2022 | page 9 of 9
REVISION HISTORY
rev.
description
date
1.0
initial release
02/23/2006
1.01
new template applied
04/02/2012
1.02
updated housings
04/05/2012
1.03
corrected SDF-50J and SDF-51J pinouts
07/15/2014
1.04
updated datasheet
09/08/2017
1.05
updated datasheet
07/24/2018
1.06
discontinued model SDF-30J
10/08/2019
1.07
discontinued model SDF-70J
02/17/2020
1.08
changed housing
04/13/2020
1.09
modified design and changed factory for SDF-40J, SDF-50J, SDF-60J, & SDF80J
02/21/2022
logo, datasheet style update
08/05/2022
1.10
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“SDF-70J”相匹配的价格&库存,您可以联系我们找货
