EEG.00.304.CLL
www.lemo.com
SUMMARY
# Wires
Low voltage
4
Image is for illustrative purpose only
Series
00
Termination type
Female solder
IP rating
50
AWG wire size
34.00 - 28.00
Cable Ø
0.00 - 0.00 mm
Status
active
Matching parts
FGG.00.304.CLAD35Z
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
EE*: Fixed receptacle, nut fixing (back panel mounting)
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
3.02 g
Performance
Configuration
00.304 : 4 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
2 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.5 mm (0.02in)
Bucket Dia.: 0.4 mm (0.016in)
Max. Solid Conductor: 0.09 mm^2 (AWG 28)
Max. Stranded Conductor: 0.05 mm^2 (AWG 30)
R (max): 8.7 mOhm
Vtest (contact-shell): 650 V (AC), 920 V (DC)
Vtest (contact-contact): 800 V (AC), 1130 V (DC)
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Others
Salt Spray Corrosion: >1000 hr
12NC part number: 4022.438.73100
DRAWINGS
Dimensions
A
B
E
L
M
N
P
S1
S2
e
mm.
10
9.5
2.3
15.5
2.5
13.7
6
6.3
7.5
M7x0.5
in.
0,39
0,37
0,09
0,61
0,10
0,54
0,24
0,25
0,30
RECOMMENDED BY LEMO
Tools
Spanner wrench:
Socket for torque wrench DCM.00.M07.4
Cables
CMN.04.T28.031PGCE
PVC
CMN.04.T28.031PGZE
CMN.04.T28.031PNCE
GREY
Grey
PVC
Black
2/3
CMN.04.T28.031PNZE
CMN.04.T28.031QGC
TPR
Grey
40080
PVC
Black
40086
PVC
Blue
4041
PVC
Grey
4050
PVC
Black
4080
PVC
Grey
417920
PVC
Grey
4280
PVC
Black
80080
PVC
Grey
80082
PVC
Red
80084
PVC
Black
CTR.75.030.121870G
PVC
Grey
3/3
很抱歉,暂时无法提供与“EEG.00.304.CLL”相匹配的价格&库存,您可以联系我们找货
